Closed Thread
Old 08-24-2014, 12:17 AM   #1201
Turtleman
Turtleman's Avatar
Re: What did you do to your truck today part II.
Originally Posted by Chevy Fleetside View Post
I shoe horned my green truck into the garage to put a clutch in it. The thing barely moves anymore.
Well no wounder it doesn't move ... It's wedged in between all that stuff !..
Turtleman is offline
Old 08-24-2014, 10:23 AM   #1202
Chevy Fleetside
Chevy Fleetside's Avatar
On the drivers side is the outside wall and on the other side would be my bros 64 Valiant Convertible. Maybe Garage Squad would come out and finish that thing so it can get out of the garage.
I pulled the clutch last night and was suprized it wasn't burned up more. It is definatly worn out. The truck is up on Jack Stands and then we have an earthquake but was up in the Napa area and it was a 6.0. Woke me up at 3:21 this am. I haven't looked in the garage yet, maybe I should go do that...
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 08-24-2014, 09:43 PM   #1203
seabeevin
seabeevin's Avatar
installed a front sway bar on the 65 c20. rides great. all parts from the u pull it junk yard.
seabeevin is offline
Old 08-25-2014, 02:26 PM   #1204
pimpston65
pimpston65's Avatar
finally got my second offset mirror,plus a castiron arm from my burban
pimpston65 is offline
Old 08-25-2014, 02:28 PM   #1205
pimpston65
pimpston65's Avatar
castiron arms for my burban and havent seen these mirrors but ima rock em
Old 08-25-2014, 02:30 PM   #1206
pimpston65
pimpston65's Avatar
snag'd a second one for the pass. side
Old 08-25-2014, 02:45 PM   #1207
KB63/292
Got the front down this weekend, Now to start on the rear.
KB63/292 is offline
Old 08-25-2014, 09:54 PM   #1208
Chevy Fleetside
installed the clutch today. The bell housing had to come off but would not come out of the truck. It moved back enough for me to get the disc and pressure plate in. Now I can pull small hills in 3rd gear...
Old 08-25-2014, 10:24 PM   #1209
66Submarine
66Submarine's Avatar
Awesome!
BTW, the bellhousing will come out if you turn it the right way. Some guys also remove the clutch with it still in place.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline
Old 08-25-2014, 11:23 PM   #1210
Chevy Fleetside
Originally Posted by 66Submarine View Post
Awesome!
I removed the clutch with it still in place and there was no way I was going to get it back in that way.
Old 08-25-2014, 11:25 PM   #1211
66Submarine
Yeah, I also just take the bellhousing off to mess with the clutch. Some are really hell-bent about leaving it on there, though.
Old 08-25-2014, 11:48 PM   #1212
Jasons65
Jasons65's Avatar
Stared at pictures of parts that are accumulating and the truck, I'll hopefully be home this week to meet the truck in person for the first time and dig into it.
1965 SBFS BBW Soon to be Restomod Daily Driver
1972 Chevy Nova-Pro Touring
Jasons65 is offline
Old 08-26-2014, 05:39 PM   #1213
LVPhotos
LVPhotos's Avatar
I got Hosed A! Took in radiator for leakage. Been since 98 that my guy had seen it out of the truck. New hoses, actually had the one that is suppose to be in there. New T-stat, 180. Took longer to clean the mess than to install. This is the original 283 V8 radiator which is a V flow and not the cross flow. Heavy and more cooling.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 08-26-2014, 09:54 PM   #1214
Dillon Rock
Haven't posted on here in a minute. Sorry fellas but Navy engineer life has taken its toll on me lately so here's my new addition. Bought it for 25 bucks off CL, and had to chop it down to my bed size. Here's before and after. Not bad for not touching a welder in 4 years. Still have to chop it again to fit the bed rails and grind welds and then finish it in classic white.
That's the thing about a Chevrolet, no matter how they look, whether it be a trailer queen or a good ol' used farm truck, no other truck on the road will always look that damn good wearing a Bowtie.
Dillon Rock is offline
Old 08-26-2014, 10:16 PM   #1215
rickywideglide
rickywideglide's Avatar
finally got trailing arms back on with new poly bushingsName:  009.jpg
rickywideglide is offline
Old 08-27-2014, 03:13 PM   #1216
pimpston65
pimpston65's Avatar
mocked up my new stepbumper, took to the sandblaster... cant wait for shiny black paint!!!
Old 08-27-2014, 04:19 PM   #1217
pimpston65
pimpston65's Avatar
made a handy dandy rivet setting tool, needs to be tweekd, but no pounding just tight'n a screw!!! should have added a nut to the bottom threads to aid in tight'n it, but ima slot the top threads so's a wrench can do all the smashing i need!!!
Old 08-27-2014, 09:33 PM   #1218
Lugnutz65
Lugnutz65's Avatar
Flipped the cab over onto pallets so I can remove the undercoating with my needle scaler. I'll have the cab back on the frame by the end of September (I hope).
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 08-28-2014, 08:04 AM   #1219
64shortbox
64shortbox's Avatar
Another good tip for removing undercoating is to use a small propane torch apply very little heat and using a putty knife it will easily scrape right off. I did this lying under a 62 Pontiac still on the frame and with full interior in it. I was amazed how easy and fast it was to remove the undercoating. I was even using the cheap throw away plastic putty knifes because I didn't want to scratch the factory red lead primer.
64shortbox is offline
Old 08-28-2014, 10:03 AM   #1220
Lugnutz65
Lugnutz65's Avatar
I'm gonna try your method tonight. A wire wheel just smears it around when it heats up from the friction. YouTube methods like dry ice and the oscillating saw are not practical for me. I need to cut a few mm off the ends of needle scaler needles so they have a good cutting edge again. They have become a bit dull from use. Thanks for the tip.
Old 08-28-2014, 03:14 PM   #1221
pimpston65
pimpston65's Avatar
shot out to Bruce(oem4me),MiDunes,ebay. for making possible this awsome spare combo,YEA!!!
Old 08-29-2014, 06:41 AM   #1222
mark 66
I have used easy off oven cleaner. let it sit over night and then scrape it off. work pretty good. dosent get all of it but will get a lot. for some reason easy off is the brand to use.
mark 66 is offline
Old 08-29-2014, 07:04 AM   #1223
schpeen
schpeen's Avatar
wet color sand compounded and buffed
wax on wax off
schpeen is offline
Old 08-29-2014, 01:01 PM   #1224
Chevy Fleetside
I drove it down to San Jose to pick up a piece of funiture. I have been having trouble with it getting hot on the freeway so I thought I would change the thermostat. The one that was in there was sticky so I replaced it with a 160º thermostat and I have a feeling that is just to cold and won't close when the water is hot so the radiator can cool it down. The first picture shows what the temp is like when it is hot outside and the other is when I came back into cooler weather. The truck cools down alot. It was probably 80º in San Jose and about 60º in SF.
Old 08-30-2014, 06:59 AM   #1225
robber grin
Passenger side rocker and floor work. rg
robber grin is offline
Closed Thread
