03-15-2010, 03:18 PM | #101 |
Re: My DJM flip kit install pics
Nice write up! I read it 777 times before buying the goodies to do mine. I just finished my DJM flip kit install, along with DJM 3" drop spindles and cut coils. I used the same flip kit that you used, and highly recommend it. I am running 4 new stock-length shocks, and have no problem. The axle will hit the new bump stops before the shocks bottom out, with the shock extenders.
The instructions do say to flip the axle locating bolt, but I did not (out of pure laziness). The spring plates will straddle the other side of the bolt, but won't be positioned perfectly under the axle tube. The two rear u-bolt shafts will have more threads showing than the two fronts, but it isn't going anywhere, and pulled tight with the impact gun. I used a torch to get the factory bump stops off, and it took less than 2 minutes. I made the same mistake by not putting the one shock extension bolt in before the u-bolts, but the bolt will go in from the other side. The nut will be facing the outside, instead of how the instructions show, and you, and me, put the others in. My install went fairly smooth, with the exception of two things: both of my pass. side leaf spring bolts would not budge, so I had to maneuver the axle up and over the leaf. This wasn't too easy to do, since I didn't pull the brake line (it was stretched tight). The second problem I had was the shock extenders were too wide on the shock end for the factory shock bolt, supplied shock bolt, and the shock itself. This was fixed with some flat washers and a longer grade 8 bolt. I have no plans on doing a c-notch, and really don't see the point, unless I decide to use it for towing or hauling heavier things. The PO did install some overload springs, so maybe that helps me, but it does not bottom out going over tracks at normal speeds. The spindle install was a lot more demanding, thanks to the lower ball joints not wanting to separate. I had to cock the spindle to the side and beat on my pickle fork for some time, before it finally went. I cut 1/2 coil off the factory coils, and it sits just like yours, but I think I will end up going a full coil to get rid of the California rake. I had no problems with rubbing on the lower control arm, but did have to grind on the caliper ears (running stock 15x8 ralleys). Now I just need to get it aligned, so it quits pulling to the right and wandering everywhere. Well, I just thought I would share my experiences, as well. Thanks again for showing everyone how easy this is to do. |
06-05-2010, 02:48 PM | #102 |
454HO, would you possibly be able to update the photos on this how-to? pleeeease
09-20-2010, 12:48 PM | #103 |
Amateur Rust Fighter
+1. Looking to do this on my '79 and would love to see the pics.
Brent '72 Chevy SWB stepside - [ Build Thread ] '79 ChevMC SWB fleetside - [ Build Thread ] '64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...) |
09-20-2010, 04:52 PM | #104 |
please update pics.. i will be buying a kit to lower my 85. and maybe if i can see the pics it will help me atcually try and do the job myself as opposed to paying for job. thanks for any help.
05-20-2011, 01:18 AM | #105 | |||
Bringing this back from the dead.
I can't see the pictures from the 454HO's original post, but I think I just went through this same problem. You said you replaced your rear-end so you worked around this problem, but what I think is that you had a 4x4 rear-end that someone swapped in 5-lug axles. Quote:
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) Last edited by kevinr1970; 05-20-2011 at 01:19 AM. |
08-15-2011, 05:22 PM | #106 |
Anyone have the pictures from this thread or was it maybe stickied somewhere I missed?
08-15-2011, 11:04 PM | #107 |
chevy runs deep
ttt
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
