Old 06-29-2015, 09:29 AM   #1001
Kim57
Kim57's Avatar
Re: Lurker OrrieG Progress Pics
Nice job on the install.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-29-2015, 07:07 PM   #1002
OrrieG
OrrieG's Avatar
Originally Posted by Nut Case View Post
OrreG Maybe a small triangle gusset could be welded to the spacer only might give it more strength, just a thought. Great work you have provided lots of good information. Thanks NC
I will keep that in mind if I ever have problems.
Originally Posted by solidaxel View Post
When I changed compressors from R 12 to R 134 I was told to change the oil in the compressor.
I like your hard lines from the condenser to the evap
I read that I could have swapped out the oil, but with all the other issues decided to just get the correct compressor. Hard lines are VA. I did all the hoses using a Mastercool crimper.
OrrieG is offline   Reply With Quote
Old 07-04-2015, 03:22 PM   #1003
OrrieG
OrrieG's Avatar
Back and corner panels upholstered and installed. Have a few wrinkles because of extreme changes in angle and curvature, will try steaming it later, but no biggie they are on the bottom of the speaker bump and the seats will hide them most of the time. Got some nuclear grade headliner adhesive from local hot rod upholstery shop, works great. All hidden fasteners except for three along the bottom of the back panel. Now I just need to find some nice fishing rod holders.
Old 07-04-2015, 05:35 PM   #1004
Kim57
Kim57's Avatar
Looks real nice.
Kim
My build thread
Old 07-04-2015, 07:03 PM   #1005
Advanced Design
Advanced Design's Avatar
Originally Posted by Kim57 View Post
Looks real nice.
Kim
X2...nice work!
Advanced Design is offline   Reply With Quote
Old 07-05-2015, 12:02 AM   #1006
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Very nice! I plan on using that bubble insulation stuff on my trucks as well.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 07-05-2015, 09:41 AM   #1007
oldman3
oldman3's Avatar
OrrieG, nice job on the back panel and corners, material looks great...Jim
oldman3 is offline   Reply With Quote
Old 07-05-2015, 07:56 PM   #1008
dyno
dyno's Avatar
Originally Posted by OrrieG View Post
Worked some today, installed the shift bezel. The 82 Eldo shift used a cable to move the indicator in the bezel. I got an original 64 Chevelle unit with repop graphics to work with the TH350. Need to touch up the paint and add the pointer. Did I mention its a bit warm?? Garage was only 90...
No joke on the thermometer! Kicking myself for deciding not to put A/C in my truck! At least we have a little reprieve today in the temps.
Make any progress on the steering mod?
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 07-06-2015, 02:14 AM   #1009
Dan in Pasadena
Dan in Pasadena's Avatar
Looks great Orrie, but I've gotta ask, what are the three big openings for? How is it that they can't be seen after the material is on there? Is it just that the material is stretched tightly?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 07-06-2015, 05:42 PM   #1010
OrrieG
OrrieG's Avatar
Material is mounted to a piece of 3/16" plywood with up angled wood blocks that match down angled blocks on back of frame. PW slip up so angles are engaged to pull it tight at top, screws hold it tight at bottom. Corners have pieces that slip behind the center frame and are screwed to tie all together. I did the sub frame to have something to screw to for rod holders, possible future storage box, etc.
Old 07-06-2015, 05:59 PM   #1011
OrrieG
OrrieG's Avatar
modified the pitman arm to move two splines towards frame. Shortened the drag link to get minimum length. Picked up a lot more rotation but still about 1/4" off of the spindle bump stop with 215R75-16 tires. If I can find some 205R85-16 I can maintain the diameter I want and they should clear. The guy that did the modification originally is running 84ish axles and they cleared with 235r75-16 tires so geometry of the axle must be a little different.
Old 07-06-2015, 06:37 PM   #1012
_Ogre
_Ogre's Avatar
nice speaker pods and back panel orrieg
shop air compressor timer
Old 07-06-2015, 08:45 PM   #1013
OrrieG
OrrieG's Avatar
Thanks I learned a lot from your fiberglass work thread. Like the old timer told me never put on more filler in the morning than you can remove in the afternoon!
Old 07-07-2015, 10:52 AM   #1014
_Ogre
_Ogre's Avatar
i learned that paint grade vs vinyl or cloth is a world of difference
paint grade means hours of hand sanding and filling
vinyl/cloth is 1 coat, power sand and cover... easy peasy
Old 07-07-2015, 03:27 PM   #1015
OrrieG
OrrieG's Avatar
Exactly, fabric over foam hides a lot. Or you can spend a lot of time on making molds and gelcoat/glas too!
Old 07-09-2015, 11:22 PM   #1016
OrrieG
OrrieG's Avatar
Did the head liner. 1/8" masonite with 3/8" upholstery foam and fabric. Cut the masonite 5/8" larger than open on front, back and one side; 1/4" on other side and back about 3" on front and back. That is what lets you get one front corner in, then work around to the back and across. Then slid it back to center. Held the foam back about 3/4" and bevel cut the edge. Tight fit but with Ms. Joan's assistance got it wrestled into place. Hint: nitrile gloves help a lot in sliding it for fine tuning once it is wedged into the space. Just need to install the split trim (door protectiong edging), it is buried in one of the part boxes.
Old 07-10-2015, 03:35 AM   #1017
Daze57
Daze57's Avatar
great job!!!
Daze57 is offline   Reply With Quote
Old 07-10-2015, 09:33 AM   #1018
oldman3
oldman3's Avatar
Looks super, nice job...Jim Tell Ms. Joan she does nice work...Jim
Old 07-10-2015, 09:54 AM   #1019
Kim57
Kim57's Avatar
Looks great.
Kim
My build thread
Old 07-10-2015, 10:06 PM   #1020
OrrieG
OrrieG's Avatar
Door Panels. The stock raised metal accent will be metallic black to match the steering wheel , knobs and ac grille. Rest of panel will be silver birch to match the rest of interior. Arm rest is grey matching the seat leather, door handles stock chrome and black knobs.
Old 07-20-2015, 12:16 AM   #1021
OrrieG
OrrieG's Avatar
Put some elbow grease into an old school back up light I got yesterday at a swap meet for $8. I wanted something that looked correct for the 50's. Allstate Brand, glass lense and good 50's American chrome came back with a little polishing. Cleaned up the electrical, rewired and works great. Just need to find a brighter bulb. Not shown is the rest of the bracket and mounting bolt. It will mount next to the license plate.
Also finished insulating the cab floor. You can also see one of the carpet templates, getting close to having the interior wrapped up.
Old 07-20-2015, 09:53 AM   #1022
Kim57
Kim57's Avatar
Nice light.
Kim
My build thread
Old 07-22-2015, 12:17 AM   #1023
OrrieG
OrrieG's Avatar
Working on the carpet fitting. made a template but found it only worked to identify problem areas. Cut is wide and lined up the part across the brace and taped it. Then started on the passenger side add slowly nipped and tucked around the speaker pod, AC, and shifter. Wanted to see if it would lay over the hump, it does not, which is ok. Then fit around the gas pedal, steering column cover and speaker pod on other side. Will trim the step sides last. Also decided to make a panel to put in front of the fuse panel to hide the wiring and brake cable.
Old 07-22-2015, 09:51 AM   #1024
Kim57
Kim57's Avatar
Nice color on the carpet.
Kim
My build thread
Old 07-22-2015, 12:19 PM   #1025
OrrieG
OrrieG's Avatar
Yes it is a heavy duty commercial tight loop with built in soil release, etc. so it will be easy to clean. Better than the orange outdoor foam backed stuff I had in there before!
