Closed Thread
Old 03-11-2010, 08:07 PM   #976
DPowers
DPowers's Avatar
Re: What did you do to your truck today?
Originally Posted by lakeroadster View Post
Started on grille modifications:
On the Custom Classic Trucks website I saw a photo of a stock "big truck" grille with stainless bars (see the first picture below). Very clean... I want to replicate that look.
First step was to cut out the stamped steel mesh. I used my air grinder and a 4" cut-off wheel.
Next was fab'g. up some mounting brackets for both sides out of 1" angle. These were drilled for (5) 3/16" dia. stainless tubes.
Next step is to make a mounting bracket for the center and then procure some stainless 3/16" tubing.
Cool- looking forward to seeing it
DPowers is offline
Old 03-12-2010, 05:24 PM   #977
hossmann
hossmann's Avatar
today a buddy and I fireed up my new 355 rebuild
hossmann is offline
Old 03-13-2010, 12:31 AM   #978
low900rr
Started shortening one of my bedsides. One side is almost ready for finish welding and grinding.
My builds
69 stepside.......2wd to 4wd
http://67-72chevytrucks.com/vboard/s...d.php?t=330675
and the new 66
http://67-72chevytrucks.com/vboard/s...d.php?t=302321
low900rr is offline
Old 03-13-2010, 12:54 AM   #979
daxloves
daxloves's Avatar
Today I found this website and decided to do a complete front end swap from a 73-87 on to my 62
daxloves is offline
Old 03-13-2010, 01:03 AM   #980
markeb01
Senior Enthusiast
markeb01's Avatar
Cool. Welcome to the forum. The following thread might prove helpful:
http://67-72chevytrucks.com/vboard/s...d.php?t=366850
markeb01 is offline
Old 03-13-2010, 01:08 AM   #981
daxloves
daxloves's Avatar
Thank you. That is one of the threads that got me thinkin
daxloves is offline
Old 03-13-2010, 11:28 AM   #982
Chevy Fleetside
Chevy Fleetside's Avatar
I am off to the shop to do some work to the 66 hopfully. It is going to be hard to do by myself but I will try. Last week this was my helper and he did very well.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 03-13-2010, 11:49 AM   #983
65Gregg
65Gregg's Avatar
I just pulled my carb, time for a quick rebuild and new floats. It is amazing what 5 1/2 years of bad gas does to the carb....trying to get it running for the Lonestar Roundup next month.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 03-13-2010, 12:33 PM   #984
ravens65
ravens65's Avatar
Drove it , yes finally after 5 years its almost done . it has a oil leak and that pisses me off cause its from the engine builder, but.... all I can do is fix it . its either the front seal or the timing cover. still felt nice to drive it to a friends house and back.
If it has tits or wheels its gonna give you problems!!!
ravens65 is offline
Old 03-13-2010, 02:50 PM   #985
shrunken66stroker
shrunken66stroker's Avatar
At least the leak is in the front, Eric. Any smoke come off the tires on the trip?
shrunken66stroker is offline
Old 03-13-2010, 03:37 PM   #986
ravens65
ravens65's Avatar
no smoke this time, last time I did but motor is not broke in yet, so.... of course it did! almost had ya fooled- didn't I
ravens65 is offline
Old 03-13-2010, 05:10 PM   #987
Slow Build
Slow Build's Avatar
Well, I guess I'll go help him. But I can't compete with last weeks helper.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline
Old 03-13-2010, 07:04 PM   #988
Slow Build
Slow Build's Avatar
Too late. Shops locked up tight. Maybe next time.
Past GM Trucks:
Old 03-13-2010, 07:48 PM   #989
hunterkane
put a 350 in it going to try and get it runing tomorrow
hunterkane is offline
Old 03-13-2010, 08:07 PM   #990
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Removed the steering box and driveshafts off the K10. They'll go off to the rebuilder's this week.
aerotruk63 is offline
Old 03-13-2010, 08:53 PM   #991
daxloves
daxloves's Avatar
Put new brake/clutch master cylinder kits in so now I can go, shift AND stop all in the same trip Tell ya tho, I cant wait till i swap the front and go disk and upgrade to a differnt brake cyl. No one had 2 kits in stock so I had to hit 2 parts houses to get the 2 kits. Napa charged 21.99 and Oriley was 15.99. go figure.
daxloves is offline
Old 03-13-2010, 10:25 PM   #992
Chevy Fleetside
I put some pulleys on the engine, dropped in the dist and bolted down the valve covers. I also cleaned up some of the mess cutting up a truck leaves behind.. Thanks for the effort Rich..
Old 03-13-2010, 10:32 PM   #993
Woogeroo
Yesterday I took it to my mechanic and wrote the check.
oil/filter change
front end/driveshaft lube
tires rotated and balanced (they were new tires but dang it rides a lot better now!)
brake shoes/drums inspected (while they had the wheels off)
emergency brake cable checked and lubed
they also tuned the carburetor... which is good since it seem to ride a lot smoother now
new master brake cylinder and fluids, etc..
A lot of the above I usually do myself... but I'm on vacation week after next and I wanted it done.
I'm lucky, my mechanic works on old stuff.
-W
Woogeroo is offline
Old 03-14-2010, 01:10 AM   #994
burbguy
burbguy's Avatar
today I set the dwell and timing on the 66, and greased the front end... and drove it...
burbguy is offline
Old 03-14-2010, 01:20 AM   #995
63 extreme low
63 extreme low's Avatar
Went to the Louisville swap meet and scored a GMC dash cluster for five bucks!!
1963 Big Back window short fleet
63 extreme low is offline
Old 03-14-2010, 02:20 AM   #996
Slow Build
Slow Build's Avatar
No biggie. Though the Sheriff hiding behind the mustard plants down the street did give me a moment of concern. We must have past on Cypress but I was in my Audi so you wouldn't have noticed me. I don't know what my excuse was.
I wish I could have helped.
Past GM Trucks:
Old 03-14-2010, 02:29 AM   #997
Slow Build
Slow Build's Avatar
Originally Posted by burbguy View Post
... and drove it...
It's a runner!!!
Isn't it cool?
I've been collecting parts at junkyards that I don't really need. Also ordered a gas fill tube so I can put some gas in it without having it leak in the cab.
Past GM Trucks:
Old 03-14-2010, 02:32 AM   #998
Dan in Pasadena
Dan in Pasadena's Avatar
Since no one is posting on the Pre-'47 board:
I did the final installation on my '46's glove box and door - the hinge-to-doors screws are too loose though. Gonna have to drill and re-tap CAREFULLY to avoid breaking loose the caged nuts.
Wire-wheeled, painted and installed my recently acquired rear headliner bow.
Pulled my steering wheel, filed cracks and began repairing using JB Weld. It's a work in progress.
And last, I bought a $10 1941 Calfornia license plate just to try my hand at restoration. It's rusty but it's only gonna hang on my shop wall. Stripped it, primered it with several coats of sand-able primer and painted it gloss black. Tomorrow I mask & paint the letters/number.
Dan in Pasadena is offline
Old 03-14-2010, 02:45 AM   #999
Slow Build
Slow Build's Avatar
I think I speak for everybody when I say your welcome here.
Does the crank on the dash open the bottom of the windshield?
A/C must be a tight fit on that truck.
Past GM Trucks:
Old 03-14-2010, 11:21 AM   #1000
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Welcome Dan. How about a shot of the whole truck.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline
Closed Thread
