View Poll Results: If you had the option, which of these grills would you use?
Original 66 painted grill 1 20.00%
64-66 C60 painted grill 2 40.00%
an original aluminum grill that needs to be restored 2 40.00%
the repo aluminum grill that is now available 0 0%
Voters: 5. You may not vote on this poll
Old 09-19-2025, 01:16 AM   #1076
350TacoZilla
Re: pdx-sanity66
I've just always used the garden hose kits that go in the heater hose and take the thermostat out to circulate it. I've heard of guys using CLR or white vinegar but thats if you have flow, do you have 0?
350TacoZilla is offline   Reply With Quote
Old 09-25-2025, 02:03 PM   #1077
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Originally Posted by AussieinNC View Post
When you replaced the water pump, did you buy the correct one for the serpentine style system?
The serpentine pumps rotate the other way....
I owe you a big apology for not listening to you about the pump. I thought I was buying the correct pump and that is what I asked for at my local parts store. (Damn, I hate those places, and this is one reason of many that I hate dealing with them) and the pumps look identical from the outside. I removed the pump and verified that it was the wrong pump. So, when I took it back, I had a few choice words for the guy that led me astray and I got my money back. I did not want to deal with them anymore so I went to a different store and bought the correct pump. guess what? I now have circulation.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 10-09-2025, 01:36 PM   #1078
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
My Sanity has left the building. I got everything put back together and took a test drive around my neighborhood and everything worked. I need to test when the weather is HOT, but it works. There were times I didn't think I could get the job done because of several issues along the way. Now I have a lot of cleanup on the truck after being jacked up in the shop for awhile. So far so good.
Sanity'66
Old 10-10-2025, 02:55 AM   #1079
Braunschweiger
Re: pdx-sanity66
Glad the problems are solved and the truck is running smoothly again. Regards, Harald
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 10-10-2025, 10:02 PM   #1080
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks Herold. I've got some driving to do, and I need to do some major cleaning after this fiasco. And then there is my AC to finish.
Sanity'66
Old 10-11-2025, 01:03 AM   #1081
franken
Re: pdx-sanity66
A late reply but there are flush solutions available that may help the rust in the cooling system issue. https://www.evapo-rust.com/thermocur...-rust-remover/
I'm not endorsing the product, just using it as an example.
franken is offline   Reply With Quote
Old 10-11-2025, 02:09 PM   #1082
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks for the info b8ut I have Sanity back on the road and it is working very good. It is so good to be able to drive it again. I've got some serious cleaning to do and some finish up on a few other small projects.
Sanity'66
Old 10-21-2025, 02:02 PM   #1083
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
So, I went to put my overflow tank in but I couldn't get it back in where I had it. When I installed the temp controller, I didn't have room for the tank. I found another tank that I was able to install next to the battery. It fit really nice there. I don't have pics, yet, but I'll get some posted later along with the temp controller. Sorry, I know everyone likes pictures.
Sanity'66
Old 03-29-2026, 03:33 PM   #1084
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I haven't posted for months. During this time, I have flushed, and rebuilt most of the cooling system except for the radiator. replaced the hoses and added a new water pump. I don't know why I decided to add a new Vintage Air gen5 system to the truck at this time but I did. What a job that has been but I got it all done except making the controls talk to the ecu. So far so good, I thought.
I started up the truck and moved it from the shop to the carport with plans on washing it up.
The next morning I started up the truck. I sounded just fine, BUT, when I shifted into reverse I got a sound like something really breaking loud and shuddering. I got it started it again in park but if I try to shift out of park it was a no go and sounds terrible. So right now, Sanity is DEAD out in the yard and I'm Totally Done for now. So I guess I'm going to be needing a trans specialist at some point.
Sanity'66
Old 03-30-2026, 04:46 PM   #1085
rbruno68
Re: pdx-sanity66
That sucks. Hope you get back on the road soon.
rbruno68 is online now   Reply With Quote
