Old 12-12-2007, 06:09 PM   #101
454HO
Re: TPI Conversion Progress/Process
Originally Posted by Captkaos View Post
hmmm, that stinks. that is the same URL as the last picture I linked... You shouldn't have to join my forum to view them as they are public accessible....
When I click the link it asks me to login. I am not a member. Maybe I should be.
- Greg
454HO is offline   Reply With Quote
Old 12-12-2007, 06:12 PM   #102
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I have linked these like this several times and didn't have a problem. I have no idea what is going on...
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-12-2007, 06:14 PM   #103
Captkaos
Captkaos's Avatar
Originally Posted by 87 STEPPER View Post
Hey Chris,
If you find that other missing water neck and i assume you are talking about a thermostat housing send it out and have it jet hot coated.
Thanks for the heads up Bruce. Now if I can find the stupid thing...
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 12-14-2007, 10:01 AM   #104
Captkaos
Captkaos's Avatar
I will fix this ASAP...
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-09-2008, 09:31 AM   #105
454HO
Just noticed your pictures are working now... looks really good.
What are you going to do for valve covers?
- Greg
Old 01-09-2008, 12:06 PM   #106
Captkaos
Captkaos's Avatar
Sunday, January 6th, 2008: "rebuilt" an '85 distributor for the motor this weekend so I can retain the current HEI hookups. Now I just need to have a connector made up to go from the 85 on the distibutor connetion to the 90-95 small connector.
What, you don't like those nasty factory paint peeling versions.. Actually I am not usre yet.
"rebuilt" an '85 distributor for it this weekend
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-09-2008, 01:32 PM   #107
phishfud
I am planning this conversion in the coming months on my 84 K10. I was concerned about doing it only because of my motor (factory replacement, non-roller). I wasn't sure how my motor would pair up with the TPI computer as far as specs go. I checked my cam specs and they are similar to a stock TPI cam, but being non roller, I didn't know how well the truck would run. Just curious if this is something I should worry about, or if there is enough latitude in the factory proms to compensate. I could always go roller and get a nice computer friendly cam, but that's way down the line. Looks like a great swap!
Terry
84 K10, 350 Auto
72 Chevelle, 454 4spd.
78 Trans Am 400 4spd
88 GTA 350 Auto
94 Cherokee
phishfud is offline   Reply With Quote
Old 01-09-2008, 02:04 PM   #108
Captkaos
Captkaos's Avatar
GM didn't start using roller cams until about 1987 on the F-body/Vettes. It really isn't an issue though.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-09-2008, 06:39 PM   #109
BaddBusa2005
BaddBusa2005's Avatar
mmm.. turbo tpi, talk about a crap ton of torque.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
Old 01-09-2008, 09:33 PM   #110
rfmaster
rfmaster's Avatar
Phishfud
You have to use a non roller Knock Sensor (KS) 10456288. Roller engines tend to use a more aggressive cam lobe ramps - thus nosier. Also, if you are using a full size HEI dizzy with non roller cam a stock iron gear should work just fine. On the other hand if you are using factory steel roller cam then you'll have to switch to melonized gear 10456413 (for 0.491 diameter dizzy shaft).
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 01-10-2008, 06:35 AM   #111
Captkaos
Captkaos's Avatar
I am hoping it will have some pep to it. The engine is basically stock and I only plan to add 5lbs to it, max of 7lbs.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-20-2010, 05:18 PM   #112
Damien
Damien's Avatar
What ever happened with this swap?
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 01-20-2010, 09:18 PM   #113
Captkaos
Captkaos's Avatar
working on the rusty body tub right now.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
