Old 03-20-2013, 08:48 PM   #1051
jbclassix
Junk Yartist
jbclassix's Avatar
Re: 1967 Chevy CST aka "the loud truck"
Rick, what cam are you running with that single plane high-rise? That's probably not helping.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 03-20-2013, 11:50 PM   #1052
shawno72
C/10 junkie
shawno72's Avatar
Rick its almost Thursday, is everything alright?
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 03-21-2013, 01:17 AM   #1053
67chevy1series
67chevy1series's Avatar
Jeremy I'm running a stock cam..
This engine burns oil like you wouldn't believe! Worse then the other one! After about 30 minutes of driving it burns an entire quart! I don't think I'm gonna make it to the show..
67chevy1series is offline   Reply With Quote
Old 03-21-2013, 01:19 AM   #1054
NewType72
NewType72's Avatar
awe man why in the world would it ever burn that much oil?? Do you have a major leak somewhere?
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 03-21-2013, 01:23 AM   #1055
jbclassix
Junk Yartist
jbclassix's Avatar
Dude, that sucks! Sorry to hear that. I know what it's like to fire up a used engine and have to shut it off just to pull it back out. Live and learn.
-Jeremy
Rebuilding an NP205
Old 03-21-2013, 01:27 AM   #1056
67chevy1series
Probably wont have to pull it out but defiantly take everything off the front of the engine. Need to do a new harmonic balancer so it can seal and the new timing chain an ill probably be set
Old 03-21-2013, 01:32 AM   #1057
NewType72
NewType72's Avatar
Whatever balancer you're looking at spend the cash for a fluid dampener one they are too truck I love mine to death it's amazing what keeping the crank completely balance will do for a motor
- Dylan
(209)-985-7721
Old 03-21-2013, 01:57 AM   #1058
67chevy1series
Fluid dampener? How much do they go for?
Old 03-21-2013, 02:12 AM   #1059
jbclassix
Junk Yartist
jbclassix's Avatar
Talking Re: 1967 Chevy CST aka "the loud truck"
Also, do you plan on running a double roller chain? If so you know about grinding the block for clearance, right? Fluid dampeners are tops. But for that kind of money you may want to make sure your bottom end is worth the investment.
I still think you will have performance issues with tour intake/cam combo. If you are that far into it why not do a new bump stick
Posted via Intergalactic Device
-Jeremy
Rebuilding an NP205
Old 03-21-2013, 07:30 AM   #1060
shawno72
C/10 junkie
shawno72's Avatar
Rick I'm sorry to hear that. Is it actually burnin oil or leaking oil?
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 03-21-2013, 08:44 AM   #1061
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I'm sorry to hear this, is it smoking or leaking? how was the compression? How the plugs look after running it?
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 03-21-2013, 12:53 PM   #1062
67chevy1series
the plugs look perfect. and its doing both. the oil is leaking so much that i gets onto my exhaust and burns off as im driving which creates smoke... jeremy i ddi not know about grinding the block for clearence with the double roller chain do you have any pics?
i did do one thing productive. i managed to run my vacuum lines in a really nice way.
Old 03-21-2013, 01:04 PM   #1063
NewType72
NewType72's Avatar
Oil from the heads? Seeping through the gaskets and ontop of the headers correct? What kind of gaskets are you using?
I ran those rubber with metal lunging re-usable ones for a long time and leaked like a siv now I run thick cork style and haven't leaked on my drip pan in almost a month now
- Dylan
(209)-985-7721
Old 03-21-2013, 01:12 PM   #1064
67chevy1series
no its coming from the rear of the oil pan and the harmonic balancer.. and then from there it flays back to the passenger exhaust and then it burns. its making a mess of the whole frame really i am actually sorry that i sold the 350 i pulled out of my 68 K10. i wish i just put that in my truck. thing ran like a top and with a little paint and some gaskets it would have actually did what i thought this one was gonna do for me... im pretty discouaraged. but then again im not really a master engine guy, i shouldve known what was to become of my plans for this engine. oh well. if i pull this engine out again or fix it while its in the truck and it still leaks or doesnt run right then im gonna pull it out and use it for a table. lol if you dont want to work then ill make sure you never do haha
Old 03-21-2013, 03:32 PM   #1065
Ol Blue K20
Did you figure out the miss? Leak at the rear main or pan?
Dale
Old 03-21-2013, 03:48 PM   #1066
67chevy1series
its the pan i believe. and yeah it has to be the timing chain. ive been through all the vacuum lines and double checked the intake not a leak insite for the intake. so that leaves me with bad timing or oil in the cumbustion chamber.. and timing is as good as it will ever be and the spark plugs have no carbon build up. so there cant be any oil getting in there. leaves me with my timing chain and since its so loose that would explain why it would be miss firing because its having poor timing. so new timing chain will fix my miss fire and new harmonic balancer will fix the leak. so im gonna get new timing chain cover gasket kit and a new harmonic balancer or a really good used one with no grooves and then ill pull it aprt and fix it. i dont think the intake/cam alliance isnt right because when i had new spark plugs that didnt have real bad carbon on the 302 it would run pretty good actually. its just that it was tired and didnt have the power it was capable of having.
Old 03-21-2013, 03:53 PM   #1067
Ol Blue K20
make sure to check the rear main seal while you're fixin things. by the way vac lines look good
Dale
Old 03-21-2013, 04:11 PM   #1068
67chevy1series
thanks dale! at least i did one thing right with the vacuum lines lol
Old 03-21-2013, 04:20 PM   #1069
Ol Blue K20
Don't beat yourself up, this is how we learn
Dale
Old 03-21-2013, 04:32 PM   #1070
67chevy1series
lol thats why im givin myself some chit that way i wont ever but a engine in a truck again without it having a new timing chain and harmonic balancer lol
Old 03-21-2013, 04:43 PM   #1071
67chevy1series
alright now that the discouraged stage has passed its time for planing and idea stage lol i have a motor head buddy who lives fairly close to me and gives me good deals (not the race car guy) and he has plenty of engine parts and components so he should have harmonic balancers and stuff. so ill buy a good harmonic balancer from him and then use that on the 327 and as for timing chain.. i want it new so that way theres no way in hell that things can be loose lol
Old 03-21-2013, 06:02 PM   #1072
fastcam1
Young gun
fastcam1's Avatar
Sound like a good plan to me
67 SWB Custom "JANE"
http://67-72chevytrucks.com/vboard/s...d.php?t=554024
Northwest C10's
http://www.facebook.com/#!/groups/Norhtwestc10s/
Cameron sparks
fastcam1 is offline   Reply With Quote
Old 03-21-2013, 07:45 PM   #1073
sleeper69
I know that im comming in way late, but i just started a clone cst and im ordering parts comming up soon. What are the factory sunvisor rods? Chrome or painted black? Any helf would be great
sleeper69 is offline   Reply With Quote
Old 03-22-2013, 12:10 PM   #1074
67chevy1series
They are like a milky silver color looking forward to seeing a build for your truck if your gonna make them
Old 03-22-2013, 12:10 PM   #1075
67chevy1series
Same here! Just need to get the parts and get it done
