Old 06-05-2010, 06:16 PM   #101
jimmypop
Re: MY 1971 Jimmy Build Thread
subscribed
jimmypop is offline   Reply With Quote
Old 06-05-2010, 09:54 PM   #102
1949gmc
Originally Posted by hgs_notes View Post
It's wearing the coat of many colors. That's a lot of good work there.
Yeah, she's a bit of a mutt, that's for sure. Not for much longer, hopefully. I'll have some more of the zinc chromate down, soon, and then the whole thing will go urethane primer gray. I've also just gotten two gallons of Al's Liner to do the whole interior with. Small steps, but we're getting there.
1949gmc is offline   Reply With Quote
Old 11-10-2010, 09:53 PM   #103
1949gmc
UPDATE: My motivation has really been in the crapper the last couple of months, but I did manage to do some body work in the last few weeks and shoot some urethane primer today. Gotta say, seeing it in a different color (or all one color) for the first time in months is enough to get motivated.
Old 11-10-2010, 09:58 PM   #104
1949gmc
Last picture is of a beautiful Maple in my front yard. Fall is pretty but i hate winter.
First pic is of my new NOS dash pad..... i like it.
Old 11-10-2010, 11:16 PM   #105
hgs_notes
GEARHEAD
hgs_notes's Avatar
Looks great!
hgs_notes is offline   Reply With Quote
Old 11-10-2010, 11:23 PM   #106
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Nice! Looks like you got the hard part done; the dash pad.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 11-11-2010, 01:53 AM   #107
Jtrux
I'm a poor spectator
Jtrux's Avatar
Looks damn good, did you remove the bedsides just to paint the inside? I kinda scanned through it quickly.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 11-11-2010, 02:24 AM   #108
1949gmc
Looks great!
Thank you.
I might just leave it like this and start driving it!
Thanks. I replaced the bedsides with a pair of nos sides that I had. The originals weren't bad, but I lost patience with the patches... just couldn't get the things lined up right. It was so much easier drilling the spot welds and welding the nos ones on. I POR 15'd the inners while the outers were off.
Working on the doors is my next obstacle. I had them acid dipped in July and right away rust started creeping up from under where the outer skin folds over the frame at the bottom. There isn't any rust thru, but I don't really know how to stop that creeping rust.
Old 11-11-2010, 04:43 AM   #109
Deep C 915
Deep C 915's Avatar
Don't forget to pull out that glove box from ole' yeller. I think it was what you won in the auction. I will be starting the tear down of my 70' K5 next week., I pray it doesn’t turn out to be as big as your project.
I’m not worthy.....
Deep C 915 is offline   Reply With Quote
Old 11-11-2010, 07:15 AM   #110
vtblazer
vtblazer's Avatar
You've come a long way!
vtblazer is offline   Reply With Quote
Old 11-13-2010, 04:54 PM   #111
Erik V
You're doing what my plan is as well. My 71 has some rust, and lots of bends from years of trail running and racing in the early 70's. We pulled the body before I was in HS, with the plan of swapping in a 72 tub we got from a parts truck, zero rust, but with a bend window frame and some damage to a quarter panel. So we'll probably just repair whats needed on the 72 tub, and use that for my 71 swapping the VIN plate. Also means I get factory air since the 72 had that.
My question is: Did the soul of your truck change? Is it still the rusty plow truck original or is it now the 72 donar? I grew up in front of too many Herbie movies, Dukes of Hazzard, and Knight Rider. Since we picked up that tub years ago, I've often thought the truck will be great, but not the same truck it has been since Dad special ordered it in early 71.
Erik
Erik V is offline   Reply With Quote
Old 11-13-2010, 06:15 PM   #112
nickp51chevy
Do it!
Had;
Old 11-13-2010, 07:32 PM   #113
1949gmc
Erik
Funny, I know exactly what you're talking about. It is definitely not the rusty plow truck anymore, but I don't consider it to be the donor either. The plow truck had certain nuances like the switches for the plow and other do dads that I had no intention on removing because it retained that 'original' factor. I wanted to fix it up and then call the original owner and say "I fixed up your old truck and I want to show it to you". There's no way I can do that with the donor truck now, so all those little nuances are gone but it's like I'm starting from ground zero and the truck will have my little nuances in it that only I will be able to point out. Now, I will be using a ton of stuff from the plow truck, the entire interior and the drivetrain for example, and that will always be part of the plow truck. So, I guess it's kind of a mix between the two.
And like nickp says...... Just Do It!
Old 11-13-2010, 07:38 PM   #114
1949gmc
I’m not worthy.....
Hahaha. Yeah, the glove box, the rear seat and the gauges were really the prizes that I won.
Old 11-14-2010, 01:06 AM   #115
hgs_notes
GEARHEAD
hgs_notes's Avatar
My wife says this now about my C-10 because I changed the cab. I disagreed. What made the truck MY truck was the work I put into it and the pleasure I felt doing that work and driving the hell out of it. The rest is just metal.
Old 12-09-2010, 04:37 AM   #116
1949gmc
Updates
Rebuilt front axle two weeks ago....
~new ball joints
~new tie rods
~new axle shaft u-joints
~replaced inner and outer hub bearings and races
~new calipers
~new rotors
~new carrier bearings and races
~new Skyjacker 2 1/2" springs
~new shackles from ORD
~greaseable front spring bolts from ORD
~new brake lines front to rear
Old 12-09-2010, 04:41 AM   #117
1949gmc
Then I painted the dash and the steering wheel sandalwood brown, as per original. It looks good in the pictures, but it has some trash in it that I'll have to wet sand out..... maybe. And the steering wheel has a damn run in it, so I'm not posting that picture.
Old 12-09-2010, 04:50 AM   #118
1949gmc
Then, about an hour ago, (1:30am CST) I sprayed my Al's Liner in. Can't say that I'm real happy with it now... I added the Marina Blue tint to it that the truck is going to be... with no binder as per the instructions... I'm not happy with myself. When they say it's all about gun control, they aint lying! It's like six inches thick in the back where I started and about 2 mils in the front. I exaggerate, but that's what it looks like to me. Maybe it'll be better in the morning light. I hope.
Old 12-09-2010, 09:40 AM   #119
hgs_notes
GEARHEAD
hgs_notes's Avatar
It all looks good in the pictures. Nice color BTW. How much of the liner material did it take to do this?
Old 12-09-2010, 10:14 AM   #120
1949gmc
Hey Mike- Thanks. I tried to find the best pics I could, but it really doesn't look that good in person. I used almost two full gallons to do all this. I dont know what I did wrong. It looks like someone threw up blue cottage cheese in the back of the truck. I like the color, too..... too bad the metallic ran on every vertical panel.
Old 12-09-2010, 09:59 PM   #121
Erik V
whoa, speaker grill in the dash? I thought that was only a pickups thing. Looks sharp, dont worry about thick liner in the back, thats where all the dirty work will be anyways, a little carpeting here and there up front and it'll all balance out.
Erik
Old 12-11-2010, 01:01 AM   #122
1949gmc
Thanks, Erik. I'm not as angry at myself as I was. You're right, though... cover it in carpet and no one will ever see it.
I was curious about the speaker grille, too, so I look at every K5 I can to see if they have a speaker grille in the dash. This thread sheds a little light on the subject: http://67-72chevytrucks.com/vboard/s...d.php?t=355775 .
Old 12-11-2010, 01:55 AM   #123
hgs_notes
GEARHEAD
hgs_notes's Avatar
I had one 72 GMC K5 with the dash speaker for sure, possible another but I can't confirm it. All the others I have owned did not have a dash speaker grill.
BTW, if you're done with that spray gun kit for the Al's Liner, maybe you could sell it to me and recoup some of your costs. I was planning on doing pretty much the same thing as you did.
Old 06-06-2011, 08:43 AM   #124
hgs_notes
GEARHEAD
hgs_notes's Avatar
Soooo, what's been happening around here?
Old 06-06-2011, 12:33 PM   #125
1949gmc
Wow, it has been a long time since I posted anything here. Good to hear from you, brother.
Been trying to figure out the best method to get the truck painted in my garage. Been reading other's posts about getting good ventilation and, with that, waiting for some nice weather instead of painting in a cold dark garage.
Bought a gallon of epoxy primer from Southern Polyurethanes, Inc and got my doors and tailgate shot last week. Next up is getting the hood and cowl panel sprayed, hopefully Wed or Thurs.
Also been trying to figure out the steps in getting the final color on. Everything will be in primer; firewall, w/s frame, jambs, dash, everything. I'll be shooting Nason bc/cc. Do I go ahead and shoot the firewall, jambs, dash, kick panels in both paint and cc, with proper masking so as not to get the bc and cc on the outer panels, then install doors and fenders and shoot the rest? I guess that makes sense. Is there another way that I'm not seeing?
So, pretty much between thinking and trying to get my ass up off the couch, and a little primer spray, not much happening. I hope that'll change soon now that it is FINALLY nice out here. Anything new with you?
