#101 |
BLAZER THIRTY!!
![]() Join Date: May 2007
Re: Got My '63 GMC Today!
by chance can you supply me the part numbers from jeggs, i want the chrome 4412 i dont see it on there web site, i have a 62 with a 305 thinking of doing this swap, thanks in advance ,matt
49 chevy 5 window 20 year project (sold)😟 57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.) 62 GMC 305 V6 custom L/B 72 HIGHLANDER K5 BLAZER 2nd owner ![]() ![]() ![]() 71 K5 MAMMA'S RIDE! 63 GMC 4X4 305 V6 62 GMC SHORT BED SERVICE BODY V6 (STUMPY) 74 GMC CUSTOM 1500 L/B |
#102 |
Registered Loser
The carb is #510-0-4412S and the carb adapter is #720-1937. The throttle return spring bracket I used is #720-9678. You will also need a couple of fittings to attach the fuel lines but I will have to search for those #s. I got all my swap info from www.6066gmcguy.org. The swap was super easy. The only problems I ran into was a plastic riser under my stock carb meant I had to buy longer bolts to hold the adapter on and I had to buy 1 longer bolt for the front of the carb to hold the throttle return spring bracket on.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. Last edited by creep; 03-04-2010 at 05:17 PM. |
#103 |
BLAZER THIRTY!!
Thank's now i just need the funds, and convince the wife later, matt
#104 |
updates
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#105 |
Registered Loser
There's a link in my sig. to my other thread.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
