#1201 |
Re: What did you do to your truck today.The 3rd chapter
After a wash and a quick cruise I started cleaning up the cross member and sway bar I grabbed off a ‘77 Scottsdale. I’m hoping to eliminate the horrendous body roll that goes along with having leafs on all 4 corners.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296 |
#1202 |
![]() Join Date: Dec 2013
Well it wasn't today but might be helpful to the guys installing M20-21-22's in their trucks . I used a new Hurst competition -plus shifter and install kit from Summit to set mine up ,Along with Paul's hardened tool steel bushings and clips . And after talking to Paul I'll be adding a tail shaft trans mount
![]() https://www.summitracing.com/parts/huu-3910002 https://www.summitracing.com/parts/huu-3737834 https://www.5speeds.com/cart/index.p...&product_id=76 Check out his website he has a lot of info on all the 4-5-6 speeds - This guy wrote the book on Muncie transmissions 5speeds,com https://www.youtube.com/watch?v=_40q7wbeoRQ https://www.youtube.com/watch?v=yaQw...PsyqqE&index=1
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 05-17-2020 at 01:45 PM. |
#1203 |
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#1204 |
#1205 |
![]() Join Date: Mar 2005
Finally getting around to the last rust area.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
#1206 |
At the body shop.
Fresh coat of penetrol
And some nanoskin wet look tire sauce
" That didnt make it any newer " " Dont antique the equipment " |
#1207 |
#1208 |
Finished up the headliner on my squarbody burban . Spray gun is older than me blinks #7
#1209 |
Landau glue. Old stuff still works the best
#1210 |
![]() Join Date: Mar 2011
nice......
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#1211 | |
#1212 |
![]() Join Date: Nov 2008
Headliner looks great. My 91 burb has needed one my entire ownership. They sell the pre-formed pad/headliner combo I was thinking about buying.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
#1213 |
Love Penetrol. Just don't lean on it real hard for a couple days haha.
#1214 |
The later cloth headliners are available mine is vinyl. Pattern called snakebite closeup of the old liner . I matched up to material used in alfa romeo
#1215 |
I didn’t know that. Yeah mine was just blue cloth. The boards are all warped anyway so may try the board/cloth pre assembled headliner.
#1216 | |
At the body shop.
It's rained on it twice the morning after I put in on. But it's coming around slowly. Going to have to paint the roof soon..
#1217 |
I drove mine yesterday, I think it developed a vacuum leak. Have to work on that. Otherwise she is doing well.
#1218 |
![]() Join Date: Aug 2015
Cleaned up the 4x4 fan shroud I bought from CUSTOM/10. I used Gunk, de-greaser and a power washer, being careful to not mar the factory finish. Will be nice when installed.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke 2007 BMW X3 2020 BMW 540xi 1995 Harley FLSTC |
#1219 |
![]() Join Date: Dec 2012
Oooooo that is nice! I just posted a thread about adding one back to mine! Looks like a real score!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#1220 |
Finally broke down and removed all the heater and controls. I’ll probably be in the hospital due to the hantavirus with all the mouse stuff in there. The outer box was completely full of leaves, acorns, and dirt dauber nests. Good news was the fan motor worked after knocking a pound of mud nests off the wheel. Bad news is the outer box is pretty much shot. Lower left corner is broken and the metal area between the fan and firewall is rusted gone.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
#1221 |
The cardboard was sagging on mine too. I dampened the top side of it and layed a few paver blocks on it in the sun. Sag came out but most likely will return
#1222 |
Replaced all the vacuum hoses, and carb fuel filter. Took it for a test drive and eliminated the rough idle while stopped in drive.
#1223 |
![]() Join Date: Feb 2011
Removed the side mount aluminum tool box and fire extinguisher bracket from the bed of my new truck....lookin' better already!
Next up....back rack & warning lights
![]() '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
#1224 | |
I just looked at mine from my garage chair today.
#1225 |
