Old 03-13-2009, 01:30 AM   #1
shrunken66stroker
shrunken66stroker's Avatar
Shrunken66Stroker's build thread.
I'm going to start from the beginning to give you guys a sense of how far this project has come. My Grandfather bought this truck off the lot in 66 along with a chevelle for my Grandmother. I think he must have run into some money to buy both of them at the same time. The chevelle is currently sitting in my Dad's driveway in pristine unrestored condition. It has the original 283, powerglide and only about 70,000 miles on it. That's my next project if I can talk him out of it. Back to the truck.
This truck sat broken down in my yard from the time I was in middle school till I was 21. My Dad and I put a rebuild small block in and I drove it around the country. 30,000 miles later I finally moved into a house with an empty two car garage out back. This was 2 years ago in January 09'. I started stripping it down to the frame immediately. Once the frame was bare metal I decided to convert it from a long to a short bed. With some help from my Brother and Dad, we cut 20 inches out of the frame and the bed. I ordered up the Air Ride Strong Arm kit for the front and back along with a four wheel disc brake set up from Baer. After the bags and brakes were on I put the cab back on the truck and started cutting rust out of the floor board, kick panels and rocker panels. I patched the floors on both sides and moved to the front fenders. I bought new ones but have since decided to cut them up and patch the original fenders. When you get a part for your truck and it has a made in Taiwan sticker on it, it makes you cringe. Plus nothing fits like original sheet metal. I've done most of the hammer and dolly work and have gotten all of the panels pretty straight. When the front fenders are done I'll be ready for primer.
Right now I still have the rebuilt small block in it but I traded out the old 4 speed granny for a T-5 out of a Firebird. It's a good cruising combination for now but it's only a place holder for what I'm in the process of building. I've started a 383 stroker that will have about 450hp and will be bolted to a Tremec TKO500 5 speed. I'll probably have to finish the truck first with the engine and tranny that are in it now and swap them out later. I've had to prioritize since the economy turned to ****.
I'll post as many pictures as I can to give you guys a good look at some of the work that's been done. Some of them are from my phone so there a bit fuzzy but effective.
Thanks for looking.
shrunken66stroker is offline   Reply With Quote
Old 03-13-2009, 01:40 AM   #2
shrunken66stroker
Re: Shrunken66Stroker's build thread.
This is the TIG welded frame with the backing plate. Also, the sheet metal cuts I have from the 20" shortening.
Old 03-13-2009, 01:51 AM   #3
shrunken66stroker
The bed is welded up and is now a stock length shorty. If anyone is doing this make sure you brace it up tight before cutting the rear. Both sides of the rear come off at the same time and are connected with the cross sill. I used a piece of angle I had and bolted it where the tail gate chains go. I also braced it in the center the same way. When I put the tailgate back on the gaps and alignment were perfect... or as good as they were before.
Old 03-13-2009, 02:01 AM   #4
shrunken66stroker
These are the brake and engine shots I have from after the install. The set up is from Baer and is not cheap. I broke the bank with these and my build has stalled because of it. Maybe I'll learn to budget next year. Running out of money teaches you things like hammer and dolly technique so it's not all bad sometimes. Elbow grease is free.
I didn't take to many progress pics during the middle of jobs but lots after each was completed.
Old 03-13-2009, 02:17 AM   #5
shrunken66stroker
Cab on, rusty floor out and fresh metal in. Most of the time I'm working by myself which explains the cherry picker.
Old 03-13-2009, 02:21 AM   #6
shrunken66stroker
I cut 3" out of the steering column to have a little more room to roam because I'm 6'3. I've decided to keep the bench because I can't seem to find a bucket that looks like it fits in the truck. I'm going to lower the bench a little for more head room when I get a chance.
This is how she sits now and brings us up to date in March, 2009. It's come along way since the snow shot.
Old 05-14-2012, 12:24 PM   #7
el_bole
Shrunken66stroker,
Great thread, apologize in advance if my question is answered some where in your build thread....I too have a long bed, just panels and rear end cut off, and want to know what is the exact length in front and back of wheel well? Basically want to have someone weld it up into shorty....ANy info would be greatly appreciated...
Thanks,
el_bole
el_bole is offline   Reply With Quote
Old 05-14-2012, 10:41 PM   #8
shrunken66stroker
Originally Posted by el_bole View Post
Shrunken66stroker,
Thanks,
el_bole
I cut 12" out of the frame and bed infront of the wheel and 8" out off of the end of the frame and bed behind the wheels. I believe the wheel base of a stock short bed is 115" and the wheel base of a long bed is 127". If you want I'll take a picture of where I cut the frame under the cab. If you want specific measurements I'll be happy to get them for you.
Old 03-13-2009, 01:41 AM   #9
rss396
rss396's Avatar
Looks like you have a very good plan and are going to have a very cool truck. Like to see more pics. Also nice shop / garage.!!
1950 Chevy 1/2 ton 283 Mustang II
1961 SWB 2x4 235 six
2007 Silverado 1/2 ton Z71 4x4
1968 Camaro SS 396 / 502
rss396 is offline   Reply With Quote
Old 03-13-2009, 04:09 AM   #10
collins10672
collins10672's Avatar
you have a great looking build project.i have never saw a 60-66 bed shortened the way you did it(most people just cut straight down),but it looks fantastic.great welding skills and quality metal finishing.i wish i had your metal working skills.will be sweet truck.keep up the good work.
collins10672 is offline   Reply With Quote
Old 03-13-2009, 07:37 AM   #11
jason65
Registerd User
jason65's Avatar
Great lookin truck.
jason65 is offline   Reply With Quote
Old 08-14-2011, 02:11 AM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
The way Shrunken66Stroker did it is a better method to insure a straight frame.
Take, for example; cutting it straight down and then being off by 1/16 of an inch. Now multiply that 1/16" by half the length of the frame. It only takes being off by a small fraction to translate to much over the length of the frame.
66 C20 Service Truck:
Old 03-13-2009, 08:12 AM   #13
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
awesome build!! 2 questions where did you get the front shocks and shock mounts?and second where did you get the tubular trailing arms and crossmember i want to get all of that for my build let me know thanks
gostranger is offline   Reply With Quote
Old 03-13-2009, 08:36 AM   #14
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Nice and build...and even nicer is the story behind both rides !!! That is way cool, and the only way to get them !!!
Looks like the bed was shortened like they did on "Trucks"....Similar ?
Great work !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-13-2009, 08:52 AM   #15
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Sweet
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 03-13-2009, 10:22 AM   #16
shrunken66stroker
Yes, it's the same cuts and air ride. I'm trying to finish mine before they do but they have a better credit card than me. I'm bustin my ass to save for some rims and tires to get this thing on the ground. It's been on jack stands for almost 2 years. I think I'm going with 20" Coys or Torq Thrusts. Not sure yet.
Great work !!
Old 03-13-2009, 10:17 AM   #17
shrunken66stroker
All of the suspension parts are from Air Ride Technologies. Not cheap but I'm hoping it's going to give me some great handling. It'll be a while before I find out. Some day I'll be able to afford wheels.
Old 03-13-2009, 12:37 PM   #18
kizer
Its Deja Vu time again
kizer's Avatar
Wow nice job man. I will say nothing is cooler than seeing a truck in bare metal. Its kinda cool to me and that thing your working on is going to look awesome.
Can I ask a silly question thou? How long can you leave bare metal like that without it rusting? Or is the length of time realitive to the moisture and tempreture in the air?
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 03-13-2009, 01:09 PM   #19
shrunken66stroker
It's not a good idea to leave it in bare metal for long. I live in las vegas where the humidity hovers around 5-10%. I can get away with it longer than most but I'm still worried about it and about to shoot it with etching primer when the front fenders are done. If I lived in a humid climate I wouldn't be so lazy.
Old 03-13-2009, 05:46 PM   #20
66chevy PROSTREET
SOLD
66chevy PROSTREET's Avatar
Location: Poorest state in America(Breaux Bridge,Louisiana)
in south louisiana i can't leave something bare metal for more than 2 hours with this 80-100% humidity!!
1966 CHEVY FLEETSIDE
SOLD 11-29-9
TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2
66chevy PROSTREET is offline   Reply With Quote
Old 05-12-2012, 04:17 PM   #21
bobbylast
bobbylast's Avatar
i know dats right...
If you used to be...then i guess you never were.
bobbylast is offline   Reply With Quote
Old 05-12-2012, 10:47 PM   #22
Strodder
Daring to be Different
Strodder's Avatar
In the high Desert that doesn't happen.
It's a DRY HEAT.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 03-13-2009, 12:47 PM   #23
66chevy PROSTREET
SOLD
very nice!
SOLD 11-29-9
Old 03-13-2009, 01:15 PM   #24
TimE
Hey Y'all!!
TimE's Avatar
Great job so far!! Keep it up.
That's a cool story behind the truck. Good luck in talking your dad out of the Chevelle.
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 03-13-2009, 01:16 PM   #25
kizer
kizer's Avatar
Thanks. I figured as much. All this metal work stuff is over my head. I"m a computer geek with a camera and trying to be computer geek with a grinder and a cut off wheel.
Worst case I'll get tons of pictures of my mistakes. hahahaha
Either way I subscribed to this thread because its kinda cool. Your backstory was awesome as well.
1966, bagged, disc, long to short, stroker
