02-11-2006, 12:56 AM | #101 | |
someday it will be done!
Re: Air Ride For Dummies
What pressures you running?I'd sure like to see a pic at ride height as well whenever you can.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
09-18-2006, 11:55 PM | #102 |
Hi, cool setup...Do you have any pics of the rear bag install . i am trying to install the back bags and i dont have a cup or any thing. the air bag has two places for the bolts and on for the sir fitting. do i just drill the the three hols out and bount like that . any info helpfull or pics to. Thanks Frank
Frankmentesana@verizon.net |
09-19-2006, 02:34 PM | #103 | |
67 SWB |
09-19-2006, 02:39 PM | #104 |
BTW, this has been covered before, but anyone using Suicide Doors lower cups should consider triming them down about 1". I took mine back out and cut them, now my front cross member is maybe 1" off the ground aired out.They are way too tall as shipped.
67 SWB |
09-19-2006, 03:06 PM | #105 |
Do you have a shot of your truck aired out with the cups trimmed?
<edit> I ask because I will be installing mine this week! Also, are you running drop spindles? Last edited by jimmydean; 09-19-2006 at 03:11 PM. |
09-19-2006, 03:08 PM | #106 |
No, but if you give about 10 minutes I will go outside and take one for you. Oh, and yes I am running drop spindles, 2.5".
67 SWB Last edited by wink_tim; 09-19-2006 at 03:14 PM. |
09-19-2006, 03:33 PM | #107 |
How about these?
67 SWB |
09-19-2006, 03:37 PM | #108 |
you are running blocks in the rear too, correct? What size?
By the way, your truck looks great! I will be installing my kit over the next week or so. I am trying to do it without pulling the bed and I should be ok. I don't have a garage that my truck fits into and I would rather not have to put the bed somewhere while I get everything done. |
09-19-2006, 03:43 PM | #109 | |
67 SWB |
09-19-2006, 04:57 PM | #110 |
Mine will be a little different then the others on here, but I think everyones is a little different. I will be taking pics of mine to share as well, just in case my system helps any.
As it is I am running two lines off the tank, one for each side. My valves will be mounted on the frame under right under the cab for easy access. That way I have a shorter distance for the wires as well. Last edited by jimmydean; 09-19-2006 at 04:58 PM. |
09-20-2006, 12:53 AM | #111 |
great truck
09-23-2006, 07:04 AM | #112 |
A guy with a truck
Wink-
Want to make sure I've got this right. You are bagged in stock spring locations front and back, with a 2 1/2" c-notch correct? How far off the ground are the bumpers and pinch welds when aired out? Truck looks great btw.-Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
09-23-2006, 01:41 PM | #113 |
He also cut down the front cups (about an inch left).
I am leaving my cups as is for now and may run a small cup in the rear to start with. I can go lower if I want, but going higher would mean additional work to drive it. At this point I would be happy to be on the road again. |
09-23-2006, 02:10 PM | #114 |
the truck looks great do you have any plans for wheels
http://www.cardomain.com/ride/2461088 |
07-14-2008, 09:17 AM | #115 |
Should be a sticky.....
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
07-14-2008, 01:42 PM | #116 |
It is time to take the bed off. Got all my stuff ready.
minus the comp. switches and tank. Get that latter. Thanks for this tread
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
07-14-2008, 02:53 PM | #117 |
More Cowbell....
Maybe I overlooked this tidbit of info....but how do the bags mount on the trailing arms?
It looks like the bags have a center hole for air, but outer holes for mounting. Trailing arms have a center hole for the bolts. See my problem? Is there a bracket, do you drill extra holes, or is there a specific air bag part number to get to the hole is in the correct place? Thanks in advance, Putter
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 07-14-2008 at 02:53 PM. |
07-14-2008, 02:57 PM | #118 |
Never Ending Projects
Usually most bottom mounts on the bags have one bolt hole, which works great with the trailing arm. It's the top one that has two mounting studs or bolt holes.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-14-2008, 03:03 PM | #119 |
More Cowbell....
So would the rear bag require a plate of any sort where the bag meets the frame? I just don't want to dive in half-informed.
The front has been well covered by several posts and makes perfect sense, including cutting the cups down....but the back doesn't seem to get as much coverage in the threads.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
07-14-2008, 03:20 PM | #120 | |
Others will mount the bottom of the bag through the original hole in the trailing arm & drill the required holes in the frame. This is much more difficult but allows for more total drop (or more air psi required per bag height which can help w/the overall 'spring' rate).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-14-2008 at 03:21 PM. |
07-14-2008, 03:24 PM | #121 |
A guy with a truck
You will need to run a spacer up top, or drill mounting holes and a larger air fitting hole in the frame. If you want to be low, drilling is the way to go.
The bottom of the bag just bolts to the trailing arm via the coil spring hole w/ a 4" long bolt.
07-14-2008, 03:30 PM | #122 | |
ARR 21800 LCA http://www.ridetech.com/more/test-posting/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-14-2008, 03:54 PM | #123 | |
Questionable
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
07-14-2008, 05:57 PM | #124 | |
I made mine but then didn't use them because they would not allow for the full drop that I wanted.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-14-2008 at 05:59 PM. |
07-14-2008, 06:12 PM | #125 |
I'm a cheapskate, so I just drilled the holes in the frame. Time consuming and tedious. Make sure and double check before you drill, if you are off even a little you will have to drill larger holes than what you wanted. On a side not, Now my exhaust hits the brake junction block on top of the rear differential. Has anyone else ran into this problem? Did you just remount the j-block oon the bottom of the differential? What was your solution?
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
