Old 07-28-2006, 10:17 PM   #101
low4life1
low4life1's Avatar
Re: Dragndoorhandle
Here ya go. probably cant get a room tho. they sell out quick. just show up the day of and they might have a cancellation and you might get lucky. there is a really cheap hotel kitty corner to motel 6 that usually has rooms without reservations.
Motel 6
www.motel6.com
6330 Debonair Ln
Speedway, IN
(317) 293-3220
low4life1 is offline   Reply With Quote
Old 07-28-2006, 11:00 PM   #102
Rydn2L0w
Active Member
Rydn2L0w's Avatar
Re: Dragndoorhandle
Originally Posted by 7deuce
No, you cut a secton out so that the X-member is moved heigher up towards the engine.
Actually the engine stays in the exact same position in relation to the crossmember. You section the center to raise the front suspension up above the framerails. Seeing since the LCA's hit the ground first.
Rydn2L0w is offline   Reply With Quote
Old 07-28-2006, 11:06 PM   #103
7deuce
Sold! 2 days after finished
7deuce's Avatar
Re: Dragndoorhandle
You got it.
7deuce is offline   Reply With Quote
Old 07-29-2006, 12:27 AM   #104
Rydn2L0w
Active Member
Rydn2L0w's Avatar
Re: Dragndoorhandle
You got it.
By the way sweet truck. Ill be happy to get the pinchwelds of my burban on the ground.
Old 07-31-2006, 05:38 PM   #105
7deuce
7deuce's Avatar
Re: Dragndoorhandle
XXL thanks for the search engine. It took me there in less than a minute.
Old 07-31-2006, 07:45 PM   #106
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: Dragndoorhandle
Ive never been there either, but I heard its one of the biggest shows on the east coast. And I know there aint that many shows around here, so Im going to try to make it to this one. Should be close, but Ill be there.
If you want to go to a killer show that's going to be huge, go to the Relaxed Atmosphere All-Star Event on Labor Day weekend. It's in Millington, TN which is just outside Memphis. That show is going to go nutz.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 07-31-2006, 09:23 PM   #107
7deuce
7deuce's Avatar
Re: Dragndoorhandle
Do you have info or a website for the show? thanks
Old 08-02-2006, 03:42 PM   #108
87burb
Re: Dragndoorhandle
How is the truck?? is it almost ready? I'm going to be at indy and i want to check out the drop on it.
87burb is offline   Reply With Quote
Old 08-02-2006, 04:16 PM   #109
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Re: Dragndoorhandle
Im gonna try to go to the All Star Event. Not for sure if its gonna happen yet. I will still hang out with some of Outlandish Trends even though Im no longer a member.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 08-02-2006, 10:57 PM   #110
7deuce
7deuce's Avatar
Re: Dragndoorhandle
I got the frame back from powdercoating last week and I put all the suspension on it and also the cab. Im having one of my boys redo the 355 with a ton of new stuff, roller rockers, dist, h2o pump ect. The motor and tranny with the 2500 stall should be in by Friday. Then I have to get the drive shaft done which takes a half a day. Get the exhaust ran and have a fab shop break a tranny tunnel and d/s tunnel Bolt a seat in it and try to make the trip. If I break down I have another guy that said he would be watin on stand by with a trailer. I hope I can make it there. MR Wilt said there is allways a burnout and drag fest @ the motel 6 so well see what happens. Weither the truck will drive or not Ill have it there. Probably at the Killer Kustoms area.
Old 08-12-2006, 04:43 PM   #111
87burb
Re: Dragndoorhandle
No news yet? Hows it coming ?
Old 08-12-2006, 08:50 PM   #112
7deuce
7deuce's Avatar
Re: Dragndoorhandle
I got the tranny tunnel finished today. The motor and tranny are in it and the motor is 80% done. Just need to bolt a few more things on and it will be ready to fire. On the ****ter side when I went to put my headers on today, I found that there is about a 1/16 of an inch clearance from the fire wall. I will be working that over tomarrow morning. Then back to Bonified customs to put the bed on, then monday to the exhaust shop. Then to the junk yard to get a seat, and then...and then.... and then.....
Old 08-12-2006, 09:04 PM   #113
7deuce
7deuce's Avatar
Re: Dragndoorhandle
This is what got done today.
Old 08-12-2006, 09:55 PM   #114
72CSTC5
72CSTC5's Avatar
Re: Dragndoorhandle
Looks good. Did you bend that up yourself or did someone do it for you?
72CSTC5 is offline   Reply With Quote
Old 08-13-2006, 02:25 AM   #115
7deuce
7deuce's Avatar
Re: Dragndoorhandle
A buddy of mine bent it on a 100 ton accurshear break. This thing is crazy, digital controls you name it. I drew out what I wanted and he blasted it out in no time. The hardest part was the pieces on the fire wall, thoes took a minute to get done. I just got back from bonified customs where I was redoing the air compressor setup, but at 2am there was no place to get 1/2 in brass T fittings. I should be done with the truck by friday, I hope
Old 08-16-2006, 12:51 AM   #116
87burb
Re: Dragndoorhandle
2 more days away? Whats the status bro?
Old 08-17-2006, 01:33 AM   #117
7deuce
7deuce's Avatar
Re: Dragndoorhandle
FUUU$$$$$$$$$$$K I dont know if Ill drive it there, but Ill tow it and then drive around at INDY. I got all the sheet metal on and the engine fired up @ 1 AM. The guy at the exhaust shop fuc#ed up so I got straight pipe to the rear of the cab. I might drive to JEGS tomarrow to get 2 new ones and I still need a seat ant to mount the lokar tranny dip stick, b&m shifter and bolt down the air setup. As long as I can start it Ill be there. The fu#kin bed sides need cut down 1 in, the are bowed out BAD when I lay it out and I nee to cut the inner fender lips so I can stear this pig,. Ill try to post some pics tomarrow.
Old 08-17-2006, 01:01 PM   #118
blt2rail
land of the free ya right
blt2rail's Avatar
Re: Dragndoorhandle
how come you didnt center the rear wheels in the wheel wells
73 c10 body droped bagged zed frame 20s 2link 350,350
03 dodge crew cab 4x4 cummins banks 6 gun 4 in exhaust 4in lift 35s 16.5 5th wheel hitch xm linex
33 foot weekend warrior
06 chrysler pacifica (wifes)on 19s
00 xr 650 supermotard for sale$$$$
98 honda accord (commuter)
blt2rail is offline   Reply With Quote
Old 08-18-2006, 02:50 AM   #119
7deuce
7deuce's Avatar
Re: Dragndoorhandle
Its close. The pic you were looking at, the bed was not bolted down and when I aired it out the bed alked back. I need to cut 1.5 in off the bottoms of the bed. The sides are rollin in BAD right now when I let the air out.
Old 08-22-2006, 12:01 AM   #120
steveo10
steveo10's Avatar
Re: Dragndoorhandle
saw your truck at bash and wanted to talk to you but i wasn't sure which one was you. looks even better in person. one question what headers are you running? if i had the right ones i would of been at the show but i didn't like how much i had to cut out of mine and i didn't want to go with open headers.
steveo10 is offline   Reply With Quote
Old 08-22-2006, 04:38 AM   #121
87burb
Re: Dragndoorhandle
damn you went? i didnt make it...i'm pissed
how was it? start another thread if you got pics from there.
Old 08-22-2006, 11:53 AM   #122
low4life1
low4life1's Avatar
Re: Dragndoorhandle
got some video of 7duece rollin at the show. kinda big though:
http://s80.photobucket.com/albums/j1...t=5f048de4.flv
Old 08-22-2006, 12:17 PM   #123
low4life1
low4life1's Avatar
Re: Dragndoorhandle
here's some pics:
http://67-72chevytrucks.com/vboard/s...d.php?t=209028
Old 08-22-2006, 08:10 PM   #124
7deuce
7deuce's Avatar
Re: Dragndoorhandle
Damn, You have more pics than me. Oh wait I forgot my camea.
Old 08-22-2006, 08:22 PM   #125
Shane
Shane's Avatar
Re: Dragndoorhandle
... and your hood
Shane is offline   Reply With Quote
