Closed Thread
Old 06-06-2015, 03:03 PM   #1126
OldChevy61
OldChevy61's Avatar
Re: What did you do to your truck today part III
Got the pistons and crank out of the block. Headed to machine shop Monday morning.
OldChevy61 is offline
Old 06-06-2015, 05:59 PM   #1127
blown240
blown240's Avatar
Today I found why my truck was Missing, and i put some new exhaust gaskets on it. Not its got a pretty good tick in the motor though....
Pics
LOL, Anybody want to guess why it was missing?
New exhaust gaskets!
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline
Old 06-06-2015, 06:51 PM   #1128
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Lost my storage for the 63 yesterday, The new owner of the building where the truck has been stored for years called and wanted it out immediately. Not even a days notice. Ended up in the driveway yesterday in the rain. Called around while the truck was getting soaked and found a place for now, till the new garage is built. Thank God for old contacts.
aerotruk63 is offline
Old 06-06-2015, 07:38 PM   #1129
kepi
kepi's Avatar
Took her to her first car show. Didn't win anything, but got a lot of good complements. Mine was the only 60 - 66 truck in the show. The big red truck next to mine won in the truck category.
kepi is offline
Old 06-06-2015, 08:23 PM   #1130
sags
upgraded brakes - a little too low
Finally got around to the front disc swap with new master and booster.
Went with 2 1/2 inch drop spindles. Previous owner cut the springs more than I thought. Even though I love the rake, it is a little too low. Lots of good comments at the cruisin night tonight but it bottoms out quickly. Only about an inch above the bump stop. And the tires are up in the wheel wells and hit the fenders at turning. Will replacing the springs help out with this and still give me a lowered look?
Now onto some back drop springs...
sags is offline
Old 06-07-2015, 07:22 PM   #1131
Chevy Fleetside
Chevy Fleetside's Avatar
One day I made my son come and help me pull the cab from the parts truck.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 06-07-2015, 07:29 PM   #1132
OldChevy61
OldChevy61's Avatar
Got the pressure washer out and knocked some of the heaviest oil,dirt and grease off the front frame so I can see all the bolts,lol. Got most all undercoating off the firewall with it as well. Also got the motor parts loaded up to goto machine shop in the morning and just landed me a 4 speed to go behind it. Means I got a T5 I don't need now.
Old 06-08-2015, 03:24 PM   #1133
Chevy Fleetside
My new 15x8 OEM style steelies came in today...
Old 06-08-2015, 05:30 PM   #1134
The Rocknrod
Moderator
The Rocknrod's Avatar
Mounted the cab on the chassis. Sorting all the parts on my new project. Finding out what parts I need, even though I was told all the parts are there (not).
The Rocknrod is offline
Old 06-08-2015, 06:13 PM   #1135
blown240
blown240's Avatar
I got my logos on. They are the same as what the truck would have had new.
blown240 is offline
Old 06-09-2015, 09:04 AM   #1136
1963c-10
1963c-10's Avatar
Hood back on and adjusted. Completed the last hood seal last night and will get it installed tonight.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline
Old 06-09-2015, 09:49 AM   #1137
LDO
LDO's Avatar
I'd like to see how that seal goes on.
LDO is offline
Old 06-09-2015, 10:19 AM   #1138
1963c-10
1963c-10's Avatar
The two notches fit around the two rear upper latch bolts and the they just press in. I used an empty .357 shell casing to punch the holes. Does a real nice job and you get a very nice clean hole.
I ordered the gasket from Grumpys. Was less than $15 shipped and an identical to the original. Same lines and thickness. A real nice replacement.
I reused the original clips....cleaned them up and 2 coats of engine enamel.
I've got some archived pics from one cortcomp did.....and a factory diagram.
I redid all the anti squeak pads on the hood also. Pics on my stepside build thread if interested.
1963c-10 is offline
Old 06-09-2015, 12:52 PM   #1139
grizzlyoutlaw
I went shopping for my truck at the local U-Pick today. Came out with:
A new battery - time to crank up the engine and see what happens!
drivers side windshield - no more trash bag on the window!
two tires - gonna be alot easier to push around with rolling tires.
Should get all that installed today.
My 1965 C10 Build Thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=672865
Other Builds:
2014 Cummins Ram
1999 Ram Sport
2005 Frontier Prerunner
grizzlyoutlaw is offline
Old 06-10-2015, 10:10 AM   #1140
jbgroby
jbgroby's Avatar
Did these seals get used on the '60 gmc Hoods? None of the parts houses show list for a '60? I did not know if I was missing something?
jbgroby is offline
Old 06-10-2015, 10:12 AM   #1141
1963c-10
1963c-10's Avatar
Yes. Same kit as the 62-66, but there are 3 center braces on the 60-61 as opposed to 2 braces on the 62-66. The kit I used from Classic Industries came with the additional seal for the center brace even though it wasn't used for my 63 hood.
Diagram attached
1963c-10 is offline
Old 06-10-2015, 10:43 AM   #1142
LDO
LDO's Avatar
good job & thanks!
LDO is offline
Old 06-12-2015, 08:45 PM   #1143
Chevy Fleetside
I painted my wheels today. They are 15x8 oem wheels. Before and After.
Old 06-13-2015, 12:06 AM   #1144
60sIron
60sIron's Avatar
Very nice Chevy Fleetside! Did they come primed or white? Where did you get them. I'm looking for 16x8 in white 8 lug......
60sIron is offline
Old 06-13-2015, 12:25 AM   #1145
Chevy Fleetside
They were primed. I got them from Summit Racing. They are Wheel Vintiques OEM wheels. I dought they make them in 16" 8 lug but I think I saw some on craigslist.
Old 06-13-2015, 01:41 AM   #1146
markeb01
Senior Enthusiast
markeb01's Avatar
Those wheels are gorgeous! There was a time I would loved to have had a pair of those on the rear of my truck. I've always been torn though, they are so pretty bare in paint or chrome, but they are also beautiful with 57, 60, or 63 passenger car hubcaps too! What to do?!!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 06-13-2015, 10:13 AM   #1147
Chevy Fleetside
I looked at the tire and wheel thread probably 20 times. I went back and forth with OEM steel looking with hubcaps or something in mags. Finally I just pulled the trigger and ordered these. I am kinda leaning towards 65ish nova hub caps but I have time to figure that out. For not I am going to be running bullet lug bolts and I ordered some chrome dust covers for the front rotors.
Old 06-13-2015, 02:34 PM   #1148
Chevy Fleetside
Well I just bought these. We will see if I use them or not.
Old 06-13-2015, 03:57 PM   #1149
markeb01
Senior Enthusiast
markeb01's Avatar
I had those upper caps on my 67 Chevelle and really liked them as well. That's what I liked about the 63 caps, they also had the vanes or fins around them. Back in 1967 I bought a full set from the local Chevy dealer for $5 each in the factory boxes wrapped in white paper!
It all depends on the look you're after, but I find those bare wheel centers very attractive as they have gone back to the detail of what I refer to as the "hub cap clip humps" from the previous generation. Having those humps in between the lug nuts truly restores the look to the 1960's. Most of what came later where simply flat in that area, with 4 hub cap bumps. They lost the sense of style that was present in this design. I'm looking forward to seeing them on your truck!
markeb01 is offline
Old 06-13-2015, 05:16 PM   #1150
OldChevy61
OldChevy61's Avatar
Just made an 8 hour round trip to pick up a sandblaster and a welder from my brother. Never used either before, but about to self teach, lol. If it wasn't 95 degrees rite now,I would fire that blaster up. Will be early morning job for sure.
Closed Thread
