Closed Thread
Old 07-10-2014, 09:55 AM   #1001
pimpston65
pimpston65's Avatar
Re: What did you do to your truck today part II.
Originally Posted by 1963c-10 View Post
I took some pics this a.m. and once they upload I'll get them on my build thread for you.
Edit.....pics loaded Pimpston65
thks so much i will be lookin for em, hey do you have an old working ebrake handle? my spring broke and need a replacement or should i just post in the sell section? mine is chrome i just need the spring
pimpston65 is offline
Old 07-10-2014, 04:53 PM   #1002
Ronw435
Ronw435's Avatar
Well made a note to myself. Don't try to replace the front springs with only the frame to help. Removed the old broken spring with out a hitch. Put the front of the frame on jack stands. Put jack under the A-frame. Pushed out the bottom ball joint. Slowly let the jack down and took out the broken spring. Tried using Autozones spring compressor, it worked ok but after getting the ball joint back in I could not get the jaws of the spring compressor out. I tried about everything I could think of, prying the spring open to allow the unit to come out the bottom. No luck. Tried to un-hook the top but could not get it into the straight configuration to let it drop out the bottom. After a couple hours I decided to drop the A-frame and remove the spring and get the D--m compressor out. Now out I thought I could just jack the A-frame back up and connect the ball joint. NOT!!!! The whole frame would lift up before it would even get close to being allowed to put the nut back on. Live and learn. So I am going to now try and put the motor, trans, and drive shaft back in, in hopes that it will be enough weight to keep the frame from lifting off again. And we have said that this is fun???? LMAO.
Ronw435 is offline
Old 07-10-2014, 06:47 PM   #1003
forestb
forestb's Avatar
Don't do all of that just to get the increased weight. There is a thread on hear on how to do that. Maybe some one else will chime in. I remember that there were plenty of alternatives.
forestb is offline
Old 07-10-2014, 07:07 PM   #1004
BADAZ chevy guy
BADAZ chevy guy's Avatar
I saw a similar situation once. Squeeze the springs down and hold them in place with zip ties (A LOT OF ZIP TIES) around 3 coils. Believe it or not, enough zip ties will hold it. Once you have the ball joints in place start cutting the ties one at a time.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline
Old 07-10-2014, 07:30 PM   #1005
La Zona Imagery
my new plates just came in
1965 Chevy C-10 350 V8
2003 GMC Sierra Crew Cab 6.0L 4x4
La Zona Imagery is offline
Old 07-10-2014, 09:21 PM   #1006
robber grin
^^^ Very SHARP truck! ^^^
Been busy flipping the bed wood mounting flanges, laying the bedwood all out, marking, drilling, and sanding... even finally got some clear on it.
Domino seems to dig it.
robber grin is offline
Old 07-11-2014, 04:57 PM   #1007
Ronw435
Ronw435's Avatar
Well I want to thank you all for the information. Not sure who it was but someone said to put a chain around the A-frames and Jack. I didn't have a chain so I used a 2" ratchet strap and it worked like a dream. Both springs in and painting the frame tomorrow.
Thanks again for all the great information everyone gives in these forums.
Ronw435 is offline
Old 07-11-2014, 05:49 PM   #1008
Grizz1963
Grizz1963's Avatar
Carried a load, including a replica coffin to town, then went bowling, and had a great dinner afterwards with Nicola.
Also helped her set up the front of the shop for their WW1 Commemoration, using the replica coffin I had built recently.
Took the box down to the shop this afternoon after work and helped Nicola do the basic set up.
Some fine tuning to be done.
Outside view..... (yes, the building needs a load o attention)
Size of display is limited by the size of the building and reception area.
Sister in Law Margaret sat and crocheted 60 poppies as well to help with the decoration.
Some finer details to be added, but I am pleased and impressed with how it has turned out.
I suspect some of the branches will not make the same effort, and wait to see what others have done.
"LEST WE FORGET"
Thank you to everyone who commented and helped with advice and additions to the display.
Unfortunately, barbed wire and other "dangerous" objects were banned, in case someone hurts themselves.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 07-12-2014, 01:03 PM   #1009
robber grin
Sanded runs from the first coat of polyurethane, scuffed and painted the sills, then gave everything another coat of poly...
truck bed floors are a project in a project!
Old 07-12-2014, 06:31 PM   #1010
rcg66
rcg66's Avatar
Not really what I did to my truck today, but I took it to my first cruise-in. It was 12 miles from home and truck ran really well. I had it inspected this week and it passed without any problems. I have looked forward to this for a long time, and was really pleased with how it ran.
rcg66 is offline
Old 07-12-2014, 07:52 PM   #1011
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Nice day, so I took it to Les Schwab to get the inside of the tires flipped to the outside.
The previous owner loaded the truck up too much and put some pretty rough scratches in the tires.
Also the inside of the tires still looked almost brand new.
66 C20 Service Truck:
LostMy65 is offline
Old 07-12-2014, 08:12 PM   #1012
siggyfreud
siggyfreud's Avatar
Looks good. I think I know right where that's at. Used to live in the OC up until about a year ago.
siggyfreud is offline
Old 07-12-2014, 08:18 PM   #1013
LostMy65
LostMy65's Avatar
A boy there around 7 or 8 said excitingly to his daddy;
"Look at that cool old truck, daddy!"
LostMy65 is offline
Old 07-12-2014, 09:39 PM   #1014
markeb01
Senior Enthusiast
markeb01's Avatar
That's a great shot!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 07-12-2014, 10:08 PM   #1015
LostMy65
LostMy65's Avatar
Thank you, Mark!
LostMy65 is offline
Old 07-12-2014, 10:12 PM   #1016
Dillon Rock
Nice shot x2! Lookin good 65. Glad a little fella like him likes these ol' rigs.
That's the thing about a Chevrolet, no matter how they look, whether it be a trailer queen or a good ol' used farm truck, no other truck on the road will always look that damn good wearing a Bowtie.
Dillon Rock is offline
Old 07-14-2014, 08:56 AM   #1017
Improbcat
Improbcat's Avatar
Took the passenger bedside from this:
To this:
Then to this:
The silver is MasterSeries anti-rust paint. Much like POR-15 but less finicky about what you apply it over.
The fill & sand of the grille support & GMC grille also continue.
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures)
SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD
Improbcat is offline
Old 07-14-2014, 01:58 PM   #1018
markeb01
Senior Enthusiast
markeb01's Avatar
Very nice!
markeb01 is offline
Old 07-14-2014, 05:12 PM   #1019
Ronw435
Ronw435's Avatar
Well finally have a painted rolling chassis. Set it out in the Texas sun today. Who needs an oven when you have Texas..........lol.
Ronw435 is offline
Old 07-14-2014, 05:56 PM   #1020
schpeen
schpeen's Avatar
Thumbs up Re: What did you do to your truck today part II.
sweeet
schpeen is offline
Old 07-14-2014, 06:22 PM   #1021
pimpston65
pimpston65's Avatar
its a shame we cover those awesomely painted frames with the body, but at least we know they are a thing of beauty!!!
Old 07-14-2014, 06:36 PM   #1022
BADAZ chevy guy
You do have an oven... a Texas sized oven. lol
Old 07-15-2014, 07:48 AM   #1023
Ronw435
Ronw435's Avatar
Yes that is true, I love Texas but the summers can be a bit tough. The truck is going to be my daily driver, well sort of, I have recently retired so it will not be driven daily, but will be my driver when ever I need to go somewhere. I checked the surface temp today after being in the sun for about 45 minutes. My gun said 132 degrees!! And it was only 100 degrees today outside.
Ronw435 is offline
Old 07-15-2014, 09:23 AM   #1024
1963c-10
1963c-10's Avatar
Nice job on the frame....came out great!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline
Old 07-15-2014, 10:40 AM   #1025
Ronw435
Ronw435's Avatar
Thanks 1963c-10. Lots more to do. Taking it day by day. If the heat would go away I could make more progress....lol. I turn into a puddle in the heat. Hardest thing in painting frame was keeping from dripping sweat on the new paint......lol.
Ronw435 is offline
Closed Thread
