Old 09-23-2013, 08:37 AM   #1
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
More progress on the gate.
mcbassin is offline   Reply With Quote
Old 09-23-2013, 08:45 AM   #2
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
I did find out I can straighten the majority of bow out of one of these gates, however I didn't take any pictures. It involves a hydraulic jack, several boards, and a Suburban. I still need to get some finished pics but I'm pretty happy overall.
More:
Old 09-23-2013, 10:59 AM   #3
jlsanborn
jlsanborn's Avatar
Re: 1969 Short Wide
That gate needed some love! Nice work!
How did you lift the cab and how heavy do you think it is? I have mine finished, ready for paint and now I want to pull it from the chassis WITHOUT hosing it up.
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 09-23-2013, 11:21 AM   #4
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks, I have a bunch of time in it. Too much time, but I really wanted to try to save it. I'm going to get some better pictures of the finished product. You cant really tell how straight it came out from what I posted. I did have to use some filler to get it to look good but nothing like the 3/8" that was on the orange gate.
On the cab, We used an engine hoist/lift with a 6" x 2" Cee perlin. Shown HERE on my friend Crash_OK's 69 K-10 project. I borrowed his hoist and he helped me test fit it. It won't be long I will be putting it back on my frame for final test fitment.
Old 09-23-2013, 11:28 AM   #5
jlsanborn
jlsanborn's Avatar
Re: 1969 Short Wide
Thanks for the link! I was worried it might be too much weight on the pinch welds. By the looks of that cab I'm sure you wouldn't have risked it if you felt it was sketchy.
Old 09-23-2013, 01:47 PM   #6
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Originally Posted by 68 Four on the Floor View Post
Looks good. My step gate has too much rust for me to consider using so im going with an aftermarket smooth one. Ill only have 3 pieces of aftermarket steel on my truck with the rear cross sill and the cowl hood. Keep up the good work Mike
Thanks Drew. I have seen several of the step gates for sale. Those are far easier to come by, they made them for chevys up till 1987. If you look around I bet you can find a nice one.
No problem. Mark has moved his several time with this bar and no issues. I wouldn't do it with the extra weight of the doors though. I my look at bracing just to be sure it can't buckle. Now you have me nervous about it.
Old 09-23-2013, 11:26 AM   #7
68 Four on the Floor's Avatar
Re: 1969 Short Wide
68 Four on the Floor is offline   Reply With Quote
Old 09-23-2013, 07:27 PM   #8
Re: 1969 Short Wide
yea they are the same from 54-87. Im not a fan of the block lettering tho So im gonna get a smoothie and do some customizing.
Old 09-23-2013, 09:13 PM   #9
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Here's some of the tools I've been using to straighten and sand my panels.
My next project is getting all the cab stuff mocked up before painting. I really don't want to forget to weld something then after paint it's too late.
I started with the brake and parking brake assemblies, blasted epoxy primed and painted.
Old 09-23-2013, 09:40 PM   #10
big_al_71
big_al_71's Avatar
Re: 1969 Short Wide
Great progress!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-23-2013, 11:04 PM   #11
Bennett68C10
Bennett68C10's Avatar
Re: 1969 Short Wide
Awesome job on the tailgate Mike
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 09-23-2013, 11:32 PM   #12
El Campo
El Campo's Avatar
Re: 1969 Short Wide
How do you like that longest Dura Block? Is it necessary do you think or did you rarely use it? Have heard varying opinions about it
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 09-23-2013, 11:55 PM   #13
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: 1969 Short Wide
It's really cool to see you back on this again, Mike.
Zoomin is offline   Reply With Quote
Old 09-24-2013, 09:04 AM   #14
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Originally Posted by big_al_71 View Post
Great progress!!!!
Thanks for checking in Al!
Thanks Keith, It turned out pretty good. I can't seem to get any good pics with my phone or camera though.
The longest one is 30 inches. It's a must have. You don't think it's necessary till you try it. It makes it a lot easier getting long areas of filler blocked out. I have been doing a skim coat on all my panels and you would be surprised how wavy the GM sheetmetal is, even with original paint and no filler. I use the long one on bare metal to show the high points so I can hammer and dolly them too.
Second most used block is the 16" I think. I will measure it. I used to use it all the time till I got the 30". This one you can buy pre cut paper for, that's handy.
I use 80 grit paper on a roll for almost all my prep and filler. Once I get to start blocking I'll start with 240 grit and work my way up to 600 wet.
Thanks Steve. I never stopped, just slow to update. Life gets in the way of my progress sometimes. I'm not fast like Kyle either. I'm getting close on the panels. All pieces are in epoxy or high build except the inner fenders.
Old 09-26-2013, 04:17 PM   #15
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 1969 Short Wide
Amazing work on that gate Bro, you are a talented man. Wish we were neighbors so I could talk you into helping with mine! LOL
--Josh
Old 09-26-2013, 05:54 PM   #16
jlsanborn
jlsanborn's Avatar
Re: 1969 Short Wide
Great updates and nice job on that gate!!! Your an artist man.
Old 09-28-2013, 01:59 PM   #17
P-DAWG'85
P-DAWG'85's Avatar
Re: 1969 Short Wide
[IMG][/IMG]
P-DAWG'85 is offline   Reply With Quote
Old 09-28-2013, 02:04 PM   #18
FL71C10
Re: 1969 Short Wide
Looks good Mike. I'll bet your glad to see it going back together!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 09-29-2013, 12:47 AM   #19
67c10rustbuket
67c10rustbuket's Avatar
Re: 1969 Short Wide
Originally Posted by P-DAWG'85 View Post
[IMG][/IMG]
X100 Always awesome quality work and Mike is a great guy and very humble in person too. I always come back to his thread when I need to find the right way to do something. I am going to start a petition to add a sixth star to this build
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 09-30-2013, 08:19 AM   #20
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Josh, I would help you if I could.
Thanks, I think it will turn out pretty good, considering how rough it was starting out.
[IMG][/IMG]
Thanks P-Dawg that's a very cool picture.
Thanks I can't wait to start putting it back together.
Originally Posted by hgs_notes View Post
I haven't commented on your thread before but I've been following along. You're in that real tedious stage where progress gets slow and it takes more hours than you ever plan for to get it where you want it. Just keep pushing through. End of the year is creeping up fast.
Thanks for following along. Tedious is a good word for it.
Hear that! "How perfect is PERFECT?" "How much did that gray juice cost again!?" McB is looking like a pro here. It's gonna look ( . )( . ) when he's got it in paint. Ima want details when the color and clear goes down. He's obviously done a little body work before. Painting it in the same shop? Fun-dome and fans?
Thanks I can tell you it won't be perfect! gray juice? Yep I have done a bunch of bodywork back in the 90s, I got burnt out on it and quit doing these old trucks. It's easy to see why when you spend as many hours as it takes. I hope to be painting the final coats at my friend's paint booth. I have thought about building a small booth to paint the inside of some of the panels though.
Thanks for the nice compliments Dan.
Old 09-28-2013, 05:59 PM   #21
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: 1969 Short Wide
hgs_notes is offline   Reply With Quote
Old 09-28-2013, 08:40 PM   #22
jlsanborn
jlsanborn's Avatar
Re: 1969 Short Wide
Old 09-30-2013, 08:44 AM   #23
Low Elco
Re: 1969 Short Wide
You been doin' the Lord's work! We put a Repop gate on Yeller, we've dented it twice and are considering finding an OEM gate. Lotsa good work here! I looove my Durablocks but found them too flexy on the long panels, so I taped a 2x4 to the back of my longest one, worked like the bomb! You shooting this at Kyle's?
Low Elco is offline   Reply With Quote
Old 09-30-2013, 09:14 AM   #24
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Good luck finding a nice OEM gate. They are hard to come by!
I have had real good luck with my long board. It works great on the long areas.
I hope to shoot it in Kyle's booth. I want to get the inside panels all painted first so all I have left is the final outside painting. But I may end up doing all of it there? It really depends on how busy he is when I'm ready. The real problem for me is I have no where to store the finished panels except on the truck. I have some other stuff going right now that's keeping me from finishing the cab for paint. Always some kind of delay.....
Old 09-30-2013, 09:19 AM   #25
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
This has kept me busy the last week or so:
Still have some work to do but it will work for transporting my panels.
It needed a bunch of work.
