07-27-2011, 09:30 PM | #101 |
dazed and confused
Re: Project No-buck!
Patiently waiting on surprise
members met: redbaron69, billsbowtie,nc67 |
07-27-2011, 09:41 PM | #102 |
you may be right (read the latest issue of hot rod mag) but that's not what I'm refering to. If you tried to turbo this thing, the 350 would die immediatly, I'm pretty sure. I don't push it very hard at all.
07-28-2011, 02:08 AM | #103 | |
07-28-2011, 11:37 AM | #104 |
Here's a clue
07-28-2011, 12:48 PM | #105 |
Still plays with trucks
Those look like the tread pattern of the Falken tires I have on my Tahoe.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
07-28-2011, 01:41 PM | #106 | |
Now why would I get new Falken tires, when I just got new tires? Hmmmm? |
07-29-2011, 07:53 AM | #107 |
Has more rust than truck...
Ok, lets see the rims
07-29-2011, 08:25 AM | #108 |
Still Learning
No longer No Buck?
07-29-2011, 08:30 AM | #109 |
yeah, I think they just about double the cost......but of course I'm gonna get reimbursed for them when I start driving No-Buck for work once it cools off a little.
20x8.5 all around |
07-29-2011, 10:29 PM | #110 |
Nice choice of rims. They will look great on there.
07-30-2011, 01:01 AM | #111 |
Still Learning
Hey very nice choice there is a guy selling those local for around $750 a set. How much was your quote. I want the same rims for my project too.
08-04-2011, 05:06 PM | #112 |
My Spoon Is Too Big
7-30-2009 you picked up the truck, 7-29-2011 posted The rims pic
1972 C20, 03-14-10 Build Thread 2000 Silverado 4.8L, 11-04-13 (Currently Parting) 1999 Silverado 5.3L, 07-07-14. (Engine Donor) 2015 Ram 05-20-15 (Daily Driver) |
08-11-2011, 05:44 PM | #113 |
yep, 2 years Still waiting on the wheels, starting to loose faith in the company I ordered them from, but maybe they're getting the same run around crap some other board members have had from Boss trying to get them. Oh well...still working on it anyways. I installed an ECE super track bar and lower shock relocation mounts. The upper shock mounts are on back order, so I'll get them on later. I'm gonna pull the bed off to get to the rivets to remove the originals and also pop out the rivets that holds a cross member into the frame from the original leaf spring suspension (my 68 doesn't have that cross member). This cross member is right where the mufflers are, so the whole exhaust isn't quite where I'd like it, so once I get this cross member out, I can get the exhaust where it needs to be. Plus, I can run the rest of the exhaust out the back since the wierdo panhard bar no longer blocking it since it's no attached to the trailing arm. Painting is coming along: Got the roof and one bed side painted. I also have the other bed side primered and ready to paint. The doors need just a little more welding and then filler to smooth them out and they'll be ready for paint. Finally, the tailgate needs some more welding and it will be ready to finish up. |
08-11-2011, 07:39 PM | #114 |
Still Learning
Derek,
Where did you order your rims from? What's the plan for the fitment issues? Let's see some pics of the paint |
08-11-2011, 08:08 PM | #115 |
Tot Roddin'
Derek... are you planning on heading to KS GG's (9/2-4 Kansas Speedway) or the All Truck Nat's (9/9-11 Riverside, MO (N KC)) this year?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
08-11-2011, 11:39 PM | #116 |
Both, and possibly the Ottawa show (our vacation is the next week, so we're not sure what day we're leaving yet)
08-11-2011, 11:41 PM | #117 | |
The last word I got on them (last friday) was Boss had shipped them the wheels, but they hadn't arrived yet. Then they have to put tires on them, and then ship them to me. |
08-13-2011, 09:44 PM | #118 |
Tot Roddin'
Be sure to look us up... we'll have quite a few board members in our area.
08-18-2011, 12:08 AM | #119 |
Teaser shots of the truck. I have a few more coats of paint to put on the bed and doors, and I may scuff the front end and put another fresh coat on it.
Got two wheels put on tonight. Had to grind the front hub as most do. With only 8.5" wide wheels, I don't think I'd have to put spacers on the rear, but then again, it will look better with spacers. One thing is for sure, these wheels/tires are a lot heavier than the Racelines I have on my 68. But what do you expect for <$200/wheel compared to >$600 per wheel. |
08-18-2011, 08:37 AM | #120 |
Still Learning
Looks Great Derek! I know all about the fitment issues
Not too far away on this one. Did you say already what kind of paint you are using? |
08-18-2011, 11:08 AM | #121 | |
It's Valspar brand spray paint from Lowes. Its a Satin red. They have a few different colors now. I'm putting down a base layer of white primer (Valspar also) and really makes the red pop, and reduces the number of coats needed for good coverage. Looking at the stance with the new wheels and tires, I'd like it to be a little lower, but I don't know if that will happen (at least for awhile ). I might put a 1" block in the back and maybe cut a coil or so off the front, but we'll see. Need to get it out in the light, get the wheel spacers, and see how it really looks. |
08-18-2011, 04:19 PM | #122 |
Looks great.
I'm going the same route paint wise on my 69 K10 project just with a different color. It will be a parts hauler, winter beater & play toy that will get scratched up for sure. It won't hurt so bad when the paint is only $9 a quart.
08-22-2011, 10:29 AM | #123 |
Paint is done (except for the front clip...if I decide to shoot another coat on it)
I started putting the interior stuff back together. I still have some work on the tailgate. Pretty happy with the way it turned out. |
08-22-2011, 11:02 AM | #124 |
the truck is coming along awesome....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
08-28-2011, 01:13 AM | #125 |
Got some more painting done today and some other little things.
First, I tried to install my new Summit tach. Got it wired up and it starts at 500 rpms with the engine off, and then you fire it up and it goes up to 1200 rpms (about 500 rpms too high). It also seemed slow to respond. So it will have to go back Worked on painting the tailgate. I welded up the other side that I didn't get to before where the spot welds had popped loose. I didn't clean up the whole thing like I'd really like, I just wanted something to put on the truck for now. So I primed the whole thing, sprayed the letters with the off white from the grill, then taped the letters, and shot the rest of the tailgate with red. Turned out decent for the amount of time I spent on it. Then I worked on a buddy's jeep for a bit, then went to a cruise in. I took along No-buck for its first "public display" Ate some burgers, and came home. On the way home I got her up to 70 mph and it seemed to hum along great. Got the kiddo to bed, then back out to the shop. To paint the shop logo. Earlier in the day my wife helped out by cutting out some stincils with one of her scrap booking machines. We got some self-adhesive film. So I used those to make the shop logo. Here's the results. Pretty happy. Sorry for the crappy pics, only had my cell phone, and the paint is still drying as I type this: |
