Old 04-13-2010, 04:59 PM   #101
Tow Me
Glen
Tow Me's Avatar
Re: Crewella - My '81 crew cab, short bed 1/2 ton
The front tires are pretty narrow... But the height is right. I found a set of 20s for a good price so I may just go that route... Well see. I think my rear tires are 245/75-15, but that's just a guess. As for the headlights.... I have everything wired up and I did notice a parking light was not working... I was hope it was burnt out but I didn't check. I ordered some relays and a dual harness to boost my lights and so I can wire up all 4 lights on high beam.
Glen Simpson
Severed Ties - Oregon
Roseburg, Oregon
  • 1983 Chevrolet C10 - Ginger
    Photos
Past Trucks
Tow Me is offline   Reply With Quote
Old 04-23-2010, 12:12 PM   #102
Tow Me
Glen
Tow Me's Avatar
The engine is mostly wired up, but I need to bolt on the headers and get an exhaust made. I'm waiting to put the inner fender wells in along with the battery tray. My radiator had some damage but we had it tested and it works fine. I Photoshopped Crewella lowered on rallies and blurry 20s.
Glen Simpson
Roseburg, Oregon
    Photos
Past Trucks
Old 04-23-2010, 02:32 PM   #103
WillieloRidez
WillieloRidez's Avatar
That is looking sweet man. I like the stance...makes me want to shorten my truck... Keep us posted
WillieloRidez Drive em in Drag em out!
Projects:
1956 Chevrolet 210 2dr post
58 chevrolet 2dr delray
58 chevrolet belair 4dr hardtop
1965 Chevelle big block 4spd
88 crewcab 1/2 ton long bed aka STRETCH Lt1-4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=388445
WillieloRidez is offline   Reply With Quote
Old 05-08-2010, 09:14 PM   #104
Tow Me
Glen
Tow Me's Avatar
We are getting closer on getting Crewella on the road and I have some updated photos.
A few hours ago, we got the motor started and it sounds really good. The headers are installed and I see they hang down very low. I may cut the flanges off and have the exhaust welded on with reducer. The collector diameter is only 2.5" so it will transition into the exhaust just fine. Getting the headers on was a pain in the ass. My dad actually had the task of doing that. He had to jack to motor up to get the driver side on.
My OEM grill was cracked and didn't look real good up close. So I ordered a new reproduction grill and bezels a while back. I'm pleased with the fit and look. I used a file on in a couple spots on the new grill to make everything fit nicely. I had to do some trimming to make the emblem fit too. I think it turned out pretty well. See the photos below. Also, after doing the '91 Suburban grill swap, I just realized the lower metal piece (between the bumper and grill) is different than the stock '81 piece. Previously I had the grill set in place, but when I finally screwed it all in, the bottom didnt look right. I found the '91 piece in my barn since I was planning to use the red one that matched my truck. I sprayed it semigloss black and it is hardly noticeable.
Since I bought some new rims for my bagged '83 SWB, I have a set of Centerline 20s for Crewella. They didnt fit right on like I thought them would. The centers of the wheels don't work with the heavy duty brakes, so we did some grinding on the wheel bearing and the inside of the wheel center cap.
Added the stainless trim around the turn signals and fender opening.
New grill in place, but it still needs a bowtie!
I had to modify the grill to get the emblem to fit the way I thought it should.
And after all the trimming the bowtie looks like it should be there.
I robbed the fan shroud off a parts Suburban and it makes it look a little better.
Got the overhead console too from a Suburban.
Powder coated the battery tray, and the inner fenders (not shown)
New bed bolts and weatherstripping from www.classicparts.com
Hidden hitch is permanently in place now. This hitch originally hung down below the bumper, and my dad modified it to fit inside the frame rails.
I got the 20s to fit after a bunch of grinding.
Glen Simpson
Roseburg, Oregon
    Photos
Past Trucks
Old 05-09-2010, 07:46 AM   #105
menace121978
menace121978's Avatar
looks sweet man! i like the wheels
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 05-09-2010, 07:57 AM   #106
BGRAFX
The crew looks damn good glen. I like the newer grill setup and the wheel fender trim looks perfect.
BGRAFX is offline   Reply With Quote
Old 05-09-2010, 10:28 AM   #107
joe231
joe231's Avatar
very nice!
I like the wheels and that new grill looks killer. I need one of those. Where did you get it?
I have the same overhead console but in blue, I haven't figured out how I'm going to mount it yet though....have you come up with a plan?
CHEVY ONLY
Old 05-09-2010, 12:53 PM   #108
Tow Me
Glen
Tow Me's Avatar
Thanks guys!
Originally Posted by joe231 View Post
very nice!
Joe, the overhead console has a metal bracket that you bolt to the ceiling, then the console bolts to it. If you don't have one, I would get it to make installation easier. I can get a picture of the bracket next time I'm at the shop.
I got the grill and bezels at www.classicparts.com. $98 for the grill... and I think the bezels were $20-30 each.
Glen Simpson
Roseburg, Oregon
    Photos
Past Trucks
Old 05-09-2010, 01:11 PM   #109
BGRAFX
I'm going toi the junk yard later, maybe I will find myself a console so I can be cool like you guys
Old 05-09-2010, 02:42 PM   #110
joe231
joe231's Avatar
Originally Posted by Tow Me View Post
Thanks guys!
I have the bracket for the console, but it doesn't fit the crew cabs ceiling very well, the burb I got it from didn't have the double skin ceiling like the pickups. It had exposed supports that te bracket was riveted to. I'm thinking I might cut some keyholes in my inner roof skin for the console to slip into and just run self-drillers in the back two holes to hold it up.
Thanks for the info on the grill
CHEVY ONLY
Old 05-09-2010, 03:50 PM   #111
Tow Me
Glen
Tow Me's Avatar
I haven't test fit the console in the crew cab so hopefully I dont have issues too.
Glen Simpson
Roseburg, Oregon
    Photos
Past Trucks
Old 05-10-2010, 02:44 AM   #112
qu1cks1lver56
qu1cks1lver56's Avatar
Those mirrors have me thinking. Where'd you get them? And do they come in chrome?
Nice looking truck btw, I wish I had the time/money to put together a CCSB, I love the look.
qu1cks1lver56 is offline   Reply With Quote
Old 05-10-2010, 11:31 AM   #113
Tow Me
Glen
Tow Me's Avatar
I bought the power mirrors off of Craigslist. A guy was parting out a Suburban and he was willing to ship me the mirrors, harness, and switch from Washington. I have been tracking some on eBay and haven't seen them under $250. I got mine for $200. I'm not positive, but I think they were only available on '89-'91 Suburbans. Maybe Blazers and Crew Cabs. I've only seen them on a Suburbans.
Check this LED signal conversion by BLE 'BURBAN.
http://67-72chevytrucks.com/vboard/s...=389166&page=2
Glen Simpson
Roseburg, Oregon
    Photos
Past Trucks
Old 05-10-2010, 11:42 AM   #114
BGRAFX
I've got a pair that I may not use. Bought them 6months ago from another board member.
Old 05-10-2010, 12:39 PM   #115
Tow Me
Glen
Tow Me's Avatar
If you don't mind me asking, what did you give for them? Did it include the harness and switch. I'm wondering if I got a good deal or not.
Glen Simpson
Roseburg, Oregon
    Photos
Past Trucks
Old 05-10-2010, 12:49 PM   #116
BGRAFX
I didn't get the harness or switch, I got a hell of deal on them since I trade some other parts I had layin around. I do know they are very hard to find which makes the price so high. I was going to put them on my suburban but never took them out of the box, then I sold that and just got my dually home this past weekend so I'm not sure if I will use them or not. Right now its all stock farm truck with the exceptoon of a cowl hool, so mirrors might be the change it needs lol. Your truck has come along way and looks good.
Old 05-10-2010, 08:13 PM   #117
qu1cks1lver56
Yeah that conversion is awesome. I've been thinking of new mirror ideas because my crappy ebay ones are rusting and theyre brand new. I like the idea of those because every set of dumbo's that have been on my truck move in a little at highway speeds and everytime the door is shut. Drives me crazy, and I kind of like the idea of those off the suburban. I don't know how they'd look on my truck, but I have to at least try it, do they bolt in the same holes as the dumbo's?
Old 05-11-2010, 10:17 PM   #118
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I love that grill! And $98 bucks seems dang cheap too. You guys keep up the nice work! It's making me want to get my 76 done or atleast running.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-15-2010, 11:23 PM   #119
Tow Me
Glen
Tow Me's Avatar
So.... today was the first time I have ever driven Crewella!!! Runs great too!
Granted, I didn't have brakes and it was just on my dad's property, but I drove it. I got my Centerline caps to fit on the front after a little more grinding on the wheel bearing area. I cleaned and mounted the washer fluid tank, replaced the heater hoses, cleaned/painted the hood hinges, and pulled out the old flooring. There is some rust I need to address but it was expected. I have OEM rockers and floor panels out of a Suburban so I have everything and more for when repairs are needed!
Inspected the rear brakes and everything looks good, but my dad and I couldn't get the brakes bled. We may have a problem with the master cylinder, but we have to try again tomorrow since we ran out of brake fluid.
Here are some updated photos.
Glen Simpson
Roseburg, Oregon
    Photos
Past Trucks
Old 05-16-2010, 12:00 AM   #120
BGRAFX
Looks Good!
Old 05-16-2010, 07:37 AM   #121
menace121978
sweet man! looking good
"Dennis the Menace"
Old 05-16-2010, 10:05 AM   #122
WillieloRidez
Freakin SWEET!!! How soon till you get the bed back on and pictures????
Projects:
Old 05-16-2010, 12:01 PM   #123
scotts62
One day...
scotts62's Avatar
Awesome!!!!
Love the looks of it with those wheels!!
Scott
93 crew cab build
Project 62
Old 05-16-2010, 01:42 PM   #124
Tow Me
Glen
Tow Me's Avatar
Thanks! I need to cleAn up the under side of the bed and have some tack welds repaired on the fenders before I put the bed on .... So hopefully next week it will be on. Thanks for all the feedback!
Glen Simpson
Roseburg, Oregon
    Photos
Past Trucks
Old 05-16-2010, 03:27 PM   #125
joe231
joe231's Avatar
On second thought Glen, those wheels are just horrible!
You should box them up and send them to me for proper disposal
CHEVY ONLY
