08-31-2009, 06:39 AM | #1151 |
Re: PO has me PO'd
If I hear what your saying...the pass. side widnshield frame up top is to far away?
Is that what you meant by 'longer'? If you pull back the firewall just a small amount, it would translate into a fair bit of change at the top of the windshield frame. Simply pulling the windshield back isn't the answer till you check door opening dimension's. Last edited by vtblazer; 08-31-2009 at 09:55 AM. |
08-31-2009, 09:47 AM | #1152 | |
Re: PO has me PO'd
I may try the comealong idea, see what happens
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-31-2009 at 09:50 AM. |
08-31-2009, 09:52 AM | #1153 |
Re: PO has me PO'd
What about just filling the hardtop gap with this....
Billy Mays wouldn't agree to sell it unless it was good.
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s Find me on INSTAGRAM @MIGHTASWELLK5 '72 K5 - Greg's "Might As Well™" Build |
08-31-2009, 10:09 AM | #1154 | |
Re: PO has me PO'd
Sorry, for got to add the happy face
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-31-2009 at 10:11 AM. |
08-31-2009, 10:37 AM | #1155 |
Re: PO has me PO'd
Im glad I bolted my top back on and braced everything in before i sold it! Its a pain in the arse working around the braces, but will be worth it in the end. Good Luck
08-31-2009, 06:50 PM | #1156 | |
Re: PO has me PO'd
Meant to send you a PM, but since I have your ear, how are you making out with the floorboards? Personally, I would get rid of the torsion boxes, or whatever their called these days, makes it much easier to weld up the bottom seam, and seam seal your work. Tri-Pro makes some real nice repops
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-31-2009 at 06:51 PM. |
08-31-2009, 07:04 PM | #1157 | |
Re: PO has me PO'd
08-31-2009, 07:05 PM | #1158 |
Re: PO has me PO'd
SNAFU----averted, close call!!! I found out that if you hang 200 pounds of sh!t from the drip rail, it will suck the top right down
-Greg, thanks for the idea, but I still had some leftover from the PO. He had it stuffed into a crossbrace under the bed, worked great as you can see, but the rest of the metal rusted out.LOL Found a better product, you can machine it, drill and tap it, and it really sticks to anything
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-31-2009 at 07:14 PM. |
08-31-2009, 07:25 PM | #1159 | |
Re: PO has me PO'd
Post up picks on your progress and let me know where they are...Whats that Porterbilt guy like? Post up pics and we'll tell you if they are in the right location
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-31-2009 at 07:27 PM. |
09-01-2009, 05:00 AM | #1161 | |
Re: PO has me PO'd
Your build is coming along nicely, I always watch
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
09-04-2009, 01:21 AM | #1162 |
Re: PO has me PO'd
'68 mirror installed
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-07-2009 at 02:43 PM. |
09-04-2009, 09:25 PM | #1163 |
Too Dumb To Know Better
Re: PO has me PO'd
Coming along nicely Jim.
09-07-2009, 02:27 PM | #1164 |
Re: PO has me PO'd
Thanks Doug, still plugging alongever so slowly
HEY TYNEE, what kinda shape is the external voltage regulator in??? Doesn't have to work, just need the cover to be rust free Finally got a couple hours to play with the Jimmy, after all the picnics, and annual family fishing trip! Cut the bottom off the external voltage regulator and used #10 SS panhead 1/2" screws to mount the cover Found a nice grounding strap in the HELP section, don't know why that bolt was there in the frame, everything else is riveted, but it worked for a grounding location. Now I feel a little safer continuing on with the electrical hookups Nice idea to put the notch in the battery box, makes for better access put a piece of rubber hose I sliced on the core support to act as a bumper for the wiring harness. It was tight up against it Getting closer, still have to bolt up the outside windshield mounts
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-07-2009 at 02:47 PM. |
09-07-2009, 02:39 PM | #1165 |
Can't wait to retire!!
Re: PO has me PO'd
Way to go Jim...progress is progress!
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
09-07-2009, 02:50 PM | #1166 |
Re: PO has me PO'd
Thanks Tim, but it gets frustrating sometimes just to have a few hours here and there
Got tired of prepping, sandblasting, degreasing, painting every part before I mount things up, so I'm cutting corners just to get it on the road...later I'll come back and make it purdy
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-07-2009 at 02:53 PM. |
09-07-2009, 03:58 PM | #1167 | |
Re: PO has me PO'd
09-09-2009, 12:38 AM | #1168 |
Re: PO has me PO'd
Been watching the progress. How did the ws frame get bent?
09-09-2009, 12:48 AM | #1169 |
Re: PO has me PO'd
I think the PO rolled the truck at one time, I can see where he welded it back together on both windshield posts and the vent window was bent on the passenger side...BUT, I also put new floorboards in it on both sides, so I am not ruling out the possibility that I didn't screw that up...the answer is out there, I just have to find it!
Right now I am working on a new version of the bulkhead. I never found those websites in the crate, could you resend them to me. What happened to that guy that wanted to buy the bulkhead?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-09-2009 at 01:20 AM. |
09-09-2009, 07:20 AM | #1170 | |
Re: PO has me PO'd
Easy bud, hang in there, you've made huge progress on your truck. (with a lot of great mods along the way too) Think back to where you started, yes it gets old and frustrating at times but your SOOOO close now. |
09-09-2009, 02:23 PM | #1171 | |
Re: PO has me PO'd
Just because ya can, doesn't mean ya should Future home of the PCV System Recovery and Oil Separator, and Denser Charge Apparatus
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-09-2009 at 02:27 PM. |
09-09-2009, 02:29 PM | #1172 |
Damn Yankee
Re: PO has me PO'd
what's with the "Horizontal aluminum pipe" engine mod?
09-09-2009, 02:33 PM | #1173 | |
Re: PO has me PO'd
Have you heard of any companies reproducing forward bulkheads for P/U trucks, better yet w/wood beds???
09-09-2009, 02:49 PM | #1174 |
Damn Yankee
Re: PO has me PO'd
09-09-2009, 03:45 PM | #1175 | |
Re: PO has me PO'd
The piece of pipe is for a tank, like yours, that you won't sell and don't know where you bought it
