Old 08-05-2014, 07:25 AM   #1026
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks! i'm glad you are enjoying it!
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 08-06-2014, 11:05 PM   #1027
ryanroo
ryanroo's Avatar
Re: 72 k20 project
a little piddling around today. I did some other things, but i didnt get any pics, and its no fun without pics. hopefully more to come tomorrow.
this is the OEM cummins rocker box hold down. pretty fancy. it is a sealing bolt, has an oring at the top and a cute little recess for the oring to sandwich into as it meets the similarly shaped countersink in the rocker box. at just the right time for the shoulder to bottom out on the pedestal below and preload the rocker box gaskets just so.
so, as a few of you may know from reading or talking to me, i have a slight case of the twitch. in my last McMaster Carr binge, i bought some regular M10x20mm shoulder bolts. You can see what i meant about twitching out. allen heads everywhere. cant hardly stand the hex head on the very top. plus two of the stock bolts had a stud top for the fancy dodge logo cover piece. ugly.
thankfully these are like most. the diameter of the shoulder necks down at the head. not totally legit, but it allows the o-ring to go somewhere as it is turned in.
now, it cant be all that easy. i had a gross of small sized "fender" washers. for an upcoming part of the puzzle. i drilled the ID out so it just barely sneaks over the M8-1.25 threads on the shoulder bolt. 5/16" is just a hair under 8mm so it works perfect. that adjusted the effective length of the shoulder enough to not wildly over tighten it.
72 K20 12v build
Old 08-06-2014, 11:10 PM   #1028
El Campo
El Campo's Avatar
Re: 72 k20 project
Nicely done! Get rid of all the Dodge you can :-D
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 08-06-2014, 11:16 PM   #1029
ryanroo
ryanroo's Avatar
Re: 72 k20 project
I agree! that top cover is ugly, even on the dodges.
i will have the twitch again, until i make another Mcmaster order so i can get some 1.5mm thick, ground flat M8 spacer washers. make the swap totally legit. naturally the Cummins part had to be some goofball length.
72 K20 12v build
Old 08-07-2014, 06:16 AM   #1030
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: 72 k20 project
Don't ever "fix" that twitch....
Rich
1972 K5 Blazer CST Click HERE
Old 08-07-2014, 10:18 PM   #1031
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Recieved a gold plated box today with that big "C" stenciled on the side.
nice to know the B shift lackey is the guy inspecting my order...
one item in the box is the Cummins support bracket for the QE296 compressor. this couples with another yet to be shipped bracket, that may or may not work for me. at least i have something to start with if i need to do some more fabricating.
another item was this OEM thermostat. consensus of the several good sources of information i have, and the internet of course, it was determined that OEM is pretty much the only way to go here. i was planning on that anyhow, but checked to make sure the 30$ gap in price was actually worth it.
included in my seal kit was this new T-stat housing o-ring. retard proof directions.
and that shiny hunk of aluminum(gold) is the cummins oil plate for remote filters.
you will see in the previous pic and these after, that the twitch cannot be stopped.
Fan hub, ALT mount, and brand new water pump installed.
this is the fabricated water inlet. this one got cap screws instead of buttons. looks better and better clearance.
and another special gold plated box showed up today as well, filled with the IP!
It was sent to Utah and given the once over. flowed and matched for 550-600 HP. 4k spring. DVs and aneroid kit. and whatever else vodoo these sneaky pump guys do.
then i have been head scratching about this again. its big and the spot is tight back here. considering a front mount and possible bumper to accomodate. then i would still try to mount a smaller winch. this one is a 12k. i would bet an 8K would fit better and suit my needs for trailer loading assistance in the rear, but then i have to buy another freaking winch. we'll see how this one goes.
What would you guys do? obviously the second winch will ding the truck budget, postponing the finish date and all that...
72 K20 12v build
Old 08-07-2014, 10:37 PM   #1032
El Campo
El Campo's Avatar
Re: 72 k20 project
Speaking of gold plated parts from Cummins my Dad just bought a water pump for an 855 and it COST LESS than thought humanly possible! It was only 20 dollars more than Chinese made NAPA one!!!! Unbelievable and impossible for that to ever happen again in history. Haha. Hey at least no one has figured out how to put a Cat in these yet or else Cummins price could only be called bronze at that point. Everything looking really good! I like the idea of a front and back winch . 12k should be plenty big lol
Hook em Horns!!!
Old 08-11-2014, 07:58 PM   #1033
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 k20 project
Nice splurge on hardware. It looks nice. The winch does look a bit big, but I bet you find a way to sneak it in there.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-11-2014, 08:28 PM   #1034
ryanroo
ryanroo's Avatar
Re: 72 k20 project
I know a couple guys who have worked with cat stuff. thats no lie. they RAPE you on parts. i bought a few bolts to make some leveling feet for my table from the local Cat dealer. DANG.
Mcmaster makes it easy. its only ten buck for a bag of 25! i think i have in 5mm increments, every length from 20mm-70mm and a bag of 18mm in M8-1.25. and several M10 and M12s as well. haha.
winch problem is solved. i am going to draw the parts tonight, hopefully get them cut next week when i get back from the north country. i pity the fool who rear ends this truck. it will be very sturdy. more so after this winch mount
72 K20 12v build
Old 08-11-2014, 08:36 PM   #1035
Dieselwrencher
Re: 72 k20 project
I think you need to work on a front bumper after this winch fiasco.
Ryan
Old 08-11-2014, 10:32 PM   #1036
mx289
mx289's Avatar
Re: 72 k20 project
This is a good problem to have.
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 08-11-2014, 10:42 PM   #1037
El Campo
El Campo's Avatar
Re: 72 k20 project
Agreed! We anxiously await any further progress
Hook em Horns!!!
Old 08-12-2014, 12:53 PM   #1038
jbclassix
Junk Yartist
jbclassix's Avatar
Re: 72 k20 project
fasteners make the finish.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 08-12-2014, 06:57 PM   #1039
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks! be a little bare on progress for a while. im headed to Anchorage for few days... hopefully the pan is done when i get back. and i have a few other things that should be ready to go when i get back too.
I agree. i wasnt always so twitchy, but anymore i am willing to drop the cash on a some bolts. for the benifit of new hardware and the cleanliness it provides i think it is more than worth it for this truck
Listen to this guy... better design up a bumper, i want one
Dont provoke him... he doesnt need any help. ive been getting pestered to do a front bumper for a while now... hahaha
72 K20 12v build
Old 08-12-2014, 08:38 PM   #1040
Dieselwrencher
Re: 72 k20 project
Yep. IDK WTF you've been waiting for. That yellow monster needs one too before it meets a mule deer or something.
Ryan
Old 08-13-2014, 12:50 AM   #1041
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i don't really know what i have been waiting for either. i have had so much free time lately that i guess i should have done it already...
72 K20 12v build
Old 08-13-2014, 08:44 PM   #1042
ryanroo
ryanroo's Avatar
Re: 72 k20 project
so...
i get a call that the pan is done. HECK YES.
somehow the message that it was to get PC'ed raw was lost. so it got sandblasted. dammit. the work is top notch. always is with the local shop. knowing Jim, he will happily color it any color i wish and get it done asap. but i am leaning towards running it in the raw blasted look. still goes with the raw AL accessories on the engine. if i did re-coat, it would be in satin black. also, all the oil fittings will be red and blue for the blasted look, black if coated in satin. Opinions welcome on that one.
72 K20 12v build
Old 08-13-2014, 09:21 PM   #1043
tsnow678
Re: 72 k20 project
Looks great as is! Leave it alone and get this beast on the road.
Link to my 69 Camaro 6.0/T56 swap:
http://ls1tech.com/forums/conversion...69-camaro.html
tsnow678 is offline   Reply With Quote
Old 08-13-2014, 09:58 PM   #1044
El Campo
El Campo's Avatar
Re: 72 k20 project
Having had even non leaky gas engines with aluminum heads and seeing how easy they get ugly I would put SOMETHING, anything on it. I hate that you would cover that pretty pan up but I think otherwise it will look grungy and dirty soon.
Hook em Horns!!!
Old 08-13-2014, 11:11 PM   #1045
ryanroo
ryanroo's Avatar
Re: 72 k20 project
It is powder coated clear. they just blasted it before instead of clearing the raw pan. the more i look at it, the more i like it. this is going on as is.
72 K20 12v build
Old 08-14-2014, 12:57 AM   #1046
Dieselwrencher
Re: 72 k20 project
I'd run it as is. I really like the contrast you have going on here.
Ryan
Old 08-14-2014, 06:00 AM   #1047
mcmlxix
mcmlxix's Avatar
Re: 72 k20 project
It looks like NASCAR grey in the picture.... but yes, leave it raw. Its not worth striping the powder off and sanding it smooth with the lines all going in one direction for a brushed look .... is it?
Rich
Old 08-14-2014, 07:31 AM   #1048
ryanroo
ryanroo's Avatar
Re: 72 k20 project
no, definitely not. i don't like the "grained" look, and i don't have anything that would make it look right anyhow.
i thought they had colored it at first too. but if you get up close you can tell that it is just blasted. the blaster did a superb job keeping it even and uniform. it almost looks like a really nice casting.
72 K20 12v build
Old 08-14-2014, 03:44 PM   #1049
Dieselwrencher
Re: 72 k20 project
Hey, the next one you build for your hauler rig can be left shiny and cleared.
Ryan
Old 08-16-2014, 10:19 PM   #1050
mx289
mx289's Avatar
Re: 72 k20 project
That pan does look good as is.
I vote for for black or nickel fittings ?
Tom
71 K2500
71 K5 Jimmy
