03-31-2013, 02:02 PM | #101 |
Re: front coilovers
Question for you on a different upper mounting approach for the coilover. What are peoples thoughts about cutting off the part of crossmember that the upper coilover is mounted to and then make aup an entirely different mount that allowed you to increase the length of the coilover and spring and in turn suspension travel.
04-01-2013, 02:26 AM | #102 |
Re: front coilovers
If you could get past the upper control arm cross shaft it'd work.
Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=534956 |
12-03-2014, 09:37 AM | #103 |
Re: front coilovers
Thanks for showing. This was very helpful since I have been thinking about putting coil overs on the front of my 65 C10. It started from looking at 4 link suspension with coil overs. Nice to have a little adjustment without all the air bags.
03-23-2016, 02:37 PM | #104 |
Loading.....
Re: front coilovers
Reviving an old thread......
I like what I'm seeing here but wonder if one could skip a buncha fab work for a static drop of smaller size. I have 2.5"drop spindles with one coil cut from the stock springs. Thinking about removing the springs and putting QA-1 coilover shocks in place of the factory shocks. I imagine that's WAY too much pressure for the stock mounts, but assuming that I'm able to make a reinforced upper mount, what other downsides would I have against the full blown rearrangement that has been documented here? Anyone done this and have a picture / review of performance over using a coil and regular shock instead? Thanks! M7
-M7 '69 SWB GMC 5.7 EFI ‘69 C/10 SWB patina survivor ‘71 GMC K20 '72 K5 1-ton gear 468BB ‘86 K30 GMC High Sierra C&C Single Cab '96 SWB Single Cab 5.7 ‘99 SWB Z71 Single Cab '00 SWB Single Cab 5.3 '01 K2500 Yukon Safari 6.0 ‘06 2500HD Single Cab C&C Duramax 4x4 '08 1500 crew '11 2500HD Single Cab Duramax 4x4 |
