Old 11-19-2016, 08:14 AM   #976
Re: A 15 year old's project. Rusty 62 stepside
Old 11-19-2016, 08:58 AM   #977
Advanced Design
Advanced Design's Avatar
Originally Posted by 62stepside longbox View Post
I welded a nut on to the diff cover and put a short bolt through it with an o ring for making oil filling much easier.
I agree too, this is clever. Never seen it done before...thanks for the share!
Advanced Design is offline   Reply With Quote
Old 11-19-2016, 12:09 PM   #978
TJ's Chevy
TJ's Chevy's Avatar
Time to go into business. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-19-2016, 06:47 PM   #979
62stepside longbox
62stepside longbox's Avatar
Originally Posted by Grizz1963 View Post
Clever Clever.
Yes, thanks rian
Thanks Doug, just a little something I thought up.
Maybe I'll have to see about that lol
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 11-23-2016, 01:29 AM   #980
62stepside longbox
Still making decent progress here, just not many pictures. Just today I installed a new pinion seal.
Old 11-24-2016, 11:32 AM   #981
AJCK87
Beauty Nik! Keep plugging away at her.
AJCK87 is offline   Reply With Quote
Old 11-24-2016, 02:27 PM   #982
Burnouts be coming soon!
Old 11-24-2016, 10:14 PM   #983
62stepside longbox
Thanks Anthony
Oh yeah, I just might have to do them on a wet wooden bridge since I only have the six
Just the other day I purchased some hubcaps from a good friend in comox bc, I believe they are 67-69 camaro/Nova/Chevelle. They should be arriving in the mail soon.
Old 11-24-2016, 10:59 PM   #984
rusty76
rusty76's Avatar
Great job on the truck. Things are looking nice.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 11-29-2016, 08:34 PM   #985
62stepside longbox
Thanks rusty.
Today at school I used the metal lathe to make some pieces for my hydraulic clutch linkage. I turned down some roundstock and used my tap and die set to thread them. The threaded hole on this piece attaches to the clutch master cylinder and the threaded stick-out part threads into the rod end. The lock nut is to make adjustments and tighten it so it won't come out of adjustment
Old 11-29-2016, 08:38 PM   #986
62stepside longbox
And the top piece here is threaded all the way through and attaches to the pedal and pivots on the rod end
Old 11-29-2016, 08:43 PM   #987
62stepside longbox
And here it is together
Old 11-29-2016, 08:44 PM   #988
62stepside longbox
I then installed the clutch master cylinder for the final time
Old 11-29-2016, 08:50 PM   #989
62stepside longbox
Here is the linkage all Hooked up and adjusted
Old 11-29-2016, 08:57 PM   #990
62stepside longbox
While I was doing this I decided to adjust the clutch pedal to a height that I like, it's about inline with the brake pedal (The angle of the picture makes it look out of line). I still need to add a pedal stop pad to prevent the master cylinder from bottoming out and also add a clutch return spring.
Old 11-30-2016, 01:42 PM   #991
65sub
65sub's Avatar
As usual Nik, very nice work. Good looking hub caps too
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 11-30-2016, 03:27 PM   #992
scoot_mcgrute
That T5 will make awesome 6 banger burnouts! This was on wet pavement but it does it just as easy on dry
https://www.youtube.com/watch?v=VynJxi-w8AM
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 11-30-2016, 10:41 PM   #993
Advanced Design
Nice machine work! Sure beats buying a part.
Old 12-01-2016, 12:08 AM   #994
TJ's Chevy
TJ's Chevy's Avatar
Good job bud.
Old 12-02-2016, 12:47 AM   #995
62stepside longbox
Thanks Dale, and the hubcaps were only $40!
Thanks Scott, that's awesome, can't wait until the spring or summer when I have it up and running!
Thanks Doug, I couldn't agree more.
Good job bud.
Thanks tj😀
Old 12-04-2016, 08:56 PM   #996
62stepside longbox
On Friday I finally got the rear end all finished and buttoned up and I brought it home from the school shop. All it needs is a little paint on the cover and the adjusters to be set correctly
Old 12-04-2016, 09:21 PM   #997
62stepside longbox
And today I did some drilling on the frame and got the power steering box mocked up with the adaptor plate
Old 12-04-2016, 09:23 PM   #998
62stepside longbox
Another pic
Old 12-04-2016, 09:26 PM   #999
62stepside longbox
And a close up of where I had to redrill the box so that all of the holes lined up with the frame. Now all I need to do is weld the boxed portion of the frame back in place and buy some longer bolts
Old 12-07-2016, 11:17 AM   #1000
66ChevyMax
66ChevyMax's Avatar
Great work on the clutch hook-up
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
