Old 06-29-2020, 03:55 AM   #1001
J Williams
J Williams's Avatar
Well day 4 of my 14 day quarantine..... started out hooking up the rest of the wiring under the dash, installed glove box and heater switches. I don’t know if any of you have or had an issue with your heater valve at your heater core froze up with rust... but mine was and bad!
Looked all over on the internet and found a guy who rebuilds them. He wanted 119$ plus shipping. Not a bad price but I decided to give it a shot. Put it in a paint mixing jar and let it soak for several hours pulling it out every once in a while to run a tiny brush through every crevice I could.
After soaking and a little PB blaster it moved again. It was hanging up and I noticed an adjustment screw so I adjusted it. Works great now! Man it feels good when you run into an issue like that and you find a fix without spending $’s!
Then I started welding 12 bolt holes on the passenger door from Grandpa’s mirrors gone wild days! Then started to put some body filler on. Got some work still on the door but it’s starting to look good.
J Williams is offline   Reply With Quote
Old 07-02-2020, 10:02 PM   #1002
EricU
Re: What did you do to your truck today part IV
Still collecting parts for my '63 Burb build.
But I did get my 17s 5x5 rims drilled with clips installed. I then prepped and painted them body color in my "Pig Barn Shop"
I will eventually be running 3" wide whites but since I am not completely sure of the final tire size I bought some cheap rollers online and had my local shop mount them to the painted wheels.
Sent by the random thoughts from the voices in my head...
EricU is offline   Reply With Quote
Old 07-02-2020, 11:25 PM   #1003
forestb
forestb's Avatar
Those look nice. I just got my rally wheels power coated white and can’t wait to see how they look on the truck. I would love to know when you get the white walls where you get them from. I have had a hard time finding white walls for a 17” wheel.
forestb is offline   Reply With Quote
Old 07-02-2020, 11:32 PM   #1004
EricU
Originally Posted by forestb View Post
...I would love to know when you get the white walls where you get them from. I have had a hard time finding white walls for a 17” wheel.
That part is easy, easy, easy - just get out your credit card and call Diamond Back Tires. Great folks to deal with.
Download and scroll through their catalog - but definitely either call them or send an email before making any purchase as they can help out with items that don't show in the catalog.
I used them for my Caddy build
Old 07-03-2020, 12:51 AM   #1005
forestb
forestb's Avatar
Are they the ones that can make custom tires? More than I want to spend on something that I will probably run into a curb. I probably need curb finders. Vary nice cady by the way
Old 07-03-2020, 02:17 PM   #1006
EricU
Are they the ones that can make custom tires? More than I want to spend on something that I will probably run into a curb...
They don't make tires, they use other manufacture's tires then add the whitewall by vulcanizing them on.
Old 07-03-2020, 02:24 PM   #1007
forestb
forestb's Avatar
Okay thanks I will look into it
Old 07-03-2020, 08:07 PM   #1008
Robert Haas
Lots of body filler got swept up today
My arms and shoulders feel like I may be unable to brush my teeth tonight.
Our 1965 GMC big block pro mod build http://67-72chevytrucks.com/vboard/s...d.php?t=746098
Robert Haas is offline   Reply With Quote
Old 07-04-2020, 12:06 AM   #1009
forestb
forestb's Avatar
Wow I love that color. Is it a semigloss.
Old 07-04-2020, 12:59 PM   #1010
EricU
Attachment 2029907
Attachment 2029908
Attachment 2029909
Attachment 2029910
Where's the "Like" button? Beautiful!
Old 08-01-2020, 07:23 PM   #1011
forestb
forestb's Avatar
I got my wheels back from power coating and installed.
Old 08-01-2020, 07:40 PM   #1012
jbgroby
jbgroby's Avatar
Celebrating because we set a land speed record in the truck after the trans swap to the 700R. 82 mph, 1750 rpm Dana 44 with 3.23
, no parts fell off! Rocky Patel Vintage 1999 Connecticut.
jbgroby is offline   Reply With Quote
Old 08-01-2020, 08:43 PM   #1013
forestb
forestb's Avatar
What class are you running in?
Old 08-01-2020, 09:08 PM   #1014
jbgroby
jbgroby's Avatar
That for me Forest? No class except stock really.
Old 08-01-2020, 09:19 PM   #1015
forestb
forestb's Avatar
Yes it was. Thanks
Old 08-29-2020, 06:59 PM   #1016
forestb
forestb's Avatar
Got my wheels sorted out.
Old 08-29-2020, 11:29 PM   #1017
J Williams
J Williams's Avatar
Got my grill painted and put together with new halogen headlights and new bezels. Got the radiator painted and installed... well set in
63 C10
Old 08-31-2020, 01:24 PM   #1018
goatless
goatless's Avatar
Painted the track bar.
1964 C10 LWB->SWB, 283->454, SM420->200-4R
MECHANIC: "ME"
goatless is offline   Reply With Quote
Old 08-31-2020, 06:29 PM   #1019
AcampoDave
AcampoDave's Avatar
Made an ashtray pull out of an Exato knife handle
AcampoDave is offline   Reply With Quote
Old 08-31-2020, 07:11 PM   #1020
roll_the_dice
roll_the_dice's Avatar
I like the look of that Dave! Good job!
roll_the_dice is offline   Reply With Quote
Old 08-31-2020, 07:34 PM   #1021
AcampoDave
AcampoDave's Avatar
Thanks Dice Roller, my stock one sagged in the middle.
Old 08-31-2020, 09:42 PM   #1022
Johns 66
Johns 66's Avatar
That looks really cool
Former Decorated Combat Marine...Semper Fi!!
Instagram jorourke322
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699
2019 GMC AT4
Johns 66 is offline   Reply With Quote
Old 09-05-2020, 11:21 PM   #1023
'63GENIII
'63GENIII's Avatar
Finally got the Bronco Washer / Radiator overflow installed and working. Not my idea. Got it from someone here on the forum. Works great though..
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 09-05-2020, 11:34 PM   #1024
'63GENIII
'63GENIII's Avatar
A few weeks ago, I was getting ready for a camping trip that we went on and decided that I wanted to get a few things done to make the trip a little better for us. I started with the radiator overflow - washer reservoir.
Next up was the cable operated kick panel vents that had been under my house for at least a few years. Thanks Michael Bustamante!
Chris
'63 k15 long step
Old 09-05-2020, 11:48 PM   #1025
'63GENIII
'63GENIII's Avatar
Next up was the Warn steps. As we've gotten older, the wife hasn't felt like jumping up into the truck like she used to. Bad knees. I wanted to make it a little easier for her (and me ) to get in to the truck but wanted a lower profile step.
I had a set of these on a crew cab years ago and really liked them. Well built, rubber coated and stamped with the Warn logo. Well, I went to try and find them only to find out that Warn hadn't made them for a number of years at that point. Ended up finding a set on EB and snatched them up. They give the right amount of drop for us yet aren't hanging too low..
Passenger rocker is solid too. Had to add the drivers side rocker to my list. One step forward and 2 - 1/2 back. Oh well. The steps work great!
Chris
'63 k15 long step
