10-21-2010, 10:41 AM | #976 |
Re: What did you do to your truck today!
Last night, cleaned and swept interior, cleaned all the windows and replaced the right side mirror. It runs better today for some reason...
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
10-21-2010, 04:22 PM | #977 |
Big Red - Now its a SWB!
I changed a leaky power steering line, checked fluids, and sprayed off some of the mess from the leaky line. Then I drove to Home Depot to get some lumber.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
10-21-2010, 07:32 PM | #978 | |
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
10-21-2010, 08:03 PM | #979 | |
Collector of Projects
And I just received my poly body mount and 1" aluminum lift from ORD.... so I may have a new update this weekend... |
10-21-2010, 08:43 PM | #980 |
Thanks!
10-21-2010, 08:46 PM | #981 |
dazed and confused
drove to work and back home, then got the kids and took them to dinner.
members met: redbaron69, billsbowtie,nc67 |
10-21-2010, 09:08 PM | #982 |
Started the final mount to my rear fuel cell then realised i grabbed a couple of incorrect bolts out of the bin at the hardware store... Gerr...
10-22-2010, 09:19 PM | #983 |
Junior Member
I finally did something for my truck, but not to my truck. I did a side job to get some money to order a carb for my truck, roofing job.
A few minutes ago I ordered a carb for the '71. It should be in sometime next week and then I will finally be able to drive my truck again.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
10-22-2010, 09:23 PM | #984 |
Put on new hood hinges and spring. Spent 30 minutes on the first spring trying to figure out how to spread the spring. Then I grabbed a hammer and used the claw end. I stood on the inside of the engine bay and pulled....and pulled......and pulled......and bam it caught. Then did the other side on the first try.
10-22-2010, 11:29 PM | #985 |
RAT1968 '68 Cab/'71 Parts
Cut the hole above the radio space for the Vintage Air center vent. Ran the trans cooler tubes to the front. Mocked up the aluminum radiator. Started playing around with the rear brake lines (stuck like glue). Worked on figuring out why the BAT terminal of the HEI was used... and there are still three wires hanging out of the body of the dizzy. Started to plumb the oil gauge line. Got tired and came home and painted the carb with POR15 (I was very careful).
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 10-22-2010 at 11:31 PM. Reason: forgot the pics |
10-22-2010, 11:46 PM | #986 |
Burned up another compressor painting. This is #2 on this build. Gonna have to break down and spend some big bucks for a good one. YUCK!
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
10-23-2010, 12:03 AM | #987 |
Broke and still trying
6" lift and ORD extended brake lines. Still need to change my shocks over and extend my drivelines. Then my wife wants to drive it already. PATIENCE!
10-23-2010, 02:47 AM | #988 |
Timing was off so i fixed that and messed with the carb for a while...working better now...also put in a new air filter and gas...LOL!!!
10-23-2010, 08:32 AM | #989 |
Redefining LowBudget
all I'm going to say is last weekend hauled in the hot tub..this week is fire wood fire wood and more fire wood....I wish there was a hot tub big enough for my truck because it works as hard as I do at this and I think niether of us really like it....but it is getting new brakes and a compressor in the next week or so
10-23-2010, 04:38 PM | #990 |
Junior Member
Started the '71 with the 454 to move it from the carport to the garage so I can get it ready for the carb I ordered yesterday.
Once it was started it ran great so I could not resist taking it for a short ride, probably 4 miles. I resisted the urge to light up the tires though, must be getting old, lol. The 454 in combination with a granny 4 speed is great since I use the truck often here on the farm.
10-23-2010, 06:01 PM | #991 |
I took out the driver side inner fender, the passenger side will come out tomorrow. Learned the front part of the cab is in pretty darn good shape so it looks like cab mounts and floor patches in my future.
-Scott- |
10-23-2010, 06:18 PM | #992 |
Kill Bill...et
Wife got rear ended in her car yesterday...turned the '67 into a daily driver today.
10-23-2010, 06:26 PM | #993 |
Junior Member
Sorry to hear that your wife got into a wreck. Hope she is ok.
10-23-2010, 06:32 PM | #994 |
Kill Bill...et
She's fine. Took a trip in the wambulance to the hospital but was planning on grocery shopping today. And just FYI, the rear end of an Acura TL won't hold up as well as the front bumper of a Dodge Ram!....hmmmm...who knew. Thanks for the concern.
10-23-2010, 07:18 PM | #995 |
I got the the drums and spindle assembly removed. Lots and Lots of banging with the hammer. Only hit my hand twice. The first time was enough, but I just had to see if would hurt the second time. Guess what... IT DID!!!!! I got the top ball joints out, then it got dark. It's bad when you have a 30' by 26' shop and have to work in the yard. Hopefully I can get the lowers out after church tomorrow.
10-23-2010, 07:43 PM | #996 |
Rebuilt the piston on my compressor. As luck would have it my neighbor had and extra motor for his compressor and it was the same motor I had in mine. What are the odds? Painted another coat on the bed, bed strips and tailgate.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 Last edited by 67Slider; 10-23-2010 at 07:43 PM. |
10-23-2010, 08:18 PM | #997 |
drove it to my shop. ran great, got in a burn out or two! cheers, Pat
10-23-2010, 11:00 PM | #998 |
Routed and bent new fuel lines for my new rear fuel cell, almost time to hook it up..
But in doing so my head got into a fight with the front driveshaft while trying to scootch my creeper in the dirt.... I think the driveshaft and creeper are in cahoots with each other.. And of course my head lost the fight. :p
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 10-23-2010 at 11:01 PM. |
10-23-2010, 11:30 PM | #999 |
Got a notice in our box (we're in the country) when we picked up the Saturday mail at 11:30 that there was a package at the Post Office that needed a signature. They close at 12:00 today. Sharp. We made it. Look what came in the mail today from Canada.
Earlier, a trip to the local Napa on the way to our grand son's soccer game yielded a bill of $82. And a bag of stuff you never count in the budget. (More) Carb cleaner, a set of brake line wrenches (lost my 7/16" ...and the set was cheaper than one wrench), a bucket of power steering fluid, a bucket of brake fluid, three brake line fittings, a hand full of hose clamps, etc. Also, here are a couple of (lousy, sorry) pics of the carb with POR15 on the body and a Krylon rehab of the hood "popper".
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
10-24-2010, 01:09 AM | #1000 |
Found more horsepower! Actually took about 8 degrees of timing out and it made more power! Also found after the carpet install with the mat, Lost about a half inch of adjustment on the carb linkage, fixed that too. Going to the track on Wednesday night to see what it will do. Last time it went 7.86 at 86 mph in the 1/8th.
