Old 11-02-2013, 07:37 PM   #976
Rodzzilla
Re: Project "My Happy Mess"
Looking good.
Rodzzilla is offline   Reply With Quote
Old 11-03-2013, 01:33 AM   #977
litew8
litew8's Avatar
Thanks fellow Iowan
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 11-03-2013, 02:02 AM   #978
5150.4.67
Seat cover (and entire interior) looks fantastic!
5150.4.67 is offline   Reply With Quote
Old 11-03-2013, 12:55 PM   #979
litew8
litew8's Avatar
Thanks The small brown areas on the seat's bottom aren't real visible without the camcorder. The camera lens detects better. The seat has been covered with a cheap seat cover to protect it, all the time I've owned the truck and then some. Probably 20+ years.
Old 11-05-2013, 04:32 PM   #980
litew8
litew8's Avatar
A couple hours worth of work update.
The only snag we've run into so far. The front panel wouldn't lift up far enough to line up.
We concluded this to be a stamping error and adjusted as needed. It'll clean up later.
Also, spot welds on the top insides of the bedsides were hammered flat to help achieve proper clearance (upward from within).
Pass. side didn't need modified, other than hammering on the weld.
The new co-worker. He doesn't do much of anything
Heck yeah
Old 11-05-2013, 08:00 PM   #981
oldman3
oldman3's Avatar
Nice looking wood...Jim
oldman3 is offline   Reply With Quote
Old 11-05-2013, 10:17 PM   #982
litew8
litew8's Avatar
Thanks! Absolutely awesome Ash wood/kit from:
Bruce Horkey's
Old 11-06-2013, 09:13 PM   #983
litew8
litew8's Avatar
No truck work/updates for the rest of this week.
In next week's episode, we'll fit the rear wheel wells, tailgate, and drill holes for bed wood (where necessary) all around.
Old 11-09-2013, 02:18 PM   #984
litew8
litew8's Avatar
Autumn pics
Old 11-09-2013, 08:21 PM   #985
sourkraut
sourkraut's Avatar
My new bedsides were just like that, nothing a debur on a die grinder cant fix. Looks great.
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 11-11-2013, 11:47 AM   #986
litew8
litew8's Avatar
Old 11-11-2013, 12:21 PM   #987
mcbassin
Still Learning
mcbassin's Avatar
That wood is killer! Love it.
mcbassin is offline   Reply With Quote
Old 11-11-2013, 08:36 PM   #988
litew8
litew8's Avatar
I'll try and get some pics up tonight.
Old 11-11-2013, 09:55 PM   #989
litew8
litew8's Avatar
Pics from today. In a progressive order.
Spot the problem:
Zeus or Raiden
My brother's considering firing the new co-worker.
Nonconformity issue #3.
Nonconformity issue #4.
Old 11-12-2013, 12:21 AM   #990
oldman3
oldman3's Avatar
Looking good..Jim
Old 11-12-2013, 01:03 AM   #991
mcbassin
Still Learning
mcbassin's Avatar
Looks good to me. I'm going to try to put my ole bed together this week myself. Thanks for showing me how. Oh dang, mine don't have that sweet wood in the floor
Old 11-12-2013, 01:10 AM   #992
litew8
litew8's Avatar
That 'sweet wood' will be getting covered with a rubber mat if hauling scratch insistent objects There are some minor differences between short/long steel/wood.
Old 11-12-2013, 08:59 PM   #993
litew8
litew8's Avatar
We've pretty much got the bed wood buttoned up. Pics up later.
Old 11-13-2013, 04:35 PM   #994
litew8
litew8's Avatar
Truck abuse
Tailgate on.
Holes on the bedsides > front panel have been drilled out to correct the misalignment issues.
We're ready to mark and drill our perimeter and tub holes for the bed wood.
After that, tear it apart and finish up.
Old 11-14-2013, 04:20 PM   #995
litew8
litew8's Avatar
Improved heavy duty fix.
Lines. Shimmed the bed cross sill (driver's side corner) from frame to correct unevenness.
Bed wood all buttoned up. Needs no more attention
Driver's side bedside needed a little modification.
Top rail middle bend was too obtrusive. Broke the spot welds to relieve the pressure.
Done.
Old 11-18-2013, 12:44 PM   #996
Jahloha
Jahloha's Avatar
Holy cow! I am so pumped and motivated. I just finished the thread, your truck is an inspiration. Im excited to follow you through the end and get there someday for me too.
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 11-18-2013, 04:32 PM   #997
litew8
litew8's Avatar
Thanks Couple hours a day adds up.
Old 11-18-2013, 05:07 PM   #998
mcbassin
Still Learning
mcbassin's Avatar
Nice progress on your bed. I had a few set backs on mine. Maybe soon.
Old 11-18-2013, 06:30 PM   #999
Jahloha
Jahloha's Avatar
I am interested in Zero Rust. It looks like you applied it to almost everything lol. I do not have access to a blaster, so would zero rust be an option for me, if I cant prep each piece like you have on your build?
-JASON
Old 11-18-2013, 10:12 PM   #1000
litew8
litew8's Avatar
For me, Zero Rust was cost effective and user friendly. It's held up good as far as I can tell. It likes to be applied to bare metal.
Red (for first coat) and Black (for second coat) are the recommended colors to use: Zero Rust
