Old 12-03-2015, 02:18 AM   #1076
shrunken66stroker
shrunken66stroker's Avatar
Re: Shrunken66Stroker's build thread.
Originally Posted by Strodder View Post
That's going to be scary.
Ha. Not after cutting the truck in half. I think I have it figured out. Now, if I can only find the time.
shrunken66stroker is offline   Reply With Quote
Old 12-06-2015, 02:06 PM   #1077
shrunken66stroker
I got the rest of the tube in the mail yesterday, so I started on the passenger header. I'm going to tackle the hood mod after the headers are done.
Old 12-06-2015, 05:48 PM   #1078
Gary V
Active Member
Gary V's Avatar
Nice work! Great build... subscribed
Best regards,
Gary
DOMERINGER BUILD
Gary V is offline   Reply With Quote
Old 12-07-2015, 01:46 AM   #1079
jlsanborn
jlsanborn's Avatar
Sweet! Is that Mandrel Bends stuff outta Oregon?
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 12-07-2015, 03:40 PM   #1080
shrunken66stroker
Thanks Gary
Yes, they're called Columbia River Mandrel Bends. Great stuff, but the "builder kits" leave you with about 1 header and a few left over bends. Not quite enough for a full set.
Old 12-08-2015, 03:21 PM   #1081
jlsanborn
jlsanborn's Avatar
Ya, I bought their stuff to build my exhaust. Nice!
Old 12-08-2015, 10:49 PM   #1082
shrunken66stroker
And the other side tacked up. The good thing about the mock up is you can change it to make it smoother once you get it on the bench. The bend on the number 2 tube is to miss the lower A arm pivot and to go under the starter. The passenger side was a little more difficult because of the starter, but not bad.
Old 12-09-2015, 01:40 AM   #1083
Captainfab
60-66 Nut
Very nice work......quite professional looking.
Old 12-09-2015, 10:10 AM   #1084
66ChevyMax
66ChevyMax's Avatar
How cool is that
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 12-09-2015, 12:50 PM   #1085
jlsanborn
jlsanborn's Avatar
Well done!
Old 12-23-2015, 11:48 PM   #1086
Indyfab
Indyfab's Avatar
Still one of my favorites on hear. I'm looking at buying some wheels for my heap soon, is your rearend the stock width? Would a 4.25" backspacing front, 5" rear backspacing fit your truck? I still have drum brakes in the rear and trying to figure out if the wheels I like are even close to fitting, there isn't a lot of choices in backspacing. Thanks for your incite.
Indyfab is offline   Reply With Quote
Old 12-25-2015, 03:36 AM   #1087
shrunken66stroker
Thanks Cap. They're tacked up and in the truck. I have to get them back out and weld everything up still. Then, I have to figure out if I'm going with Jet Hot coating or what else to do.
Originally Posted by 66ChevyMax View Post
How cool is that
Thx!
Well done!
Thanks! The rear end on mine is stock width. I have discs on the back so I can't say 100%, but I think it should be the exact same width on the axles. My rims are Cragar Soft 8's, 17X9 with a 5" backspace on the rear and 17X8 with a 4.5" backspace on the front and they fit great. The rear is a little tight getting the wheel on because the "skirted" fender dipping so low, but it works.
Old 12-25-2015, 03:53 AM   #1088
Indyfab
Indyfab's Avatar
Thanks for the reply, I had it in my head that your back wheels were a 5.5" backspace. I only have two choices in the wheels I'm looking at, 5" and 5.75" so I was having a heck of a time trying to decide which to get.
Old 12-25-2015, 04:01 AM   #1089
Indyfab
Indyfab's Avatar
I forgot to ask if your front A-arms narrowed up the front track width any. If so how much? Thanks again
Old 12-25-2015, 07:01 PM   #1090
chevyrestoguy
chevyrestoguy's Avatar
NICE work on the headers! That stuff isn't easy to do. Very impressed, can't wait to see more!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 12-27-2015, 12:42 PM   #1091
shrunken66stroker
I'm not sure about the 5.75 backspace. It depends on how much room you have on the inside. Measure twice, maybe three times.
I have the Ride Tech Strong arms up front and I'm not sure if they're narrower than the stock ones. It was my understanding that they're the same length, but I'm not 100%.
Thanks Resto! Welding them up soon and then off to Jett Hott for coating.
Old 12-27-2015, 02:01 PM   #1092
shrunken66stroker
I had to modify the lower and upper radiator mounts to get the Entropy radiator in. It's a little wider than stock, more so on the bottom than top. I cut and widened the lower mounts a half inch and welded them back together. The upper mount fit pretty well and didn't need to be widened, but I did sand a little off the backs of the rubber pieces to give it more room since it was a little tight. The upper mount held the radiator out toward the engine too far so I cut a half inch out to make it vertical and give me room for the intake to turn down and miss the fans.
Old 12-27-2015, 02:13 PM   #1093
shrunken66stroker
I also got the Holley accessory drive last week and started mocking it up. You can see it in one of the above pics. Very slick and super clean set up. More to come.
Old 12-27-2015, 06:23 PM   #1094
shrunken66stroker
The intake didn't come with a throttle cable mount, so I made one out of 1/8" to fit the existing bosses.
Old 12-28-2015, 12:17 PM   #1095
jchav62
1962 C-10
jchav62's Avatar
I haven't been here in a while. Looking dam good buddy!! Amazing work!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 12-28-2015, 12:45 PM   #1096
likaroc13
Rollin' Old Skool
I agree, some very nice work going on here.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 12-31-2015, 08:11 PM   #1097
shrunken66stroker
Thanks Joe! I'm trying to get this thing back on the road some time in 2016! Happy New Year my friend.
Thanks!
Not a huge progress update, but here's what the engine compartment looks like currently. Everything is mocked up, no internals in the block, nothing torqued down, etc. I just want to make sure I have every piece before building the engine and I'm not chasing parts when I should be shaking it down. My plan is to get the engine built, hook up the engine harness and computer, get it running and broken in, maybe take it out on an old desert road with no traffic and drive it a bit, then blow it apart for paint. I just want to make sure everything is perfect before paint.
I took the headers out to finish weld them up. That's next.
Old 05-25-2016, 04:56 PM   #1098
Johns66
Neat build any updates?
Johns66 is offline   Reply With Quote
Old 05-25-2016, 06:18 PM   #1099
Johns66
Old 05-07-2017, 10:44 AM   #1100
Ricky Rodder
How is thi coming along?
Ricky Rodder is offline   Reply With Quote
1966, bagged, disc, long to short, stroker
