Old 09-19-2012, 09:57 PM   #1026
Midgets50
Midgets50's Avatar
Re: How about some pics of 47-59
yep yep. i was gonna put it on an s10. actually i got this far on the s10 swap before i did some research and bigger tires wouldnt really work all that well with a stock 4.3. much happier with the k2500 swap instead
Midgets50 is offline   Reply With Quote
Old 09-20-2012, 12:05 AM   #1027
mud.man.rj
mud.man.rj's Avatar
Ya the 4.3 would need too much spent on it to be useful with big tires, that's why i run a big block almost in everything. Torque rules.
mud.man.rj is offline   Reply With Quote
Old 09-20-2012, 09:38 AM   #1028
mknittle
mknittle's Avatar
i am going to use a cummins in my72 when I get to it. for the same reason.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-20-2012, 10:16 AM   #1029
Midgets50
Midgets50's Avatar
i would love to put a cummins in under the hood of this. Friend of mine has a 12 valve 1 ton that he gets around 25mpg with. the bad part is i cant find a cummins for less than what ive put into my whole truck
Old 09-20-2012, 10:41 AM   #1030
mknittle
mknittle's Avatar
A bt6 is pretty long But a bt4 would fit. there tons of them in old bread trucks with the gm bellhousing.
Mark
My GMC build.
Old 09-20-2012, 10:43 AM   #1031
mknittle
mknittle's Avatar
anyway that is going to be a beast!
Mark
My GMC build.
Old 09-20-2012, 12:34 PM   #1032
Midgets50
Midgets50's Avatar
Old 09-20-2012, 02:00 PM   #1033
Midgets50
Midgets50's Avatar
they should have the torque but will those 4bt engines have the power push 35's to go 60+
Old 09-20-2012, 09:31 PM   #1034
mknittle
mknittle's Avatar
I haven't looked into them much but here is a good place to find some info.
http://www.4btswaps.com/forum/forum.php
Mark
My GMC build.
Old 09-20-2012, 10:14 PM   #1035
BlueJeep
BlueJeep's Avatar
Yes, easy. A good friend of mine has a Jeep on 38's with a 4bt and 5 speed who pulls a decent size camper around on the interstate getting around 20mpg.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 09-21-2012, 10:33 AM   #1036
mknittle
mknittle's Avatar
Thanks bluejeep, I am more familar with the 6 I know quite a few performance parts interchange. There are guys putting over 1000 hp to the ground with the 6bt and driving it home with close to 20mpg.
I know this has nothing to do with it but it is fun to watch.
http://www.youtube.com/watch?NR=1&v=...ture=endscreen
Mark
My GMC build.
Old 09-21-2012, 10:58 AM   #1037
Midgets50
Midgets50's Avatar
If only Duramaxs got better mileage. i would love to run one with the Allison transmissions
Old 09-21-2012, 09:21 PM   #1038
mknittle
mknittle's Avatar
The v 8s are like that and Too complicated. that funnycar is a 6bt.
Mark
My GMC build.
Old 09-24-2012, 10:21 PM   #1039
RINC
RINC's Avatar
New Posie springs. Powder coated rims with Coker tyres ....
Hope to have it out of the shop in a couple weeks
Chris
'69 C-20
'04 Jeep TJ
RINC is offline   Reply With Quote
Old 09-25-2012, 06:24 AM   #1040
Hot Rod Todd
I Flew north and got my truck about a week ago and set out on the nearly 700 miles to home. We bought it back in January and had a mate sort out a bunch of small issues, and replace the Chev 250 & manual box with a 350 and 700R4. Apart from the engine upgrade, we have also fitted seat belts and burst proof doorlocks.
Truck had to pass our "certification" system before it could legally go for a warrant of fitness and then become legal.
Our truck has Jaguar from & rear suspension & steering. I can say the Jag steering setup is about the nicest I have ever driven in a hot rod, and they are dirt cheap to buy now.
Hot Rod Todd is offline   Reply With Quote
Old 09-25-2012, 08:23 PM   #1041
mud.man.rj
mud.man.rj's Avatar
That is a good lookin truck, it is a 54 right, just getting used to the years. I like the tailight setup.
Old 09-25-2012, 08:46 PM   #1042
99 to Life
99 to Life's Avatar
Thats a 54' grille but the cab is from half of 47-53. I think this was either the first or second or maybe the only one I seen with this set up. I personally like it, cool little touch not many people would catch.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 09-25-2012, 08:49 PM   #1043
Hot Rod Todd
I suspect it was "recabbed" at some stage of its life with a later cab, as its actually registered here as a 48, but its the later 54/55 grill, and it doesnt have the popout vent on the LH side.
Down here, the 55 truck still had the two piece glass, tho by then you guys got the curved glass. Maybe its the time on the water or maybe we got our trucks from Canada, as we were part of the British Empire back then & anything with links to Britain got favourable treatment.
Tail lights are 50 Pontiac repro ones on a fairly short rolled pan
Old 09-27-2012, 08:03 PM   #1044
Miayota
My "54 Raton".....
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Miayota is offline   Reply With Quote
Old 09-27-2012, 08:32 PM   #1045
jbclassix
Junk Yartist
jbclassix's Avatar
Your photography is killer. It really does the truck justice.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 09-27-2012, 10:32 PM   #1046
99 to Life
99 to Life's Avatar
Finally some more AD trucks on this thread.
What is your suspension on that looking like? Dig the truck.
Old 09-28-2012, 03:37 AM   #1047
RINC
RINC's Avatar
Hot Rod Todd .... Miayota ...... Nice trucks !!!!!!!!
Now my patina is coated in clear coat ..... looks "Creamy" to me !!!
Chris
'69 C-20
'04 Jeep TJ
Old 09-28-2012, 07:33 AM   #1048
fat56
fat56's Avatar
Thought i would post up a couple of trucks i have saved after searching the net for paint ideas.
Blake. Sydney Aus
56 Chev 3100
build - http://67-72chevytrucks.com/vboard/s...d.php?t=480363
LOW n LOUD
fat56 is offline   Reply With Quote
Old 09-28-2012, 09:19 AM   #1049
oldman3
oldman3's Avatar
Fat56, that is some nice trucks....Jim
oldman3 is offline   Reply With Quote
Old 09-28-2012, 11:58 PM   #1050
meter swinger
meter swinger's Avatar
That GMC with the 90's bed is really nice. Last time I saw it was at classy chassis in Kennewick.
meter swinger is offline   Reply With Quote
