07-25-2014, 08:13 PM | #1076 |
Re: What did you do to your truck today part II.
Ebay. One used one new. Save that part number and keep an eye open. They show up approx. 4x/yr.
07-25-2014, 10:54 PM | #1077 |
Nice truck! Me likes to!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
07-26-2014, 10:32 AM | #1078 |
Put in the gas tank and rear speakers. Had to move the gas tank more to the center to get the drivers side speaker to fit. Rebuilt and installed the vent windows. Had new drivers and passenger windows remade and tinted. The old ones were just to scratched. Had the rear window tinted and installed it. Had the drive shaft shortened and balanced. Installed the drive shaft. Installed the new sun visors, outside mirrors, rear trac bar, rear shocks and ran the gas lines. Took the rear axles to get them re-drilled to 5 lug.
I think that is it. I think the only things I need to buy are wheels and tires, carpet kit, wood for the bed to go under the diamond plate, buy diamond plate and have the sides of the bed rhino lined. Still need to run the new wire harness. Install the windshield ( waiting til i put the wire harness in so it will have more ventilation and not be so hot). Hook up the stereo. Drill new holes for the seat mounts. Install the arm rests. |
07-26-2014, 01:50 PM | #1079 | |
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
07-26-2014, 05:19 PM | #1080 |
Made two tailgate "down-position chain tabs" from some scrap 1/4" box tubing.
Welded them to the tailgate end plates (which I had to drill out to get the old hacked-up tabs off). rg |
07-26-2014, 05:54 PM | #1081 |
Installed my new Grant 377 steering wheel, got horn working, hooked up backup lights and plate light.
07-27-2014, 05:02 AM | #1082 |
Epoxy primer on the recently stripped/blasted inner and outer firewall, cowl, fresh air vents, kick panels, and floors. 2K Ceramic urethane black on the firewall.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
07-27-2014, 03:58 PM | #1083 |
Finally got the motor back in the chassis. Slowly but surely things are coming around. Wife highlighted the Chevrolet on the valve covers to put a little contrast in that darn orange. Might do the water outlet in black as well. I almost melted today in the garage....... Looks to be getting about 100 today. Lasted till about 2:30.
07-27-2014, 04:03 PM | #1084 |
I have a question about the pulleys not lining up. I know when I took it apart they were ok. I do not believe there is supposed to be a spacer on the pulley on the harmonic balancer. I believe I have seen this question addressed before but could not find it. It has a press on harmonic balancer, can you pull these back out some. It looks to be on too far. I only need a 1/4". The timing mark could not be seen at the tab with it on this far either. I have normally seen the end of the balancer out just a tad so that you can see the mark in the notches. Is it permissible to pull the balancer back out a 1/4"? Its not a bolt on balancer.
Thanks for any help you can give me on this. Ron |
07-27-2014, 04:40 PM | #1085 |
I can't help you with that Ron - but your engine and chassis look great!
07-27-2014, 04:44 PM | #1086 |
Scored front and rear from an '82 on craigslist.
07-27-2014, 05:28 PM | #1087 | |
07-28-2014, 05:43 AM | #1088 |
Finished cutting/welding rust issues on bed and fenders.
Installed tailgate cables on my homemade tailgate. Got the 93 caddy tail lights installed Sanded/primed/painted bed and fenders Cleaned up and tuned up the cabin foot vents so the work right and dont look too crappy. Not all in the last day, but over the last 4 weeks or so . . but finally got it to the point I can drive it again! |
07-28-2014, 07:38 AM | #1089 |
Thanks Andice, Palf70step I know everything was ok when I took her apart so something has changed. I will call my motor guy today and see what he says.
07-28-2014, 10:02 AM | #1090 |
Ron - The chassis work and engine work are absolutely beautiful!
The pics of the cab floor in epoxy will be my inspiration since I am going to cab floor work very soon. I'm pulling some stuff this week off an 81 which has the entire front clip but it's 1" brakes. I already have a 86 5 lug rear with the bigger brakes. Do you guys know if the standard 1" front disks would work okay when paired up with a HD rear brake or not? rg |
07-28-2014, 10:38 AM | #1091 |
Thanks robber grin.
07-29-2014, 07:45 AM | #1092 |
Well going to mock up the alternator today to make sure I know which pulley is wrong. I have a three groove pulley on the motor which my engine guy says was never found on a 65. He gave me another harmonic balancer that is thicker so at least I will be able to see the timing mark. Looks like the chain cover might not be right either as it has a long tab on it.
07-29-2014, 08:10 AM | #1093 |
chevyrestoguy, i blame you for giving me the info on the vac setup,thks a ton!!!
07-29-2014, 08:42 PM | #1094 |
This just in! Some whoa!
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
07-30-2014, 11:21 AM | #1095 |
Put the hood on after finally getting some paint on it. Got the wheels force balanced along with a front end alignment. Getting closer.....
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice http://67-72chevytrucks.com/vboard/s...d.php?t=492640 |
07-30-2014, 09:42 PM | #1096 |
Slowly working on lt1 swap... Motor should be bolted up tomarrow
07-30-2014, 10:06 PM | #1097 |
Picked up a York compressor for install. Had a local heavy truck shop make up a hose that went from the ac type connection to a 3/8 pipe thread.
07-30-2014, 10:09 PM | #1098 |
07-30-2014, 10:23 PM | #1099 |
I paid $50 extra for candy blue. After throwing $1000 at it what's not to do it!?! Braided lines included.
07-30-2014, 10:35 PM | #1100 |
I bought the grand slam kit with 2/4 drop as well as shock relocators and adjustable track bar.
