#1026 |
Re: LS1 into a 73 cheyenne
Here’s one of the lil dude
Alex - Dirty AL "One Piece at a Time" Follow me on Instagram alex.barr.ios |
#1027 |
#1028 |
I'm just glad to be here!
Congrats!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#1029 |
Congratulations on the new little smokedat!
#1030 |
Awwwwwwwww.... little feller! Congrats!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#1031 |
#1032 |
After a 5 month wait she finally arrived in style
#1033 |
Holy $#I@ that looks beautiful! I bet it cost more than a good portion of my truck...LOL
#1034 |
Still Learning
Congrats on the new family member!
that steering wheel! ![]() |
#1035 |
moving the truck to different location to finish of the final body and paint. Will block it one last time then seal it and paint. I say about 3-4 weeks before we see some color.
#1036 |
Had you ever considered having the cab and body parts acid dipped?
77 C10 Silverado SWB - LS Swap, mechanical resto-mod 05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e |
#1037 |
#1038 |
I can fap to this
#1039 |
I have herd of this option but I already went down to bare metal. At this point I just need to block then paint
#1040 |
#1041 |
#1042 |
So I gave her a good blocking panel alignment and gaps and crease lines look great but as expected I had some flaws by the doors, as it got door dings for being in garage that was actively used. In some areas I exposed some metal and in others I exposed some filler. I will spray the exterior only hood, cab, doors, and bed as a surfacer once again with some house of Kolor kd3005 its a DTS surfacer/sealer. There KD 3000 line is all the same the last digit just means the tint, kd3005 is a blue tint. This primer requires an activator hardner. As far as I know they only sell this in quarts so I got 6. I will block her again then spray some PPG sealer.
Once I have the firewall painted I will install the engine just bolt the mounts and the transmission mounts. Then I will hang the front clip and continue with painting the exterior. First objective after finishing paint is to glass the cab. I got new manual regulators and hardware from LMC, and for the front and rear I’m going with the clear flush fit from one piece products Fesler makes a real flush fit front glass but I think there pricing is off I can’t justify the cost. Another reason I’m kinda leaning toward the front glass from one piece products is because there located 1:30 Hrs away if I pick it up I can save on the shipping which is substantial at around $500 for front and rear. But I do love tha glass from Fesler. As for the door glass I will keep it original with vent window
Alex - Dirty AL "One Piece at a Time" Follow me on Instagram alex.barr.ios Last edited by smokedat; 07-10-2018 at 01:05 AM. |
#1043 |
First is Fesler second One piece products notice the small rubber seal still allot smaller than stock
#1044 |
#1045 |
Originally Posted by superdav: I can fap to this
superdav, please find a better way to express yourself. That was probably meant to be humorous and may fly on other types of forums but crosses the line here. People taking the time to let us see their projects should not have to deal with awkward comments like that. Last edited by LT7A; 07-10-2018 at 09:49 PM. |
#1046 |
#1047 |
With regard to the forum, I'll say it doesn't have anything to do with trucks... At least for most of us anyway. Beyond that, Google can probably help you out.
#1048 | |
#1049 |
Some parts arrived I got the regulators from Goodmark and the door seals from Precision door sills and a heavy duty dispenser gun from Albion B26 for the heavy weight glass adhesive, since I will be doing the install of all the glass .
#1050 |
I’m waiting on the vent window seals handles and rivets. I will restore these add new seals handles and paint the frame. I have some PCL flat black from another job Il use for this. Il post some pics of this process.
Tags |
73c10, c10, cheyenne, ls1, swap |
