Old 01-03-2010, 03:25 PM   #101
87 dually burb
my short bus
87 dually burb's Avatar
Re: 90 burb (( daily dragger))
I'm not trying hard to sell it so it may get some work done when it warms up
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 01-07-2010, 10:32 PM   #102
87 dually burb
my short bus
I got my taxes done and should have a check end of month so not selling it
look for progress early feb
Old 01-07-2010, 10:36 PM   #103
justpball
justpball's Avatar
YES! So happy you are not getting rid of it.
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 01-08-2010, 11:35 AM   #104
87 dually burb
my short bus
me to I will get 4runner end of month to play with while I pull the burb apart
to add a cross member an then raise tank has to be back together for a show mid march for my kids high school fundraiser
Old 01-08-2010, 12:47 PM   #105
SBTork
Garage wrench
SBTork's Avatar
I second this statement. Now im anxious to see progress updates
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 01-09-2010, 12:19 AM   #106
87 dually burb
my short bus
it was 20 degrees with 15-20 mph winds and got 4 inch of snow today
I'll wait till feb to look at it again
Old 01-14-2010, 10:55 AM   #107
justpball
justpball's Avatar
that sucks bro...too damn cold
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-14-2010, 10:48 PM   #108
87 dually burb
my short bus
55 degrees friday may get the fuel tank out and cut off the back of leaf springs to measure out my 2 link setup
pinch welds prepare to meet pavement
Old 01-18-2010, 10:43 AM   #109
justpball
justpball's Avatar
cut dat chit up bro...LOL
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-18-2010, 08:33 PM   #110
87 dually burb
my short bus
my side project was building the bath and closet for my master bedroom hoping to stuff the burb in the garage later this week and spend some quality time with it
going to mock up my rear links bags mounts and remove everything to prep for a 2" dropped cross member
Old 01-18-2010, 11:26 PM   #111
justpball
justpball's Avatar
Yea!
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-27-2010, 01:04 AM   #112
87 dually burb
my short bus
closet done hanging shelf system tomorrow
ruff in plumbing for bath this weekend
some times I hate being handy takes away from my truck time
side note got a 12 gal tank mounted valves on it
picking up air line tomorrow
thinking flat black with red stock rims and white wall tires
what do you'll think about that? old school ride
Old 01-27-2010, 10:39 AM   #113
justpball
justpball's Avatar
i know what ya mean i am the same way...I think that sounds cool... i dont know about the white walls though, would have to see it first.
87 Crew SWB
Build for the crew
90 burb 2wd
Old 02-02-2010, 11:26 PM   #114
87 dually burb
my short bus
well after installing new upper balljoints, break rotors,fuel pressure regulator and a set of new 31" bfg all terrian on the wife's 98 explorer the motor just crapped out
so quick tank and bag install bolt exhaust on and start driving burb till I get her a chevy this time she wants a late 90's tahoe
Old 02-20-2010, 09:45 PM   #115
87 dually burb
my short bus
well I cleaned out the burb this week and got the radio installed
I haven't clean or vacuumed it out since last may when the inspection died
well exhaust is on adding shock sunday hoping to tag and inspect it on wends
then have a shake down run next weekend
Old 02-22-2010, 12:53 PM   #116
justpball
justpball's Avatar
87 Crew SWB
Build for the crew
90 burb 2wd
Old 02-22-2010, 09:00 PM   #117
87 dually burb
my short bus
hoping to have this home friday for the family ride
little insight 88 half ton buckets up front
hitch w/ controller good driver quality
Old 02-23-2010, 10:21 AM   #118
justpball
justpball's Avatar
nice bro...
87 Crew SWB
Build for the crew
90 burb 2wd
Old 02-23-2010, 01:54 PM   #119
87 dually burb
my short bus
that then had more rot than most stuff from NY badly rusted with a nice paint covering both rocker, all 6 drs, fenders,quarters,rear wheel well had a 1.5" gap from rust you could see in carpet
sad though interior was perfect
owell back to my burb
Old 02-23-2010, 01:59 PM   #120
justpball
justpball's Avatar
oh well
87 Crew SWB
Build for the crew
90 burb 2wd
Old 02-26-2010, 02:25 PM   #121
SBTork
Garage wrench
SBTork's Avatar
any updates? wife's ride, or yours?
-Adam
Old 02-26-2010, 08:20 PM   #122
87 dually burb
my short bus
nothing lately pasted on buying the burb rusted bad all round
hoping to rework rear end measure for tank/cell replacement
having to move parking brake bracket and what ever will keep it laying on frame
Old 03-18-2010, 11:43 PM   #123
87 dually burb
my short bus
building my 2 link kit right now will lay frame in rear.
now debating on the front thinking 2" z and 2" sectioned crossmember
I need about4-5" to lay on pinch welds. frame is about 2" below body
what to do next??
Old 03-21-2010, 08:55 PM   #124
justpball
justpball's Avatar
body drop....
87 Crew SWB
Build for the crew
90 burb 2wd
Old 03-21-2010, 09:48 PM   #125
87 dually burb
my short bus
no need for a body drop if I redo the frame with 2x4 stock I can cut off the pinch welds and lay body
major set back I ripped out all the tub and notch work to start over
guy f'd it up tubs are set back 4 inches from center,bridge cover was 6"
above frame notch,tubs are 8" wider than needed
debating a 3 link with a wish bone now then build back around it
want to reuse my 3rd row seat so we can all cruise around in it?
