Old 02-07-2012, 02:32 PM   #1126
mcbassin
Still Learning
mcbassin's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Brother you got some SKILLS! Awesome work on the lines like the crossmember fix....too bad on the P.C.
mcbassin is offline   Reply With Quote
Old 02-07-2012, 02:44 PM   #1127
dammitmitchell
the pollock
dammitmitchell's Avatar
so what's the plan for the underbody when done?
and im jealous!. if i left all those welds unsealed like that here by the end of the day theyd have surface rust from the humidity..
(rush isnt a real issue here.. just surface rust)
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 02-07-2012, 03:24 PM   #1128
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
Thats what i was wondering too.... Well Friz whats the plan?
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 02-07-2012, 03:47 PM   #1129
Frizzle Fry
Frizzle Fry's Avatar
Thanks dudes. I have some tintable Raptor Liner for the underside. Will be body color.
Frizzle Fry is offline   Reply With Quote
Old 02-07-2012, 04:09 PM   #1130
Frizzle Fry
There's little bit here and there. Amazing it's not worse here in Oregon!
Old 02-07-2012, 04:34 PM   #1131
Jvsapp
Jvsapp's Avatar
dang FF those lines are clean! i deal with salt spray here. i live within a mile of the ocean. i grind something 1 hr later it's flash rusting... the next day it's already got some pitting going on. that's why i sandblast and straight into the oven.
Jvsapp is offline   Reply With Quote
Old 02-17-2012, 02:32 PM   #1132
shearjs
shearjs's Avatar
Awesome work ff!! You just made my previous 2 days at work much more enjoyable. Can't wait to the finished product!
shearjs is offline   Reply With Quote
Old 02-28-2012, 12:14 AM   #1133
Frizzle Fry
Update
Been workin on some of the loose ends. Getting very close to paint! Just a couple more fab items left.
Got the fuel tank all sealed up-
Weapons of choice:
Before:
Sudsy (Marine Clean) :
Cleaned Inside:
and out:
Metal Ready in/out (drying) :
POR-15 Tank Sealer Inside:
Regular POR-15 Outside:
Before:
After:
Old 02-28-2012, 12:26 AM   #1134
Frizzle Fry
Also made up a plenum/duct for the heater. This universal heater is becoming very specific...
The problem is that I can't mount the fan/motor assemble with the heater core under the dash. There's just no good place to package it together. So I split them up. You may have seen the fan mounted on the PS of the eng. comp in earlier pics.
In doing so I created another challenge; directing the air into the heater core. There is a space between the two that must be gapped with a plenum.
Here's the solution:
Moved the fan opening over about 1.25"
Flange on inside of firewall:
Location from other side:
Captive nuts:
View of gap between firewall and heater core:
Bridging the gap. I used posts to solidify the location/relationship between the core box and the flange:
Then filled in the blanks with sheet metal and painted:
Old 02-28-2012, 12:43 AM   #1135
VA72C10
VA72C10
VA72C10's Avatar
Nice!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-28-2012, 01:50 AM   #1136
mcbassin
Still Learning
mcbassin's Avatar
Love the work on the tank and plenum FF. they look like they came original like that.
Old 02-28-2012, 05:27 AM   #1137
Jvsapp
Jvsapp's Avatar
FF how does one get the tank liner in? just pour and swish it around? looks good i'm wanting to do the same.
Old 02-28-2012, 11:11 AM   #1138
67cheby
67cheby
67cheby's Avatar
great work !
67cheby is offline   Reply With Quote
Old 02-28-2012, 03:06 PM   #1139
Frizzle Fry
Originally Posted by VA72C10 View Post
Nice!!!
Thanks!
My Plan is verking...
You pour it in, tape off the big hole, and roll it around SLOWLY. Every angle and direction.
Originally Posted by 67cheby View Post
great work !
Thank you! More to come this week!
Old 02-28-2012, 04:50 PM   #1140
pickup67man
pickup67man's Avatar
This is still a universal heater for anyone with a 66 Sunbeam Minx with a Honda S2000 drivetrain and custom firewall.
Travis
2005 K2500 Duramax (hauls the junk home)
1967 Chev C10 (hauls a$$)
1970 Suburban (Yukon XL 4 door)
1968 GMC 3/4 ton (sheetmetal only, chassis gone)
2005 Malibu (wife's car, still a Chevy)
Project Family Hauler
New Home for Chevys (Moved in and working)
pickup67man is offline   Reply With Quote
Old 02-28-2012, 09:46 PM   #1141
CParnell
CParnell's Avatar
Just found this thread and read it from the star to the end. Incredible man, just wow.....
Keep up the good work.
1968 GMC 910 Project Tommy
1974 Olds Cutlass
CParnell is offline   Reply With Quote
Old 03-01-2012, 12:32 PM   #1142
Frizzle Fry
true dat
Yeah buddy! Was back at it last night. More to come today
Old 03-01-2012, 01:26 PM   #1143
cam.man67
cam.man67's Avatar
I can't wait! I've loved following this build!
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 03-02-2012, 12:46 AM   #1144
Frizzle Fry
Here you go. Nothing major, but little by little...
Fuel filler spout received the same treatment as the rest of the tank (sealer inside, regular POR out). Here's the tank with the pump installed and the spout with new rubber and OG clamps:
...removed all the brake/fuel lines, clutch and brake MC's, and pedals.
Another loose end to tie up was the throttle pedal. I have not been able to install it since the firewall/tunnel was closed in. The design of the pedal pivot required it to be inserted from the right side. That was no longer possible as is:
So I cut the pivot rod on the inside of the right pivot point (the right side will take ~90% of the stress), drilled, tapped, and welded a bolt to the removed side of the pivot:
Result:
Next, this little guy was the final remaining hold-out for closing in the firewall completely:
...that's as far as I got today (only had about 5hrs).
Old 03-02-2012, 11:53 AM   #1145
Hart_Rod
Hart_Rod's Avatar
Everything looks great Mike! Almost there......
Hart_Rod is offline   Reply With Quote
Old 03-09-2012, 08:19 PM   #1146
Frizzle Fry
Heck Yeah Rob!
The local paint shop (Quality Paint Products) is having a hard time cross-referencing this blue into a "mix code." Here's what I have so far:
VITON HALF-HOUR ENAMEL
COLOUR CODE: 95
DESCRIPTION: Kingfisher Blue
Crown BERGER REFERENCE: 404.2164
PART NUMBER 1 LITRE: 75242865
Looks like we're just going to do a color match.
Old 03-10-2012, 02:24 AM   #1147
JRE
You could always take a small piece with original paint on it and have them scan it with there spectrometer gun to get the paint formula.
JRE is offline   Reply With Quote
Old 03-10-2012, 11:45 AM   #1148
Frizzle Fry
That's what I meant there:
But it's not an exact science; usually not a one step deal. You get close, spray it, go back and tweak the formula, continuing this way until its right. That's why it's worth the effort to find the factory data if possible.
Old 03-10-2012, 12:10 PM   #1149
JRE
Yes true. I've always had good luck with Rainbow paint. Just got done stripping a really bad primer job off a 58 VW 23 window micro bus with oven cleaner then buffing it out and fixing some bad body work and spotting it in.
Old 03-10-2012, 03:14 PM   #1150
mcbassin
Still Learning
mcbassin's Avatar
Great work on the throttle setup. Looking forward to the custom paint matching.
