#1101 |
Active Member
![]() Join Date: Oct 2009
Re: What did you do to your truck today?
.....one more pic.
#1102 |
C10 CLUB Y QUE!
Looking good Steve 64
#1103 |
Active Member
Thanks Sick5, I'm havn' a blast with this thing, it's like a disease, all I want to do is work on the truck!
#1104 | |
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
#1105 | |
C10 CLUB Y QUE!
sometimes just need to sit back and enjoy the view |
#1106 |
mounted new front rims and tires on the dually, now I have tubles all the way around. Have been working on the 9 year olds MG so all my extra time is going to that.
![]() 71 GMC Long Bed, 454,factory everything, lowered, and shaved. 64 GMC Short Bed (great grandfathers truck) 65 Chevy 1 ton Dually a/c p/s p/b v8 auto 89 Jeep Cherokee 3" lift 79 MG Midget (My 7 year old vehicle) 29 Ford Model A Rat Rod (in the works) 86 pontiac fiero 2.5 manual18 year olds) 87 pontiac fiero SE 2.8 auto (18 year olds) 90 Mitsubishi eclipes turbo AWD (18 year olds) 69 BMW 1600 (wifes toy) |
#1107 |
Finished updating my grille: Stainless grille bars and chrome headlight Bezels.
Here are the before and after shots. More details on the grille in my build thread. |
#1108 |
I'm diggin' it.
#1109 |
1 thing at a time is progress.
Got the fan shroud fabbed up today.
Alan
Philippians 2:14-16 |
#1110 |
Senior Enthusiast
Nice improvement. Looks really custom while also looking almost stock.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#1111 |
I smoothed my firewall and fixed minor holes in the floor. I also installed my sway bar and ram style exhaust manifolds.
#1112 |
Care to share info on the radiator?
#1113 |
I started correcting the weak link on my home-made c-notches. My build thread has been updated w/some pics too.
#1114 |
Alan
#1115 |
Thanks. I'm likely going w/the Summit brand just trying to determine exactly how they look/fit. Is that p/n w/the internal trans cooler?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-04-2010 at 10:40 AM. |
#1116 |
Yes and the price when I bought it was $211.95
Alan
#1117 |
![]() Join Date: Sep 2006
This is my mock up of the Summit Radiator.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#1118 |
It looks like you just welded in that upper radiator 'retaining' plate? If that's correct, how does the radiator slip into place & stay secure?
#1119 |
Member of the longbed union.
Scoti It looks like it's the the ends of the radiator that's welded and not the plate. I like his idea, just courise as to how he's going to retain it.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#1120 |
Resistance is Futile
Looks like it will bolt in and hold the radiator in place. That's clean Fleetside
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#1121 |
I drilled holes in the holder and the side covers hold it in place. The truck is apart so I really can't take any pictures of it at this time. I was going to drill some small holes on the back side of the radiator bracket and put some small screws in the backside to hold it to the hold down. I also removed the lower mount brackets and used long bolts so I could move the radiator up. I might have something bent for the lower also. It i all up in the air. I have since painted the hold down but some dirt got in it. Still dosn't look to bad. Either that or have a Stainless one bent up. The one in the picture cost me $7 at the heating and air place and a stainless one is about $21. I think this pictures shows the back lip on the radiator.
#1122 | |
#16876
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
#1123 |
meowMEOWmeowMEOW
This weekend I did my seasonal oil change and battery charge. Changed the trans pan gasket and gave it new fluid. Cut and mocked up my lf patch panel and did a little dent repair.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#1124 |
This weekend I drove mine to town and got a truck load of mulch. I got home with it and the nephew came over to help me shovel it out. Spent most of the rest of the day getting on his @$$ for being too rough on the bed floor with a rake.
![]() The load of mulch mad the back end of my truck set even with the front....I kinda liked it...made the wheels in my head start turning. ![]() |
#1125 |
