04-04-2012, 11:31 AM | #1126 |
Re: Make it handle
Oops, one more, I like the early mustang spring 67-70, it's wide, smooth, and very close to the right sping rate for older p/u's.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
04-04-2012, 03:17 PM | #1127 |
Re: Make it handle
Rob very interested in your new front suspension for my 68 GMC. If you could send me a bunch of info and pics that would be great. Its time to change it up as now is the time since I'm doing the LS swap. Can't wait. Talk to u soon!
04-04-2012, 10:27 PM | #1128 | |
Re: Make it handle
I will be installing the trailing arm suspension on my 57 Chevy Truck and would like to know about the bend in the arms too. As for mounting them do you have to angle them in toward the center of the vehicle like the orginal set is...or can you make them straight. And attach them to the outside of the frame?? Kinda like this. http://67-72chevytrucks.com/vboard/s...1&postcount=59 http://67-72chevytrucks.com/vboard/s...4&postcount=52 Thanks
Better to have it and not need it, then to need it and not have it. Fork In The Road....Cummins Build My Build Thread... Alternative A/C Mounting for LS Engines 4L60E Transmission Rebuild Info Trailing Arm How To |
04-05-2012, 11:37 AM | #1129 |
Re: Make it handle
The bends in the factory traling arms were all about packaging. The factory needed a pad for the spring that would be parallel to the chassis, for easy mounting. It was cheaper to bend the arm, than to make a mounting plate with an angle. I'm not so sure about Trailing arms on a 55-59, the chassis is 34" wide, and the arms may contact the frame rail if the truck sits low. Again, packaging comes into play here. Kicking the rails up could help.
04-05-2012, 11:41 AM | #1130 |
Re: Make it handle
Thanks for the interest. Our new C-10 Wide Ride IFS is ready to go. - I've done my best to keep this thread on the tech info, and not sales, so i'll post up all the info in the 'Suspension Marketplace' on a new thread.
04-05-2012, 11:50 AM | #1131 |
Slots go on anything!
Re: Make it handle
Rob, can you give me a recommendation on a front spring for my truck? I have a '74, static lowered about 6/8. I am swapping in an LS, and will be putting a 1 1/2" sectioned crossmember in. It has a 3" spindle and 1 1/2 coil cut in the front currently. I would like to upgrade the handling somewhat in the future, but still keep the functionality as well. Since I will have the whole front apart, now would be a good time to swap the spring from the 38 year old ones in there now. Any ideas?
1974 Jimmy- 5.3/4L80e/NP241 |
04-05-2012, 11:58 AM | #1132 | |
Re: Make it handle
Thanks Rob...Did you happen to look at the links I provided in my other post??
The trailing arms they are using are not the conventional type like on the 63-72 year trucks. His are mounted on the outside of the frame. I was wondering if it is better to mount the arms closer together under the truck going to a crossmember or if his method will yield the same results?? I will not be bagging my truck it will be a DD and I might take it out to the Good Guys auto cross at TMS in the near future. Also what was the factory bend?? 15* (degrees) Thanks Quote:
Better to have it and not need it, then to need it and not have it. Fork In The Road....Cummins Build My Build Thread... Alternative A/C Mounting for LS Engines 4L60E Transmission Rebuild Info Trailing Arm How To Last edited by ambryatim; 04-05-2012 at 12:03 PM. |
04-05-2012, 03:11 PM | #1133 | |
Re: Make it handle
We are trying to get Ibach to make some springs, but it's going very slowly. I still like the 3/4t spring with a coil cut. Sounds like a cool truck, The weight difference of the ls swap won't be that noticable.
04-05-2012, 03:15 PM | #1134 | |
Re: Make it handle
Yes, I looked at the threads, those really arent trailing arms, as there are upper triangulated links as well. For trailing arms to work, they need to pivit from close to the center of the truck, so that the rear axle can tip, or articulate, without binding. Mini truckers have tried the '2-link' idea, two long bars on the outside of the chassis, mounted solid to the axle, and a pivit forward on the chassis, - and most learned that this is a bad idea.
04-05-2012, 04:14 PM | #1135 |
Re: Make it handle
^^^^Thanks for the info. So how do you think these would work over the oem style arms??
http://67-72chevytrucks.com/vboard/s...d.php?t=387475
04-06-2012, 07:30 PM | #1136 |
Re: Make it handle
Making adjustable arms can be a big help in tuning. Stock non adjustable arms make it difficult to 'square' up the rear axle. With adjusters in the ends of the trailing arms, you can set the rear perfectly square to the centerline of the truck, and hopefully the front axle centerline. - if it's in the right place.
04-06-2012, 07:43 PM | #1137 | |
Re: Make it handle
04-07-2012, 11:34 AM | #1138 |
Re: Make it handle
WOOO HOOO !!!! Wow, 100,000 views!!! Thats friggin cool!!! Thanks guys for keeping the interest up !!!!!!
04-07-2012, 11:35 AM | #1139 |
67cheby
Re: Make it handle
ummmm...you make it pretty easy for us to stay interested !
04-07-2012, 12:05 PM | #1140 |
Fun Stuff
Re: Make it handle
X2, Thanks Rob!
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd |
04-07-2012, 12:32 PM | #1141 |
Re: Make it handle
It's edge ba cation that even I can understand.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
04-08-2012, 10:25 PM | #1142 |
Re: Make it handle
Rob, maybe it was covered earlier, but is there a difference in handling between a setup like abadsvt's setup and a standard 4 link? Mine will be like this only using the Corvette IRS. I love the looks, but is there an advantage?
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
04-09-2012, 01:56 AM | #1143 |
Re: Make it handle
Rob, any suggestions on air bags? I don't want to go with ART because of price. I'm leaning towards Slam Specialties RE6 (rear) and RE7 (front) because of the thicker walls versus the Firestone 2500 and 2600 I've been running, any input?
04-09-2012, 11:01 AM | #1144 |
Re: Make it handle
I had those same bags on my '69 and they were awesome. I would not run any bag but the Slams.
04-09-2012, 12:08 PM | #1145 |
Re: Make it handle
Are you talking about the 'Cantalever, or Rocker-arm' for the shockwave? If so, there can be some advantages if done correctly. If you are using an IRS, then a cantilever can help out a lot with clearance issues.
04-09-2012, 12:11 PM | #1146 |
Re: Make it handle
The RE7 is a great bag for the front of C-10. I know everybody uses the 2500 style on the rear, or RE6, but i really like the 9000 style slider bags. They will run at a higher pressure at ride hieght, appx 70 psi, and have a smoother ride.
04-09-2012, 12:27 PM | #1147 | |
Re: Make it handle
I am also looking to use the Select Ride series for comfort/performance select on the fly.
04-09-2012, 04:43 PM | #1148 | |
Re: Make it handle
Thanks again, Brendan Last edited by leftcoast66; 04-09-2012 at 04:49 PM. |
04-10-2012, 11:29 AM | #1149 | |
Re: Make it handle
04-10-2012, 12:20 PM | #1150 |
A guy with a truck
Re: Make it handle
Rob, any info on installed dimensions on those f8000s? Can't seem to find them online...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
