#101 |
Re: Prepping for a BBC conversion
kenny, awesome build! i'm not sure how i missed it without posting. that big block sounds sick and the paint looks sweet! nice job and cool thread!! Dennis
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#102 | |
Navy Radioman Veteran
Gonna do the interior next. Kenny
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside - SOLD 2005 Chevrolet Tahoe Z71 |
#103 |
dang its hot
do you still have that 76 body?
#104 |
I am working on a 76 body.
#105 |
No, all I have left is the radiator, washfluid container, intake, carb, exh mani, etc... truck was sold for parts by original owner.
Kenny
#106 |
Here's the lowrider next to a buddy's '87 4x4 during a car show (her first) last year. Won "Best Truck" out of nearly 200 in the field. Not bad for her maiden voyage.
#107 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Well deserved. Sick truck man. I love the flat black.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#108 |
Very nice man. I am fixing to start a 454 conversion in my 83 1/2 ton and your thread has been very helpful. I hope you dont mind me picking your brain as I go.
#109 | |
#110 |
Truck Junkie
![]() Join Date: Aug 2008
Hey 87Lowrider sweet truck, what type of headers are you using? thanks!
#111 | |
#112 |
Truck Junkie
Video of your rat idling is like music...what are the specs on the cam? Baclay9 didn't mean to jack your thread!!
#113 | |
![]() http://67-72chevytrucks.com/vboard/a...&pictureid=487
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside - SOLD 2005 Chevrolet Tahoe Z71 Last edited by 87Lowrider; 09-07-2010 at 09:29 AM. |
#114 |
It's not my thread bud...get after it!!!
#115 |
When you installed the Becool radiator I noticed you said you used the upper mounting hardware from your SB radiator. What about the bottom hardware. Do I need to come up with the BB radiator supports and stuff for the bottom?
Do you think if you would have been running the dual electric fans with the 4 core BB radiator you had originally they would have cured your overheating problem? Last edited by baclay9; 09-01-2010 at 08:25 AM. |
#116 | |
I didn't try a dual fan on the original radiator so I'm not sure of the results. But, the BeCool keeps the engine temp around 175-185 when driving above 40-50mph. Otherwise, it gets up to around 200-210 in town. I don't let it do that without having to stop anyways so it's no concern for me. If it gets too hot for my tastes, I either stop or find an open road and cool it off.
#117 |
Hey Kenny, are you still happy with your cam choice? Is it making plenty of vaccum to run your power brakes and such? It is hard to tell from the video but does it have a fairly choppy idle?
I ended up scoring a set of 781's and I think I am going to go ahead and have them opened up to 2.19/1.88 as you did. If you had it to do over again would you have some porting work done or are you happy with the performance as is? If your setup is working well for you I would like to copy cat it so I will more or less know what to expect when I fire it up the first time. LOL Also, are you running a hydrualic flat tappet cam? I can't remember if you said or not but what stall are you running with that setup? Sorry for all the questions. Thanks man!!! Last edited by baclay9; 09-05-2010 at 10:10 AM. |
#118 |
Home Built '87
subscribed!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
#119 | |
The cam is pretty "choppy", people comment about it every time I take it out, which is a couple times a week. I've noticed a few times that the brakes are a bit hard to press on but it's only in the morning when I back it down the driveway. Once I get it warmed up, it's fine. Several of us around here have a running joke about the cam... "I've got to get that miss fixed" Since this is my first "hot rod", I don't have anything to compare it against. The heads came with the motor so I was lucky to get what I got. I'm sure I'll do something different when I get the '57 done. But, this motor has all the power I need. The Cam is like a Big German Shepard. Even the ponies stay away!! ![]() The Cam is a hydraulic flat tappet. Somewhere on here should be all the part numbers I used when i ordered the top end for this motor which is (was) all new. The bottom end was sound so a rebuild of the heads was the only other thing I needed. Valve train is a bit noisy but some say that's normal. I've got about 6000 miles on it now. Here's some more vids from my youtube page; Here's a link to a local thread with new paint on the truck back in the spring. http://67-72chevytrucks.com/vboard/s...d.php?t=402574 Good Luck! Ken
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside - SOLD 2005 Chevrolet Tahoe Z71 Last edited by 87Lowrider; 09-07-2010 at 09:47 AM. |
#120 |
#121 |
Do you happen to know what stall you are running. I called Comp and they reccomended the same came you have. Which isn't suprising I guess considering our setups will be similiar.
Where did you order your valves from? Did they come from PBM directly? When it shows the price of the valves is that for a set of 8? |
#122 | |
#123 |
The guy at comp told me I would be alright with a 2000 to 2200. If you happen to find out what yours is for sure could you please let me know
Posted via Mobile Device |
#124 |
From the looks of it you went with a mechanical advance distributor over a vacuum advance. Could you tell me why. There is a guy on CL here that has the same dist. you have, a MSD-6AL ignition box, and a blaster 2 coil for $340. I just wanted to make sure I shouldn't be running a vacuum advance befor I dropped the dough on it.
#125 | |
So, I trusted what they said and so far it's been a great decision for my application which is a driver to and from work occasionally, and out on the weekends cruising around. It's got about 5000 miles on it now but it's never been HAMMERED and ragged on yet. The most it's seen is about 4250 and that was fun! Not a bad price.
