#101 |
Re: Project ''Tailor Made'' LOWESTSIXTY7
Started to slowly work on it a little. I will have alot more time after this month. I wont have any more doctors appointments. Will try to post some pics soon.
#102 |
what are your plans on mounting the gauges? They can't just lay flat because of the angle of the sheetmetal, so you gonna built some type of cups for them to protrude out of? I really like what you did with the dash and thinking about doing something similar. What are you going to do with the passenger side recessed area?
#103 |
truck is awesome cant wait to finally see this thing done, if this is the same one i seen at the last year of showfest
ProPaint Collision & Customs |
#104 |
Propaint81- This truck is actually a different truck then the one you saw at the last year of Showfest. That one is the ''Matt Eye'' truck. That one is still at the shop. Hasnt been worked on in quite awhile. Hopefully we get back on it soon.
Jlaird- The gauges acutally do lay flat on the dash that was made. You can see the gauges very clearly when sitting in the drivers seat. The passenger side is going to get a 7'' screen in it. I have attached some pics of the gauges. |
#105 |
sweet! thanks for the pics. Hope you don't mind, I did a little photochop! This was along the lines I was thinking for mine. What do you think?
#106 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
That's very similar to the way I am planning on running mine..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#107 |
Looks Good
#108 |
What metal working tools did you use to do that dash? In one of the close-up shots I see how you bent the metal as one piece and welded the seam on the flat end. Very smart! The extent of my metal working experience are patch panels and I shaved my firewall. I'm a little nervous about cutting my dash out, but hopefully all will go well.
#109 |
any new updates?how did you mount the one piece front clip?
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain) http://67-72chevytrucks.com/vboard/s...d.php?t=434253 |
#110 |
if i only was .0009% as good
#111 |
Any updates on this truck, Did it ever get finished
#112 |
Any updates on this build?
#113 |
![]() Join Date: Apr 2005
bump
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
