07-10-2014, 08:29 PM | #1051 |
Re: 1963 C-10 in NC
thks a bunch either my box is wrong or i need new holes, cuz my box is way to close to the bumper and the draglink is too off. darn PO. it was working when i did drive the truck the 3 time a total of 20miles before i blew it apart. oh well i have a hammer drill,thks for the pics
07-10-2014, 08:49 PM | #1052 |
Re: 1963 C-10 in NC
If your steering box is just leaking from the seal and has no slack in it, it is real easy to replace the 3 seals and put new grease in it. I just did mine. I ordered the pitman and steering shaft seals from truckshop.com. I made my own gasket for the top plate from some Felpro gasket sheet. I packed it with non synthetic grease.
After reading I should have used gear oil due to channeling of the grease. I put a lot of grease in there I packed it in before putting the pitman shaft and gear back in. Cost me about $25 total to rebuild it. My worm gear had no slack and the top and bottom bearings where in good shape.
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
07-11-2014, 08:18 AM | #1053 | |
Re: 1963 C-10 in NC
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
07-11-2014, 08:19 AM | #1054 | |
Re: 1963 C-10 in NC
07-11-2014, 08:24 AM | #1055 |
Re: 1963 C-10 in NC
Picked up a steering coupler rebuild kit last night when I popped in to Advanced Auto with the Bluebomber. He had a brake light issue (easily resolved with two new bulbs). Anyways....they had the kits on the shelf for $9 so while I have the steering box off for rebuild I'll rebuild the steering coupler.
07-11-2014, 01:03 PM | #1056 |
Re: 1963 C-10 in NC
Picked up a new toy today from Harbor Freight. Ive been ok so far without one since I normally just do engine / trans separate. But I want to install the engine/trans together this time. they had a 1 1/2 ton leveler for $26.99, but the 2 ton leveler was only $29.99 and has a built in handle as opposed to using a socket.....just more hands free in my opinion.
Goal is engine/trans set in this weekend.
07-11-2014, 01:28 PM | #1057 | |
Re: 1963 C-10 in NC
07-11-2014, 01:35 PM | #1058 | |
Re: 1963 C-10 in NC
07-11-2014, 04:27 PM | #1059 | |
Re: 1963 C-10 in NC
07-11-2014, 06:00 PM | #1060 | |
Re: 1963 C-10 in NC
07-11-2014, 09:47 PM | #1061 |
Re: 1963 C-10 in NC
removed the cpp mounts from the 348 and put the stock mounts back under it. i have the cpp mounts on the stepside frame now. considering using the tubular trans mount and moving the engine forward some....originally i was going to work the firewall, but the more i look at measurements it'l be tight with a tailshaft mounted floor shift. the extra inch or two will help. so the original bellhousing crossmember will some out. i can use either trans mount, but the original will take some massaging to make it work. we'll know this weekend. i also have to be carefull how far forward since its a lwp setup
07-12-2014, 04:03 PM | #1062 |
Re: 1963 C-10 in NC
had a good day today. drove an hour north to go pick what was left of a 65 c-10 52,000 mile truckk. he had the cab, hood and some stuff i had him pull a week ago. truck was vin #595, lowest 65 ive seen yet from the baltimore plant.
picked up a nice factory fan shroud w/no cracks, gem of a deluxe seat minus 1 rip. still has some of the factory plastic cover left on the back. ill reuse the frame and let a 65 guy use the cover for a template. i'll turn it into a 63 deluxe seat. got the 4 way hazards, deluxe wheel, tailgate, found a random set of 60-63 inner door panels and........finally.......found a 60-66 power brake pedal. score of the day at $20 and nearly perfect. i'l get some pics up monday as i can't load them from my phone. shroud fit over the 348 nicely....i'll use my drum style on the stepside. also got a tailgate and spent $270 in total. he has the floor shift column for me and will bring down in a week when he comes to visit his dad.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 07-12-2014 at 04:09 PM. |
07-12-2014, 04:04 PM | #1063 |
Re: 1963 C-10 in NC
truck had a high hump, but he had the cab sold to someone from michigan. hope its a forum member as the cab was 95% rust free. had a gorgeous cluster, but was going with the cab. nice hood he wanted $200 on, but i have 3 already.
07-12-2014, 04:08 PM | #1064 |
Re: 1963 C-10 in NC
Wasn't me that bought it, kinda wish it was... Rust free is nice!!!
07-12-2014, 04:13 PM | #1065 |
Re: 1963 C-10 in NC
had a nickle size hole by the a piller on the floor. other than that it was rust free from what i saw. says its been in a garage for the last ten years. i dont know why he parted it out as everything looked great that was there. the harness was a gem too...looked nos it was that nice. had the deluxe knobs, aluminum grill (already sold) and windhield/sail panels for trim. no body trim and warning lights, not gauges
07-12-2014, 06:29 PM | #1066 |
Re: 1963 C-10 in NC
How nice was the hood, I think I saw it on the Craig's but Leary of things with only a couple small pics.
07-12-2014, 09:10 PM | #1067 |
Re: 1963 C-10 in NC
was a good hood for $200....said he'd take $150 if someone offered it. had a small area that needed some minor attention on the back of the driver side edge. just a little bend from being stood up on edge. other than that looked very solid. didnt have a magnet on me as i wasnt going for sheetmetal, but inside supports were all solid as was the inner lip
07-12-2014, 09:31 PM | #1068 | |
Senior Enthusiast
Re: 1963 C-10 in NC
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
07-12-2014, 09:57 PM | #1069 |
Re: 1963 C-10 in NC
Ok I may try and get that, I'm in need of a decent hood. Thought about waiting for auto fair.
07-13-2014, 03:36 PM | #1070 | |
Re: 1963 C-10 in NC
07-13-2014, 03:37 PM | #1071 |
Re: 1963 C-10 in NC
i don't think you'l be disappointed with the hood at $150-200
07-14-2014, 08:16 AM | #1072 |
Re: 1963 C-10 in NC
Couple of pics of the parts I got off the 65 Deluxe saturday.
Great find on the pedal pad, it will clean up nicely and has very little wear on it. But plenty of dirt.. The seat will be a great donar for a 63 deluxe conversion. I'll pull the 65 cover off so it can be used as a template. Couple of small dings here and there and a few mud dobber nests, but the seat will clean up nicely and will be a nice addition to the 63 fleetside
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 07-14-2014 at 08:33 AM. |
07-14-2014, 08:21 AM | #1073 |
Re: 1963 C-10 in NC
Also got the four way hazards....I have a bowtie 105 knob somewhere that I'd like to swap knobs out for. The steering wheel is cleaning up very nicely. Some pitting on the horn ring, but a nice wheel. The shroud fit in great over the 348. Its a tight fit, but it'll work.
Also posted a pic of the 65's VIN. Lowest VIN I have seen yet for a 65. Its not often you see a triple digit VIN #. Was such a clean truck, hated to see it parted out. Wasn't much left when I arrived, so glad I called him a week ago and had him pull what I wanted.
07-14-2014, 08:28 AM | #1074 |
Re: 1963 C-10 in NC
Had a long busy weekend. Did have time to pull the CPP perches from under the 348 and get them in the stepside. Got the manual trans crossmember taken out. Would have been a lot easier a week ago when I had the front crossmember done, but it is what it is. Ended up grinding off all 12 rivets and pulling it in 3 pieces. I can slide it forward with some modification, but it'll put the transmission up around 1/2" - 3/4" higher than the stock location. Also have the CPP tubular trans mount I can use on the tailshaft mount......decisions, decisions.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 07-14-2014 at 09:27 AM. |
07-14-2014, 10:21 AM | #1075 |
Re: 1963 C-10 in NC
Looks good! I envy the power brake pad. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
