Old 07-28-2012, 10:24 AM   #1026
mknittle
mknittle's Avatar
Re: Finally starting my Longhorn 4x4 conversion
Originally Posted by Dieselwrencher View Post
How far back did you find that post? That had to be atleast 2-3 years back I posted that.
It came up when I clicked on the last page. I didn't look at the date
And I thought the computer was smarter than I am! Looks like it's a tie
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 07-28-2012, 10:42 AM   #1027
Str8-6-68
Str8-6-68's Avatar
you had me sweating there when i first read you were planning on starting over with the longhorn idea. I'm happy to hear that was just a previous idea before this masterpiece happened. good luck on the final touches, keep the pics coming!
12ram3500 HS mm, FP 5" tbe, SB cai, 2.5" up, 35s on 20s. SOLD 02ram2500 twin turbo, built 47re, sticks & studs : SIKDZL -youtube.
68gmc1500 soon to be: shortbox, ppumped 24valve, s467.7, dap 300s, H2O/Air intecooled, meth controlled, 47re, 14bolt, 2wd.
Str8-6-68 is offline   Reply With Quote
Old 07-31-2012, 07:13 PM   #1028
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
No, the cab isn't coming off the frame on this truck again for a long time. (If I do a crew cab)
No new progress on this thing. But the headliner did fall half down and I tore it as I ripped it the rest of the way off. Stupid POS. I'll be getting a new one now.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-05-2012, 11:12 PM   #1029
Dieselwrencher
Here's some progress guys! I got the RH frame rail support made, I smoothed out where I had to clearance the frame for the primary turbo, and got the front portion of the frame ready for paint. Then I painted it with POR-15 gloss black.
I also got my shipment from DIY4X which had my RH spring mount for the D60. I put it on, but have to heli-coil the housing as one hole is stripped out.
Ryan
Old 08-05-2012, 11:50 PM   #1030
sparks427
sparks427's Avatar
shes deffinetly comin along! lookin good buddy.
Adam-
sparks427 is offline   Reply With Quote
Old 08-05-2012, 11:56 PM   #1031
Dieselwrencher
Thanks Adam!
Ryan
Old 08-06-2012, 10:18 PM   #1032
mknittle
mknittle's Avatar
looks great man!
this reminds me of a guy I used to work for we built scintific testing machines and Jim the )owner of the companyband smartest man I have ever known)Would pulling parts off machines and redesigning them as fast as the guys were assembeling the machines.
Mark
My GMC build.
Old 08-06-2012, 10:21 PM   #1033
mknittle
mknittle's Avatar
Do you figure you will be able to drive it this fall? it sure will be worth all the time!
Mark
My GMC build.
Old 08-06-2012, 10:27 PM   #1034
Dieselwrencher
I'm hoping too. I'm taking it to the All Truck Nats in KC September 7th so it will help if I can drive it. It gets old pushing them around.
Ryan
Old 08-06-2012, 10:28 PM   #1035
Dieselwrencher
looks great man!
Thanks. I was really worried how that was going to turn out, and it turned out pretty nice. I doubt it will break either.
Ryan
Old 08-06-2012, 10:31 PM   #1036
ryanroo
ryanroo's Avatar
what did you do exactly? looks like you fab'ed a "bulge" piece and cut out the existing frame rail? hard to tell with all that shiny black paint and the camera angles
either way, looks better than a decimated flange on the stock rail and a lot stronger
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 08-08-2012, 01:59 AM   #1037
Dieselwrencher
Ryan
Well after doing the steering box bracing on the 88 burb, I had an idea. I just basically put a plate on the out side of the frame, one on top and one on the bottom. This is almost like a sleeve around the stock frame. It added more lip to the areas where I cut out. I welded it all on and included the front cross member in to it via 2 bolt holes. The brace goes past the engine cross member area, so it should be stout.
Ryan
Old 08-08-2012, 08:02 AM   #1038
ryanroo
ryanroo's Avatar
oh, i see better now. it sure looks like beef. i got all confused by the plate that the front crossmember bolts in with. made me think you had completely cut the stock rail.
ryan
72 K20 12v build
Old 08-09-2012, 04:08 PM   #1039
superduty_59
Dieselwrencher, I've read this whole thread. It took me 5 days at work (mobile generator tech)to read it all. Very nice work.
superduty_59 is offline   Reply With Quote
Old 08-09-2012, 04:12 PM   #1040
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress Ryan! Keep at it buddy.
mcbassin is offline   Reply With Quote
Old 08-10-2012, 05:31 PM   #1041
fakerwade
fakerwade's Avatar
X2,,,Your frame mod looks excellent Ryan.
Wade
JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!!
Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570
Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro
fakerwade is offline   Reply With Quote
Old 08-10-2012, 05:50 PM   #1042
Dieselwrencher
Thanks guys. I have made some good progress on it lately. I am having issues getting my pics loaded though. The engine is setting back in the frame all painted up and I'm getting parts off the floor finally! The only hick up I'm going to have is my lower water inlet. After the frame rail reinforcement, now the radiator hose will rub on the frame. So I'm going to have to come up with a fix for that.
Here are the oil feed lines for the turbos.
Here is the KDP installed.
I got a lot more done than this. When I get the pics up, I'll post them.
Ryan
Old 08-10-2012, 08:32 PM   #1043
Str8-6-68
Str8-6-68's Avatar
ooh very nice progress Ryan, Is the 5.9 a ppumped 24valve? whenever I follow your posts I feel like my project is soo very far from the light at the end of the long tunnel lol. good job man.
Old 08-10-2012, 10:12 PM   #1044
Dieselwrencher
Yes, it's a 98 or 99 24v with an industrial 190hp p pump. I'm going to time it to 25*, it will have 7x.012 injectors, and some afc tuning with a ground plate. The injection pump also has 4k gsk's in it and I might put some bigger delivery valves in it. We'll see how it fuels at first.
Don't feel bad about your project............... This one is a long time in the making.
Ryan
Old 08-10-2012, 11:01 PM   #1045
ryanroo
ryanroo's Avatar
cant wait for more pics. i am jealous of your progress. i cant wait to see a video of it making bad air.
i looked at a really strait replacement bed for mine tonight. i have to fly out towards you tomorrow and drive back to CO, so hopefully in the next few weekends i can get that home and sat on the frame.
Ryan
72 K20 12v build
Old 08-11-2012, 10:37 AM   #1046
mknittle
mknittle's Avatar
I am having problems loading pictures too. they seem to load then evaporate.
Mark
My GMC build.
Old 08-11-2012, 11:06 AM   #1047
Dieselwrencher
Ryan
If you get close and have time, let me know. Maybe we can meet up.
Ryan
Old 08-11-2012, 11:08 AM   #1048
Dieselwrencher
Mine just don't want to load. I'm pretty sure the issue is photobucket, but can't get through to any customer service peeps.
Ryan
Old 08-11-2012, 12:02 PM   #1049
Dieselwrencher
Ok, getting some pics to upload finally! Here is another oil feed line shot. I also got the oil returns ran for the turbos too.
Here is the wear sleeve installed for the front seal. If you ever have to replace your front seal and your crank has any scores or bad wear on it, this is the seal you need to install to ensure it won't leak again. I also installed my new valve springs, but didn't take pics of that.
Painted the engine gloss black.
Got my billet tappet cover installed along with my billet freeze plugs.
Got the engine sat back in the truck, and got one hydraboost line on. Last night I got all new lines for the power steering system. Today I'll see if they fit.
I should have more progress to report tonight. I'm going to get the clutch in, install the trans, and get the trans cross member finished. I'd like to plumb it and try to start it tomorrow. We'll see.
Ryan
Old 08-11-2012, 12:29 PM   #1050
JPalmer81
JPalmer81's Avatar
You are doing some great work man, that is going to be a beast!
1988 Chevy Crew Cab 1ton 4x4 SRW LWB
1977 Dodge 1 ton 4x4
My Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=516872
"The price of Freedom is Eternal Vigilance"
JPalmer81 is offline   Reply With Quote
