Old 05-02-2010, 10:34 PM   #101
highperf4x4
Re: Heavy Chevy -- the penny pinchers rebuild
That looks good!
highperf4x4 is offline   Reply With Quote
Old 05-09-2010, 05:00 PM   #102
panhandler62
Java Mechanic
panhandler62's Avatar
Almost done with the re-hab on the Eaton.. go a little more to do on the passenger side then it's just waiting for the disc brake adapter brackets before I put it back where it goes.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 05-09-2010, 06:10 PM   #103
highperf4x4
Cool! What's next then?
Old 05-09-2010, 08:05 PM   #104
panhandler62
Java Mechanic
I have some brackets on the way.. need to buy a set of rotors and pads and some new shocks and then wrap up the rear.
The airlines and brake lines will get run later.
I haven't decided yet if I want to build the front suspension next or restore the cab. Both will cost about the same so I geuss it will mostly come down to mood. lol
Keith
Old 05-10-2010, 11:56 AM   #105
8mpg
8mpg's Avatar
Are you using gas with your welding? Looks like you are just flux core welding to me. If you are, and your welder can convert to gas...its some of the best money you will ever spend.
8mpg is offline   Reply With Quote
Old 05-10-2010, 12:09 PM   #106
panhandler62
Java Mechanic
This one can't. The only welding left on this beast will be the patches for the cab. It will be messy with a flux core, but I think I can get through it.
If I decide to do another one after this an upgrade in this area will be high on my list!
Keith
Old 05-10-2010, 02:38 PM   #107
8mpg
8mpg's Avatar
Right on man... Gotta make due with what you have. Just a little constructive criticism.. Looks like you need to step up the heat a little more. Not sure how much penetration you are getting. Also, the sweep needs to be a little wider when the torch tip goes back and forth between the two pieces of metal. Looks like you are pushing your welds a bit fast. Not enough wire to fill when welding, try slowing down just a bit.
Im no pro...but know a little.
Old 05-20-2010, 07:44 AM   #108
panhandler62
Java Mechanic
I'm a little stuck right now. Waiting for the brake brackets from RuffStuff and I have to wait till payday to but the rotors because my wife's laptop went poo poo and I have to fix that first.
I thought about putting the rear back in the truck, but I have the truck sitting too close to the wall -- I'm pretty sure the axle won't come out on tat side it I bolt it back up so I need to wait till I have the brackets and rotors installed before I put the rear back under the truck.
Keith
Old 05-24-2010, 03:32 PM   #109
panhandler62
Java Mechanic
Getting a little bit done.... sure looks easier on the Saturday morning hot rod shows! lol
Gotta get some clear to cover the rotors so they won't look like doo doo (man they pick up patina fast!)
Keith
Old 05-24-2010, 04:01 PM   #110
kev2809
low n' slo
kev2809's Avatar
looking good! just curious, why dont you want air ride for the front if your gonna already rebuild the stuff up there? you already have the drop spindles, i would just throw the bags up front too! just my .02 though..
ive always wanted to swap to pb trailing arms, maybe one day! good work so far man...ive been using a little poo poo welder too on my build but im scared to use it for the frame stuff lol. flux core does make more work for you but its been getting it done for me, just needs a lot more grinding!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-24-2010, 04:19 PM   #111
panhandler62
Java Mechanic
I'll probably swap to bags in the front at a future date. I want to use Nate's dropmember up there but don't have the money for that right now.
I'll revisit the front later -- put in the dropmember, tubular arms, c-4 rack and shock-waves. If I don't hit a lottery ... don't see that happening real soon though. lol
Keith
Old 05-24-2010, 04:52 PM   #112
kev2809
low n' slo
kev2809's Avatar
lol, ya i hear you. i wish i could get one too but im the same boat with you. i think my setup will be "good enough" for now i guess. i do want to be build a old school continental one day so i have to finish this truck some day!
-_--_--_ _________
Old 06-08-2010, 12:29 AM   #113
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
lookin' good very intertaining thread..
what kinda rust ya gotta deal with?
John
1999 Toyota Tacoma 4x4
Old 06-08-2010, 07:37 PM   #114
panhandler62
Java Mechanic
I think I have found rust everywhere these things rust.... I'm getting ahead of it though.. lol
Keith
Old 06-10-2010, 09:03 PM   #115
panhandler62
Java Mechanic
It may not look like much has happened but .... I have the rear suspension just about buttoned up, I sorted out the lug/hub fitment issues and just for giggles she is sitting on her rear tires instead of jack stands for the first time in over 2 years.
Getting ready for vacation but I'll be moving on to the front suspension when we get back.
Here are some "aired up" and "dumped" side elevation pics. The height of the front is close but it's somewhat guesswork until I get it reassembled.
Keith
