Old 08-17-2008, 11:50 PM   #101
Dinos63
chevy only
Dinos63's Avatar
Re: No Regrets - The Rebuild post
man how did i miss this thread, i love the chop and a good call on the wheels nice job very slick
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 08-18-2008, 01:04 AM   #102
dubdeuce80
dubdeuce80's Avatar
i love everything about your truck but the chop...personally never been a fan of them on square bodys, but other than that it's pretty much been one of my favorite trucks since i saw the pics a few years back
dubdeuce80 is offline   Reply With Quote
Old 08-18-2008, 01:46 PM   #103
85sqbdy
85sqbdy's Avatar
Can You Build Another On Of Those 180 Degree Brake Master Cylinder Brackets? If So, How Much?
85sqbdy is offline   Reply With Quote
Old 08-18-2008, 11:37 PM   #104
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I could someday, but right now I have way too much on my plate to start doing work for other people... I do this for fun you know! Get with me over the winter and maybe we can work something out. As it is right now I have two project trucks and my motorcycle has been siting waiting to put back together for more than a year now!!!
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 08-20-2008, 12:20 PM   #105
smashingchuck
thanks Dino... you've got some pretty cool toys as well.
Still working on shocks. Finally got them from Doestch (sp?) and they are really nice; and have the stroke they said they did. Still had to rethink my mounts and I'm still not done with the lowers, as the lower mounts I made just turned to temporary until I pull the axle out and build one last set. I overlooked the overall diameter of the lower shock mount and it is just too close for comfort. The uppers are in place but still need a gusset. With the shocks outboard the frame I will now be able to tun full exhaust. Also Got most of the mid crossmember done. Just have to add a few gussets on the hoop, and flip the frame upside down to do some final welds.
also got some dollies from autobody parts USA that are going to come in very handy when this thing starts to get heavier again. They were very handy for resetting the panhard bar... which is another story I will skip for now.
here is some midweek pics to show what I've been up to over the last few weeks. Please excuse the mess as I am in mid mock up/ build...
78 Build Thread
4Runner Build
Old 08-20-2008, 01:12 PM   #106
smashingchuck
one more of the upper shock mount... (with said gusset).
78 Build Thread
4Runner Build
Old 08-20-2008, 10:33 PM   #107
Rollinsqrbdy
Rollinsqrbdy's Avatar
Man I just read the tread. That truck is sweeeeeeeeet. Luv the choice of wheels,and I was never a fan of the chop on a square body but u pulled it off and its kickin. Cant wait to see more pics.
Rollinsqrbdy is offline   Reply With Quote
Old 08-24-2008, 05:19 PM   #108
smashingchuck
Well in the middle of the week I got the frame flipped upside down to do some more welding. It's sooo much easier to weld when you're not doing it upside down, so since I have the advantage of being able to just turn it over, I did. I put another matching gusset on the underside of the shock mount so it was "boxed", laid down the rest of the welds on the crossmember, Touched up a few other spots, and have just been doing some general clean up of stuff that's not so noticeable with the frame right side up. I also Boxed the frame in between the notch and the new crossmember, and added some braces on the hoop. Hopefully by next week end I can start throwing some paint on it. I'm almost there, but just keep picking at it and changin stuff. I could easily spend three more mounts filling holes, boxing the rest of the frame... but I have to draw the line somewhere!!! Here's some pics as always... and remember, the frame is upside down!
78 Build Thread
4Runner Build
Old 08-24-2008, 06:06 PM   #109
ca180
tryin to get laid
I must say, those are some fine welds for a MIG! You got skill man! Any advice? I've been playing with my lincoln welder (running flux) for about a year now, but I'm not half as good as that!
ca180 is offline   Reply With Quote
Old 08-24-2008, 06:59 PM   #110
smashingchuck
They are ok... still kinda "bugery" in some spots but definately strong. I'm by no means a pro... but I tend to run the heat a little hotter than I think it should be, and also run the feed slow. For example: On most of the welds pictured I ran the feed around 50-55 and the heat on 5 or 6. I'm still learning with the MIG... but it definitely is easier to get a nice looking weld with it... it's just not as gratifing as when you knock the slag off an arc weld to expose a nicely laid bead. I will say this though - it is way faster, and a lot more forgiving! I guess the only real advice I could give you is to ditch that flux core and get a bottle! It really does make a difference!
Also it always helps me alot to keep the gaps very small between the two pieces I'm welding, but I suppose that is a given.
78 Build Thread
4Runner Build
Old 08-24-2008, 07:56 PM   #111
N2TRUX
Happy to be here
N2TRUX's Avatar
They may not be Porterbuilt tig beads, but they do look clean. Nothing that an abrasive wheel won't clean up that's for sure. Keep the progress pics coming...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-24-2008, 08:03 PM   #112
smashingchuck
My next big tool purchase is either going to be a plasma cutter or a TIG welder. Both are inevitable. I definately want to learn to TIG weld... and I think I would be good at it once I got it down.
78 Build Thread
4Runner Build
Old 08-25-2008, 08:49 PM   #113
82ZZZR
Originally Posted by smashingchuck View Post
And here is how I solved the problem of the transmission cross member bolts hanging below the frame. First I welded tabs to the original crossmember and used two 3/8 bolts though the side of the frame. Then, I countersunk the original holes and used the proper bolts so they were flush with the bottom of the frame. Then I bolted in the other two pieces for rigidity. I still have to sand blast one of the upper pieces, but it is strong as hell and doesn't drag the bolts on the ground now.
how many cross members was that made from? I looked at mine and it has the big hump in the one side...sorry about the noob question
82ZZZR is offline   Reply With Quote
Old 08-25-2008, 11:44 PM   #114
smashingchuck
All 3 pieces are completely factory with the exception of the tabs welded to the ends of the bottom piece. My truck (when I got it) only had a brace on the passenger side, but it should have had them on both sides... The rusty looking one is just one I robbed off of a spare frame that I have. Which for some strange reason only had the brace on the driver side.
So to answer your question... it was made from two, but it should only be one. I've seen the trans crossmember you are talking about - I think they came on newer trucks - I have the one you describe on my suburban which is a 91.
78 Build Thread
4Runner Build
Old 08-27-2008, 11:48 PM   #115
Rollinsqrbdy
those are sum bad welds. My welds are getting better. Not only r u a good welder but fabricator also. Awesome job. The truck is sweet!!. BY any chance does anyone know where a tread for changing over a 86 long bed into a shortbed is? Keep us posted on ur truck chuck.
Old 08-29-2008, 02:32 AM   #116
smashingchuck
teach 'em young...
78 Build Thread
4Runner Build
Old 08-30-2008, 02:29 PM   #117
northeimcustom
northeimcustom's Avatar
GREAT thread! keep us updated !
northeimcustom is offline   Reply With Quote
Old 08-30-2008, 04:36 PM   #118
smashingchuck
thanks. Need some help here guys... check out this thread-
http://67-72chevytrucks.com/vboard/s...90#post2869990
78 Build Thread
4Runner Build
Old 08-31-2008, 09:01 PM   #119
smashingchuck
well, more boring stuff. Got all the cab mounts replaced today... old ones had already been repaired once, the others were rotting away to nothing. I scabed some new ones off a spare frame I have and sandblasted them before I put them on. All four got the treatment.
78 Build Thread
4Runner Build
Old 08-31-2008, 09:04 PM   #120
smashingchuck
Also remembered today that I didn't have the intermediate brake line mount redone on the frame. I kinda forgot about it the second I cut the old one off the frame. Anyway here is what I came up with.
78 Build Thread
4Runner Build
Old 09-01-2008, 06:50 PM   #121
smashingchuck
Finally!
Moving forward instead of backwards (at least for the time being). I finally got the first (and only) coat of black primer on today. Tomorrow I get to spray the real paint.
The first pic shows everything ready with zinc chromate primer... second and third pics are with the Eastwood Chassis Black primer.
78 Build Thread
4Runner Build
Old 09-02-2008, 11:59 AM   #122
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I don't know if this matters for what you are building, but those front mounts are 81-87 mounts..
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 09-02-2008, 01:17 PM   #123
smashingchuck
Yes, they are. Other than the different opening, is there a reason this should matter? From what I saw they are both the same overall dimensions....
78 Build Thread
4Runner Build
Old 09-02-2008, 01:25 PM   #124
Captkaos
Captkaos's Avatar
It matters for the bushings. The fronts are probably ok (if memory serves me right) , but the cab ones you don't want to mix match. The cab won't mount Level on the frame.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 09-02-2008, 11:27 PM   #125
smashingchuck
the new mounts that are from the newer frame are the same distance form the top of the frame as the old ones, but the bushings from the newer frame are a little taller. I think I'm safe, as long a use the bushings that go with my frame and cab.
78 Build Thread
4Runner Build
