03-23-2010, 06:44 PM | #1076 |
Re: What did you do to your truck today?
Dont stop yet, you have the hard part almost done. what do you have in mind for the chev?
If it has tits or wheels its gonna give you problems!!! |
03-23-2010, 09:07 PM | #1077 |
Shlong Bed Club
removed rear springs, made some bag brackets for rear control arms, and finished painting my new valve covers.
"If it ain't broke, hit it with a hammer, then fix it.." |
03-23-2010, 09:57 PM | #1078 |
Resistance is Futile
Hey DW, why did you put a spacer on the bottom of the airspring?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
03-23-2010, 10:26 PM | #1079 |
Shlong Bed Club
i dont have any kind of notch yet and wanted the frame to hit the axle bumper at about the time the bag is aired out. I'll make new lowers once i have time and money to do a notch. maybe even a behind-the-axle bag mount...
"If it ain't broke, hit it with a hammer, then fix it.." Last edited by DWright; 03-23-2010 at 10:27 PM. |
03-23-2010, 10:48 PM | #1080 |
thats soooo sick
1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
03-24-2010, 02:41 PM | #1081 |
Finally have gotten around to putting on the new heads. Haven't cranked it yet, but it should be good.
Slowly but surely getting it done. |
03-24-2010, 05:08 PM | #1082 |
After I shoveled the snow off the driveway I was able to spend a little time in the shop working on the grille. Cut the stainless tubes to length, made the center bracket, and mocked the parts together for a sneek peak of how it will look.
Now I need to tap the tubing o.d. to put it in tension to keep everything tight.... Last edited by lakeroadster; 03-24-2010 at 07:13 PM. |
03-24-2010, 06:20 PM | #1083 |
Senior Enthusiast
That looks great. So how are the tubes going to be retained, with screws threaded into each end? Just curious.
03-24-2010, 06:41 PM | #1084 |
At this point I think one end will have a flat washer welded to the tube, the other end will have the o.d. of the 3/16" tube die cut for 10-32 theads. Then they can be tightened from one end. That's the plan anyway....
I want to keep each tube separate, thus allowing removal and replacement in the event I hit a jack rabbit.......... Long story but I hit a Jack Rabbit about 3 years ago... did $1500 worth of damage. Damn thing bounded across the road, jumped up and went through the grille and into the radiator..... freakin' thing was the size of a beagle! Blood, guts and rabbit fur all over the front end and the windshield. From now on you can just call me Elmer Last edited by lakeroadster; 03-24-2010 at 06:43 PM. |
03-24-2010, 07:48 PM | #1085 |
Lakeroadster, very nice work on the grille. Clean, simple, & custom!
03-24-2010, 11:03 PM | #1086 |
Got the rear end back together after new c clips and wheel cylinders, removed all the crappy old wood and strips from my bed and pressure washed years and years of dirt and gunk from the frame, tomorrows plan to clean and prep the thing for the new wood and get the RH bed side swapped out !!
03-24-2010, 11:53 PM | #1087 |
I rebuilt the heater box new core new seal de-rusted the doors and painted em, got it back together and only need a plastic piece that broke on outer door luckily Classic parts has em in stock so I ordered one.
I also cleaned inside/out all the ac/heat ductwork reglued the upper original dash mat that always fall down on ends with some 3M spray trim adhesive and after it tacks up good and pressing in together it is really attached good now. Ordered blue carpet and oem style underlayment. Only really need front section back is in good shape still. Still need new oem style seat cover, redo headliner, paint nos black door panels blue and nos grey dash pad needs blue paint. Need finish up wiring harness paint nos fenders, paint (used) doors and install nos weatherstripping, assemble front end, get new windshield and either get a lock for rear slider or get new back glass. Whew sounds like a lot. I still need install Eddy heads and Lunati retro roller but thats gotta wait I need a truck asap. Last edited by HOGDADDY; 03-24-2010 at 11:55 PM. |
03-25-2010, 12:10 AM | #1088 |
I painted some wheels. Just as I was putting the 2nd coat on one of the rear wheels, the rattle can tip clogged & blew out a slug of paint. I had to stop for the night & will now have to sand out the resulting runs (plural!) before moving on.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-25-2010 at 12:11 AM. |
03-25-2010, 12:14 AM | #1089 |
Well, the snow's all but gone, so I thought I would wake up the old girl. Been sittin' about 8 years on a sand bar out back.
Put on wheels and tires with air in them, freed up the brakes and dragged her out, ready to trailer to the shop.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
03-25-2010, 12:54 AM | #1090 |
Ridin' Dirty
Went and got a load of water for the acreage with the 1990 Crewcab, then I swapped out the drivers side seat belt from a parts truck for my crewcab, then I drove into town on E with a full gerry can in the box just to see how far the gas gauge would go down before running out. It got to reading 1/8 tank when I sloshed the gas turning a corner when it started sputtering. Anyway I put 66 liters in a 70 liter tank after that. I guess 4 liters don't do much good when they're spread out over a 6 foot long saddle tank..
After that, my wife called me to come see why our 02 Suburban was making a grinding noise which also made the steering wheel vibrate when she turned into a parking stall at Superstore. I told her not to drive it and that I was on my way to look at it. When I got there, I found a huge glacier formation behind the drivers side tire which was rubbing the tire on the solid ice and was strong enough to prevent it from turning very far. Then I fixed it and stubbed my toe.
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
03-25-2010, 01:08 AM | #1091 |
Ridin' Dirty
I believe you! I saw something run (hop) out from between two parked cars a few years back, I didn't have anywhere to swerve on a narrow street and ran it over. It felt like I had ran over someones dog! So I turned around to check on it and saw that it was half a rabbit that was half alive.. Anyway, I did him a favor after that.. It may have involved a 235/75/15..
03-27-2010, 12:28 PM | #1092 |
Well.... last coat of bondo on the wheel tubs that I made, who am I kidding prob. needs another coat! Some of the holes on the lower flange don't line up - thats typical when you modify everything. I'll relocate them and hopefully they will be in primer soon. these were 67-71 fleetside inners that I sectioned 4" out of and bolted to a stepside. I love how they look stock- yet 20" of space allows 17"-18" wide meats on the back also installed my kenwood in the dash and all the gauge lights have been converted to blue lights to match the color of the stereo lights. It really looks cool at night. more later......
03-27-2010, 01:32 PM | #1093 |
Got my tires mounted on the freshly painted wheels. Not show worthy, but nice enough....
03-28-2010, 09:18 AM | #1094 |
Check The Champ, Demonstrator
Started the swap converting 17.5" X 5.25" original stock wheels to 17" x 6.5" wheels using original center to a new ring. 17" offers more tire variety. Their for the K10.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
03-28-2010, 11:55 AM | #1095 |
Painted my frame and now need to put wheels and bags on.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
03-28-2010, 04:02 PM | #1096 |
PROJECT 7DEUCE
Looks good sam keep up the great work.....
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-28-2010, 06:13 PM | #1097 |
I just finished hanging my door. What great fun!
I also put a new radiator in too. Cant get the 1 1/2" rad. hose onto the rad. though. WTF, it is always something.
This statement was made possible by a grant from this station and continued support from viewers like you. Flickr |
03-28-2010, 06:35 PM | #1098 |
Justified!
I welded up my rollpan.......Just have to sand it down and fill it in to make it look nice.....
Also vinyl covered my side kickpanels and installed my front speakers and my stereo deck.....
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny |
03-28-2010, 09:02 PM | #1099 |
So I have not posted in awhile but managed to get some work done to the truck yesterday and wanted to show the progress. Here ya go. The funny thing about it all was at the end ofthe day I took the truck around the corner and a hose clap from the transmission line came loose and I lost almost all of my tranny fluid while pulling in the drive way. Perfect ending to the perfect day! :
03-28-2010, 09:29 PM | #1100 |
Backed it out of the garage for the 1st time this year after installing 4" drop springs in back and about 4" inches in front with drop springs and spindles.
