Old 07-01-2013, 11:17 AM   #976
jhrusk
Re: Extreme Powder Coating '65 C-10 Shop Truck
it probably was built using a later model year block with a one piece rear seal which in turn would have a different flywheel flange than the older small block.
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 07-01-2013, 11:33 AM   #977
kart34
yes sir thats whats going on.. but were upgrading the whole clutch set up..
edited by staff
kart34 is offline   Reply With Quote
Old 07-02-2013, 09:22 PM   #978
kart34
looks like we have a problem.. pan is hitting the rack? why ? blueprint 383 installed .. 327 was in there?
edited by staff
Old 07-02-2013, 09:35 PM   #979
DURG
DURG's Avatar
Was one pan or the other an aftermarket reproduction pan? I'm guessing the one on your 383 is? Can you tell how much off it is? You should probably shoot for an 1/8" clearance to be safe
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 07-02-2013, 09:45 PM   #980
kart34
looks like 1.5 inches off...
edited by staff
Old 07-02-2013, 10:52 PM   #981
DURG
DURG's Avatar
Good lord, you better call and see what the heck they are using for a pan! I have seen deep sump pans but usually the front portion is not that much lower. Pictures?
Old 07-02-2013, 11:00 PM   #982
DURG
DURG's Avatar
I actually had Nate make me some engine mounts to LOWER the motor in my dropmember. It is the touring version not the extreme.
Before
After
Old 07-03-2013, 11:16 AM   #983
kart34
this is no good. ideas ?
edited by staff
Old 07-03-2013, 11:35 AM   #984
DURG
DURG's Avatar
Your motor appears to be moved forward compared to mine quite a bit too. Have you called Nate?
Old 07-03-2013, 12:28 PM   #985
kart34
new fabrications. cooler in back, gauge display under dash...
thanks to Marshall Starrett "the WIZ"
edited by staff
Old 07-03-2013, 12:35 PM   #986
kart34
more fab work by Marshall Starrett - THE WIZ
edited by staff
Old 07-03-2013, 12:36 PM   #987
PBFAB.COM
PBFAB.COM's Avatar
We text back and forth a few times last night. My recommendation was to go to a shallow pan like the 327 had.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 07-03-2013, 01:06 PM   #988
hotrod1
56 - autocross
hotrod1's Avatar
Did u use regular rivets to hold all this cool fab work together? Are those tweeter speakers in the door panels? Can u show a close up of those and how you did it?
hotrod1 is offline   Reply With Quote
Old 07-03-2013, 04:29 PM   #989
kart34
The rivets area race car deal... Allstar Performance exploding rivets no backer needed
Also talked to Blueprint Engines. just have to change out the pan from the 327.. ???
edited by staff
Old 07-07-2013, 08:54 PM   #990
kart34
Just got home from Good-Guys Heartland Nationals.. got to see a few forum buddys.. It was good to get Low-Lark out for a cruise..
edited by staff
Old 07-08-2013, 08:07 AM   #991
ChickenCityHotRods
ChickenCityHotRods's Avatar
Are you going to have the truck at Columbus Good-Guys this weekend?
Twin Turbo and Dropmember equipped http://67-72chevytrucks.com/vboard/s...d.php?t=586662
Follow us on Instagram @CHICKENCITYHOTRODS
ChickenCityHotRods is offline   Reply With Quote
Old 07-08-2013, 01:58 PM   #992
McMurphy
McMurphy's Avatar
Hmmmmmmm
That under dash decking/plate looks smooth....
I wonder .....
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 07-09-2013, 08:13 AM   #993
creep
Registered Loser
creep's Avatar
Ditto. Dieing to see this truck in person. Maybe even snap some pics of mine next to it.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 07-10-2013, 10:23 AM   #994
ChickenCityHotRods
Hey creep, where do you park? I missed seeing your truck last year and wanna make sure I get to check it out.
Old 07-10-2013, 02:48 PM   #995
creep
Registered Loser
creep's Avatar
It changes every year. Usually where ever I can find a spot. Last year I was able to squeeze in by grumpy over near the pavilions on Friday and in the judged section on Saturday. I'll post on here where I find a spot to cram it.
Old 07-12-2013, 11:20 AM   #996
creep
Registered Loser
creep's Avatar
I got a spot at the far end of the show on the path around the pavilions.
Old 07-13-2013, 02:07 AM   #997
Captainfab
60-66 Nut
I was thinking that your 383 is built with the later model one piece rear main seal block. I assume that is the main reason the 327 flywheel wouldn't bolt up. If that is the case, then the 327 oil pan will not fit the later model block with the one piece rear main seal. You will also need to be sure a different pan will have enough clearance for the 3.75" stroke.
Old 07-13-2013, 09:16 AM   #998
creep
Registered Loser
creep's Avatar
Today I'm in the homebuilt haulers section of the special feature area. Wanted to park close to the spectator parking so my friends don't have to walk 20 miles back to the cars after the show.
Old 07-13-2013, 12:22 PM   #999
gofastnut
gofastnut's Avatar
I agree with Captain Fab, I'm not sure that's going to work. Maybe a stock pan from a Camaro would work?
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 07-15-2013, 01:54 PM   #1000
kart34
Good Afternoon
This is Tiffany, Kart's daughter.
He asked to post an update. Unfortunately, today the update is not about the C-10.
Greg, you may know him as kart34, was admitted to the hospital last Monday evening after going in with a severe headache, fatigue, and swollen lymph nodes.
After blood tests it was confirmed that he has Leukemia. He will be admitted for 4 weeks.
Greg has been receiving 24 hour chemotherapy treatments and is responding very well. His last treatment will be on Wednesday. He is a good patient and let me tell you the staff really loves him there. Greg has been feeling well on the chemo with little to NO side effects. He is also receiving blood transfusions to keep his counts up.
He is at Gundersen Lutheran Hospital in La Crosse WI.
Prayers and cards are appreciated, no plants or fruits as they carry microorganisms and can be harmful.
edited by staff
'65, c-10, carter hickman designs, extreme powder coating
