#101 |
C35 Crew Dually
Re: The Drop Thread
Yes just the support "rib" not the floor.
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
#102 |
![]() Join Date: Dec 2008
Re: The Drop Thread
Huh this is kind of a bummer to find out. I am not completely in love with cutting anything off my truck that has survived 24 yrs with out a spec of rust.
00' Z28 ("wifes" car) 92' Mustang w/sbc ![]() 87' GMC Sierra Classic Short Bed Fleet side almost stock 69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it |
#103 |
Re: The Drop Thread
Anyone running 3 or 4 leaf spring with no flip....... how is the ride
#104 |
Re: The Drop Thread
I lowered mine by cuting one round off of the front springs.
For the back I took the leaf apart. Started with main leaf added longest leaf below, put overload leaf on top and bolted back together. The end result was 2.5 front. 3 rear. Cost. $0.00 Rides good, only draw back is redused weight carrying due to the nature of leaf springs. Posted via Mobile Device
John 82 Chevy Silverado 350ci/TH350 ![]() |
#105 |
Re: The Drop Thread
I decided to just flip it........ going low
#106 |
Re: The Drop Thread
Ha guys here is my first flip.... ass in ride alittle rough, what is the best was to soften it up abit
#107 |
Re: The Drop Thread
Sorry..... mult. Type o........
![]() ![]() Front has to go down 2 more inchs |
#108 |
Re: The Drop Thread
Changing the shocks.
Posted via Mobile Device |
#109 |
Re: The Drop Thread
3 inch drop springs and spindles in the front-the back flip kit and removed overload leaf
#110 |
Re: The Drop Thread
After doing a flip in the rear, wouldn't removing leafs be effectively raising the rear back up?
#111 |
Re: The Drop Thread
Why didn't this thread catch on?
#112 |
Re: The Drop Thread
#113 |
Re: The Drop Thread
more!!!
#114 |
Re: The Drop Thread
something sexy about a dropped truck LOL
big old burb in primer.lot of work to do. |
#115 |
Re: The Drop Thread
Finally droped it 2in more
#116 |
Re: The Drop Thread
I am running a McGaughy's 4.5/6 kit on my truck and was wondering if any of you guys ran into a problem with running the factory brake lines,and them hitting the spindle and not being able to run them how they were on the factory spindle. Did any of you have to do any grinding or use steel braided lines or.......
#117 |
Re: The Drop Thread
81psychobilly,
I'd like to see pics of yours with that set up......I'm thinking of buying the same kit for my 81....Did you c-notch? RIZ |
#118 | |
Re: The Drop Thread
#119 |
Re: The Drop Thread
#120 |
Re: The Drop Thread
Another run at the top...
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
#121 |
Re: The Drop Thread
chopped 1 1/2 coil off and did a flip kit. it was sitting pretty high and raked before i lowered it. it has a sway bar and new tires now
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread Last edited by cory d; 04-19-2012 at 01:06 PM. |
