Old 05-24-2010, 06:16 PM   #101
c10seconds
c10seconds's Avatar
Re: Mcgaughys Big Brake Kit
Originally Posted by N2TRUX View Post
I see that you have them mounted up and under the truck. What were the results from switching sides or flipping the brackets? Is it possible they are marked wrong? Would that move the calipers up higher if they were backwards?
Im hoping they are marked wrong or backwards or something. Im going to try and flip brackets around to see if I can get a different position on the calipers. The new locker has to go in still so its coming apart either way.
aggie: The problem was that the new caliper brackets were not sitting flush with the flange on the axle. The welds on the new brackets werent allowing it to sit flat. So I just took a grinder to the corners of the flange. This pic isnt the greatest but you can see the corner of the flange where I had to grind a little
c10seconds is offline   Reply With Quote
Old 05-24-2010, 10:31 PM   #102
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
man, although the 13" rotors look great out back, McGaughys has problem after problem with their kit designed for our trucks... atleast your finding solutions to them... they should give you some money back
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 05-25-2010, 09:41 AM   #103
aggie91
I'm just glad to be here!
aggie91's Avatar
Originally Posted by c10seconds View Post
The new rear set up is in! Do the calipers look like they should sit higher?
Originally Posted by aggie91 View Post
I have never seen the rear kit installed, but I thought the caliper would be more at 10 o'clock instead of 8 o'clock.
Is the bleeder screw at the top most part of the piston bore so that it bleeds out all of the air and nothing gets trapped in the caliper?
I guess you got your other issues from above corrected? What was the problem?
c10
I looked again and remembered at picture of an install done in a magazine, April 2010 issue of Street Trucks (may be Truckin). Anyway there is a picture of the rear end, from the passenger side (so that the front of the truck is to the viewers right), the pinion is at 3 o'clock and the caliper is at about 10 o'clock. I look on line for the pic, but did not find it. The lead photo for the article is a red and white 80's square body...
Hope this helps.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-25-2010, 07:07 PM   #104
stickelspeed
stickelspeed's Avatar
Here is the picture scanned from the mag.. April 2010 Street Trucks, page 68.
I think he is referring to picture 28 in article.
stickelspeed is offline   Reply With Quote
Old 05-25-2010, 11:14 PM   #105
N2TRUX
Happy to be here
N2TRUX's Avatar
Good find stickelspeed. So it looks like something is wrong with how brackets are mounted c10seconds.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-26-2010, 02:36 AM   #106
c10seconds
c10seconds's Avatar
Ya good call! Ill get those flopped around and update pics. For some reason I thought the calipers should be mounted on the most forward part of the rotor. Thanks for taking the time to help point me in the right direction. Now that I think of it, did anybody else kit come with directions????
Old 05-26-2010, 07:31 AM   #107
nlped
nlped's Avatar
Negative!!! The front kit came with instructions for a Denali
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 05-26-2010, 11:58 AM   #108
aggie91
aggie91's Avatar
Yea that is the article, pictures 27 & 28.
Karl
The LST Challenge:
Old 05-28-2010, 10:45 AM   #109
nlped
nlped's Avatar
Hey C10,
Did you use the stock hardlines on the rearend housing with this kit, or did you make up new ones?
Thanks,
Ed
Carter
Old 05-28-2010, 11:28 AM   #110
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Mine's been done for awhile, but I have been very busy with other issues.
L rear is at 2:00, R is 10:00. (Not sure if it's correct but I like the looks)
The whole kit, other than having rear axles turned, was a great fit.
I have not drove mine yet so I can't give any actual feedback.
Pic's in my siggy, only thing I changed from kit was lines.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-28-2010, 05:08 PM   #111
nlped
nlped's Avatar
I'm just about ready to get started putting everything back together. I got the rearend back from having the Auburn, gears & bearings/seals installed...cost me $100 this time .
Now I am in the middle of painting the calipers, rotors & CPP m/c. I did the rotor hats & veins and the caliper bridges in a high temp gloss black, and the caliper bodies in a high temp cast grey. The rearend housing and '95 4x4 Tahoe rear leafs are painted with PPG gloss black Akyln Enamel Chassis paint. I'm hoping to get the rearend ready and possibly put under the Blazer this weekend.
Quick pic of some parts
Carter
Old 05-29-2010, 12:44 PM   #112
c10seconds
c10seconds's Avatar
Originally Posted by nlped View Post
Hey C10,
Thanks,
Ed
Stock hard line are being used for now. I will make up some new ss lines once everything is where its supposed to be. What about you?
Old 05-29-2010, 05:07 PM   #113
nlped
nlped's Avatar
Same here!
Carter
Old 06-16-2010, 05:00 PM   #114
c10seconds
c10seconds's Avatar
Sooo... Is there a bolt-on caliper upgrade for this kit?
Old 06-16-2010, 07:48 PM   #115
nlped
nlped's Avatar
You're already looking for upgrades? Problem?
Carter
Old 06-16-2010, 09:24 PM   #116
c10seconds
c10seconds's Avatar
I have had ZERO problems with this kit. I'm very happy with it actually. I'm just wanting "the cool" calipers
Old 06-16-2010, 09:49 PM   #117
nlped
nlped's Avatar
!!! I understand, I just sanded and painted mine to make them a bit more personal
Carter
Old 07-13-2010, 12:21 AM   #118
c10seconds
c10seconds's Avatar
Did you get you kit installed???
What calipers are are bolt on replacements for these?????
Old 07-13-2010, 01:12 AM   #119
edflores
Contact McGaugys to see what the calipers are off of. I'm planning on picking these up this month, just trying to see who has the best price.
edflores is offline   Reply With Quote
Old 07-13-2010, 08:49 AM   #120
N2TRUX
Happy to be here
N2TRUX's Avatar
Take a look in the vendors Marketplace. I know Nate Porter is a McGaughys distributor.
Articles-
"Refining Sierra"
Old 07-18-2010, 12:12 PM   #121
55belairtim
80-85 cadaillac seville
or 7986 monte carlo fronts but you wont have parking brakes
55belairtim is offline   Reply With Quote
Old 07-18-2010, 12:19 PM   #122
N2TRUX
Happy to be here
N2TRUX's Avatar
or 79-86 monte carlo fronts but you wont have parking brakes
Both viable options, but no e-brake AND they aren't 13" disc.
Articles-
"Refining Sierra"
Old 07-18-2010, 01:56 PM   #123
55belairtim
i never said they were 13"
just told you what the calipers are off of
the cadys were rear calipers they have ebrake built into them sorry should have specified they were rears.
Old 07-18-2010, 04:17 PM   #124
N2TRUX
Happy to be here
N2TRUX's Avatar
Sorry, I misunderstood your post. Thanks for clarifying.
Articles-
"Refining Sierra"
Old 07-20-2010, 09:17 PM   #125
kunzy420
So all in all would you guys reccomend this kit both front and rear? Seems like the front is a breeze to install, but seems like a lot of you guys are having problems with the rear.
I definetly want to go big brakes on my 86 but wondering if I should look at other options
kunzy420 is offline   Reply With Quote
