12-23-2014, 09:56 AM | #101 | |
Re: Headers to 2.5" Ramhorns
Don aka Rocket_Man 72 K5 Blazer 454 CI 2002 Honda VTX 1800C |
05-16-2015, 07:09 PM | #102 |
But Found Her 25yrs Later!
I originally had genuine corvette Rams Horns.
The owner that I bought my truck from, had to replace the passenger side. He only used the 2" dump type. I'm replacing it with the Dorman 674-504. Is there an adapter to go from the 2.5 dump to this pipe in the pic below?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
05-16-2015, 07:14 PM | #103 |
Also, he seem to have used some pretty short bolts where he mounted them to the block.
The threads only stick out 1/4". How much thread should there be into the engine block?
05-16-2015, 09:28 PM | #104 |
05-18-2015, 11:37 AM | #105 |
FYI guys. JEGS sells a chrome set for about $100
Bought this thing bone stock with intentions to just add a lift and tires and the next thing I knew it was on my garage floor in a million pieces. Sometimes the best laid plans........ |
03-17-2018, 02:24 PM | #106 |
Anyone running the center dumps on the later 70s frame? Any other useful updates?
Dorman parts are still available |
03-21-2018, 03:16 AM | #107 |
I found a set of stock 2 1/2 in. from a 50/60 sires truck Ramhorns NOS . I grounded off the front brackets they look great.
06-21-2019, 09:30 PM | #108 |
What's a good source for a set of those brass nuts that hold the header pipe to the manifold? I don't need the studs. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
06-29-2019, 02:19 PM | #109 |
Active Member
I've had 2 1/2 Ram's horns on a 72 Blazer for 15 years.
For those of you with an HEI ignition who want to run factory type plug wires, get a set of plug wires for a 1975 Corvette. That was the first year of HEI and they still utilized Ram's horns manifolds. You can still find the back of the block looms and the looms that bolt to an oil pan bolt. With factory heat shields, your wires will not burn. |
11-27-2020, 05:33 AM | #110 | ||
Great tip suggesting 75 Corvette plug wires. Thanks. Quote:
Does anyone have experience using the 76-80 Corvette heat stove with 2.5" ram horn manifolds? https://www.southerncarparts.com/c3-...ield-assy.html They look similar to original stoves but will our stock heat riser and air cleaner work with the Corvette heat stove? Also, can 57-79 Corvette spark plugs shields be used? https://www.southerncarparts.com/195...block-4pc.html
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 11-28-2020 at 04:37 AM. |
11-27-2020, 06:19 PM | #111 |
Green Monster,
I don’t know for sure if it will work/fit but that is exactly what I am (was) planning to do when I get my engine rebuilt. Hopefully someone has done this and can confirm this for us! I am also going to have the ram horns ceramic coated inside and out to reduce engine bay heat. Unrelated, was thinking on having the master cylinder ceramic coated to match so they will look like bare cast iron but not rust. Last edited by PDXk5; 11-27-2020 at 06:43 PM. |
11-28-2020, 04:25 AM | #112 |
PDXk5- A ceramic coating in a cast iron color on the manifolds and master cylinder will have a nice look for sure.
Yesterday, a pair of Assault Racing 2.5" straight dump ramhorns with black ceramic coating inside and out from Assault Racing showed up at my front door. They were inexpensive ($200) and came with gaskets and all mounting hardware in the photo. Cast iron color was my first choice but black and silver are the only colors offered in ceramic coating, that I could find. The manifolds appear to be two RH (passenger side) manifolds, which is a good thing since there is no ports to drill out, tap and fill as Jim (Jaros44sr) shared he did with his LH manifolds. https://www.assaultracing.com/item/1...?category=8107 The new repo stove and spark plug shields I posted earlier seem like they would fit, function and look close to factory correct. If no one can confirm they won't work then I'll pick up a set and go from there. I need to find out what hardware I'll need for the shields and stoves.
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 11-28-2020 at 04:45 AM. Reason: Corrected grammatical error |
11-28-2020, 09:50 AM | #113 |
Carpe manana
The heat stove should fit but it’s a guess whether or not the OD of the riser tube to the snorkel would slip over the male end at the riser and it’s in the correct location. I wonder if there is a member here who has that gen vette with the riser who could take a measurement? The stove assembles with hex head short #8 screws if I recall (maybe #10?).
The plug shields will work I suspect. But, of the four there is at least one, that to the front LH head, that’s a different shape. The shield at this location is “tented” so to speak or an inverted V to encompass the temp sending unit. Offhand I can’t recall if that at the TCS sending unit was the tented style. If helpful, I can post photos of an oem shield in this style and the hex head bolts that secure these in place.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
11-28-2020, 11:25 AM | #114 |
20200614_104000 by [url=https://www.flickr.com/photos/97391199@N06
A 1971 blazer, turned down my sending unit, as I was having incorrect readings on my gauge, G1852 seems to stick in my head, but I could be wrong, if you can't find one at NAPA, he will supply one turned down for your truck. The flat spark plug shield will clear the sender, but in retrospec, someday , I will replace with the angled one. After I've completed a couple more heat cycles I'll bend the manifold bolt locking tabs down. I believe the shields are tapped in the block with 1/4-20 bolts Check your intake manifold gasket you may have blo cked your cross over port The Eastwood cast iron coating is not holding up to my liking, someday ceramic coating. Also I'm not fond of the the gasket for the exit port(down pipe) I use a sold sintered piece with a metal sleeve
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-28-2020 at 11:52 AM. |
11-28-2020, 12:32 PM | #115 |
Carpe manana
‘Lectric limited has temp send units that read and fit correctly and are or were USA made if I recall.
11-30-2020, 09:34 PM | #116 |
Built a 72 Jimmy for my kid and we used the 2 1/2" 'vette manifolds on it along with the 75-82 Corvette plug wires. I like the MSD Streetfire for best bang-for-the-buck these days.
We used made for you vertical valve cover looms to route the wires in the stock position down back of the black and underneath along the oil pan. Still think this is best option for a small block 4x4.
12-01-2020, 09:32 AM | #117 | |
Thank you for the info. I can't find info on the OD or the stove pipe of the C3 vette. Are these four the correct spark heat shields? One appears to be "tented" for the thermostat.
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 12-01-2020 at 10:34 AM. |
12-01-2020, 10:31 AM | #118 | |
Great info, Jim. thanks for sharing photos, bolt sizes and your experience. Can you elaborate on what you mean when you typed "Check your intake manifold gasket you may have blo cked your cross over port"? I'm not sure what the cross over port is or it's function. That's too bad about the cast iron paint not holding up, I'm sure that was disappointing. Good to know that may not be not a viable option. Hopefully the ceramic does a decent job against corrosion. I haven't seen long term results though but for $200 it was worth a shot. I may be overthinking this but if ceramic coating reduces the heat transfer and under hood temperatures, as advertised, the combination of ceramic coated exhaust manifolds and heat stove may actually reduce the effectiveness of warming up the carburetor. I will likely be better than running an open air filter element without the stove and riser set up. On a side note, DeadheadNM mentioend Letric Limited temperature sending units and I had success going this route when I had incorrect readings. Funny, this unintended project started a few weeks ago when I discovered a hole in my muffler. Instead of just replacing the muffler I saw it as an opportunity to restore the exhaust/cold start intake system. I'm sure you all know how these projects can snowball. I appreciate your help with identifying the correct parts that go with the ram horn manifolds.
Photo Gallery of 1972 K/5 Blazer CST Last edited by Green Monster; 12-01-2020 at 10:39 AM. |
12-01-2020, 10:41 AM | #119 | |
Carpe manana
Yes, that is the correct heat shield for that location.
12-01-2020, 11:32 AM | #120 |
What is the "D" shaped notch on the other three remaining shields used for? I've seen solid shields and notched, like these. Which is correct for our Blazers?
Photo Gallery of 1972 K/5 Blazer CST |
12-01-2020, 02:01 PM | #121 |
Carpe manana
Clearance for the oil dipstick I believe.
Another example of the anterior LH heat shield here: https://www.ebay.com/itm/New-Factory....c100667.m2042
12-01-2020, 02:11 PM | #122 |
Carpe manana
I believe the parts manual lists two p/n's for the heat shields for at least 71-72 FWIW. I have both in NOS form on my Blazer and believe the flat examples were all notched and had the same part number, which differed from that for the LH anterior head. I'd have to revisit the parts manual to confirm. These shields were certainly used for other SBC applications and as such are sort of generic rather than C/K or K5 specific.
What I'm struggling to remember is the style that's located on the RH rear head and favor the "tented" design to clear the send unit for the TCS system. Here's an example set presumably correct: http://67-72chevytrucks.com/vboard/s...56&postcount=1
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 12-01-2020 at 02:21 PM. Reason: added |
12-01-2020, 02:47 PM | #123 | |
I believe the function was to heat up the area below the carb, for cold starts
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
12-01-2020, 02:47 PM | #124 | |
12-01-2020, 11:30 PM | #125 |
Carpe manana
You bet. Glad you got one. Here’s the excerpt from the parts manual.
Here’s the correct screw to affix these shields to the motor. Hex head captured washer embossed with circles and an “S”; 1/4 x 3/8 and 20 pitch as Jim mentioned.
