Old 06-04-2014, 04:32 PM   #976
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Originally Posted by Eric15chevys View Post
Looks like you have been busy. I have my stuff being picked up this week and headed back down this weekend. I would love for my boys to get to see your trucks and parts sometime soon. They both love old chevys, but William likes square bodies better.
Anytime Eric....just give me a call and your welcome to come by. Bring the boys....I have enough land for them to run around on too. Maybe I can get my buddy Austin to bring his 79 square body down too!! Also.....will get the tailgate pulled for you this week.
Did your buddy decide what he wanted to do with the 230?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-06-2014, 01:33 PM   #977
WhippinSaw
WhippinSaw's Avatar
Re: 1963 C-10 in NC
great idea for the staple replacement, keep us posted Thanks
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 06-06-2014, 01:34 PM   #978
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Got a day behind on the fender closing panels. And correction on the wire gauge....its a 12 gauge aluminum wire that I use to remount the new seals to them. I drilled the staple holes out last night and hit them with one more coat of undercoating, so I can install the new rubbers and staples tonight. Will get some pics tonight.
Old 06-06-2014, 01:49 PM   #979
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
No problem....would have been done, but my 9/64" drill bit broke day before yesterday. Got a new pack of them yesterday so all holes are enlarged and with them hanging as we speak should be good and dry by tonight. I'll use a 1/8"drill bit on the rubber so its a little tighter on the wire. Saves having to use any glue in case you have to replace the rubbers down the road. The undercoating is added protection since they always seem to have rust issues....hopefully that will eliminate the issue.
Old 06-09-2014, 08:52 AM   #980
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Ok, here is the rest of the closing panel resto pics....
1st thing to do is make sure the holes are large enough to except what size wire your working with. Then I measure the distance between the two holes, cut off around 2" worth of wire and make two 90* bends so you create your replacement staple. Make sure to mark and drill the two holes in the gasket also for the staple to go through. Install the staple through the gasket and then through the metal, trim to length and fold over the two tabs on the back and repeat until done. Not hard and makes a big difference.
Old 06-09-2014, 08:53 AM   #981
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Last of the closing panels with new seals and 2 coats of undercoating and new 12ga aluminum staples. Should last quite a long time.
Old 06-09-2014, 08:55 AM   #982
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Got the inner fenders prepped and undercoated also....They look kinda spotty in the pics, but the undercoating is still drying in the pics.
Old 06-09-2014, 09:08 AM   #983
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Got a bunch of the frame and firewall coated also this weekend in undercoating. Frames really staring to pull together. Will start frame trimming tonight or tomorrow depending on work schedule.
And my other goal for the week is to get the new seals on the inner fenders (I already have all the seals to complete the front end). They are stapled like the rest of the engine bay seals, but these are some that I will glue on since they wrap the fenders and aren't just attached on one side.
Old 06-09-2014, 10:41 AM   #984
bj383ss
bj383ss's Avatar
Re: 1963 C-10 in NC
Looks good man! What brand undercoat did you use?
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 06-09-2014, 10:48 AM   #985
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
$5.49 a can at harbor freight and it lays down great. You can adjust the texture by how close you spray. Been using it for few weeks now and real satisfied with the results. Picked up on it in one of the Jeep forums....came highly recommended.
Old 06-10-2014, 01:02 PM   #986
61K10
61K10's Avatar
Re: 1963 C-10 in NC
Nice!!
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-10-2014, 01:15 PM   #987
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Originally Posted by 61K10 View Post
Nice!!
Thanks...especially after seeing the job that your doing with your truck!!
Old 06-30-2014, 11:42 AM   #988
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Been a few weeks of off and on with both trucks. Spent a few hours yesterday in the stepside and got the interior gutted and cleaned out. Will need to do inner rockers, forward floor pans, cab corners and outer rockers. Driver side will need the cab supports also. So its time to start cutting up my donar cab and getting some metal worked in. I'll get some pics up later of whats ahead of me.
Old 06-30-2014, 07:10 PM   #989
chevy6guy9
Re: 1963 C-10 in NC
Doing a great job, looking good.
chevy6guy9 is offline   Reply With Quote
Old 06-30-2014, 08:06 PM   #990
61K10
61K10's Avatar
Re: 1963 C-10 in NC
1963c-10---you are doing things top notch--every little detail is perfect. well me, i'am not quite in your zone, close maybe. Unless you do the rebuild yourself you can't splane it to others. there is a lot of exceptional people doing this here, and you are one my man!
1961 chevy K10
Old 06-30-2014, 11:46 PM   #991
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Nice work bud!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 07-01-2014, 09:20 AM   #992
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Thanks bud!!
Old 07-01-2014, 09:21 AM   #993
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Thank a bunch. Its going slower than I'd like, but I have a 5 day weekend starting July 4. Goal is front sheet metal off, crossmember swapped and engine set in. Should be a progressive weekend if the weather holds. I have all the parts on hand, so its just a timeline now.
Old 07-01-2014, 09:23 AM   #994
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Originally Posted by T.J. MCCAULEY View Post
Nice work bud!
Thanks TJ.
Old 07-01-2014, 09:33 AM   #995
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Started the Captainfab hydraulic clutch / brake master conversion. Got the firewall plate undercoated, plate installed and mounted up. Just need to bore out the 1 1/2" access hole for the clutch mc. I did notch the plate so I can access the center bolt on the steering column outer clamp. Will get the rest installed after engine in this weekend. No sense risking damage to a couple of new master cylinders if I don't have to.
Thanks to Captainfab for a great product and had no fitment issues!!!!
Old 07-01-2014, 09:34 AM   #996
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Still trying to decide if I want to grind off the old 3 speed shift mechs from the lower column.....part of me says leave them so if I ever want to go back to a column shift I can......
Old 07-01-2014, 09:36 AM   #997
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Couple of pics of the floor. The rust issues are obvious, but not bad. I have definitely seen worse, but that's what I bought a welder for.
Old 07-01-2014, 09:47 AM   #998
WhippinSaw
WhippinSaw's Avatar
Re: 1963 C-10 in NC
Thanks for the nice write up on the closing panels, I plan on doing mine this winter. The rust should be no problem, like you said "I have definitely seen worse" its also a good place to start with the new welder, on the floor under the mat, keep up the good work and keep the pictures coming, I also need to do a drivers side rocker
Old 07-01-2014, 09:54 AM   #999
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
No problem on the write up. Gives me something to do in between dry times. Also working on a write up on the other build for the conversion from manual vent to cable pull vents. A great upgrade that's not bad at all.
I agree on the welding. I have to admit, its been 15 years since I had to even turn a welder on, but I'll get back into it. I'd also rather start on the floor pans since they'll likely never be seen. I think I'll go with the full length inner rocker that has the cab corner floor on it. The tops of the inner rockers are good, but the bottom back sides are shot. It's all going to need to be cut out for floor pans and cab supports anyways. A lot of it will come from the 61 donar cab, but some of the lines that won't match up I'll order from Top Banana. I'd rather let someone who can use the OEM 61 cab floor parts on a 60-62 cab so their metal will line up. But I can use the outer rocker, maybe the inner and the cab corners.
Old 07-01-2014, 10:28 AM   #1000
TheBlueBomber
TheBlueBomber's Avatar
Re: 1963 C-10 in NC
Let me know. I'm on orders down here so one night when I get off or sometime before I go home this weekend I can come over and help.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
