03-25-2010, 08:42 PM | #101 |
VA72C10
Re: 1969 c10 the start of something fun
looks good. THe interior looks very clean
Looking for a 67-72 swb or blazer project in or around VA. |
03-26-2010, 12:01 PM | #102 |
Question about your instrument panel:
did you keep the stock gas gauge? If so how did you wire it? I like your idea of filling/replacing the 4 smaller gauge holes with aftermarket gauges, but I want to keep my stock gas gauge. thanks, and looks good! Scott
1970 C10 Fleetside longbed 350/TH350 |
03-26-2010, 12:13 PM | #103 |
I did keep the stock gas gauge but do not have it hook up yet If get it hooked up Ill let you all know. Some one needed to see how my eBay 3 speed shifter was hooked up so pic speak louder then word good luck with the install..
04-27-2010, 03:30 PM | #104 |
More work on the truck, I got a notch in some new parts and blah blah blah
04-28-2010, 01:54 AM | #105 |
Mike.... That truck is SIIIIICK! That is exactly what I want to do to mine, Flat black with red accents! The Halo lights are awesome, I was in the air about them until I saw your pics... I getting em!
You mentioned that the TJ springs in the rear are alittle soft... did you use the TJ rear or front springs? I read through the whole thread but didn't notice if you mentioned it.... |
04-28-2010, 10:09 AM | #106 |
Thanks man. It was the rear spring from the jeep tj (97 and up) They have pigtails on both ends so it works out. Good luck with your build.
04-30-2010, 11:22 PM | #107 |
Any one know how to make shore that top dead center is tdc on the intake not the exhaust stroke ????
05-05-2010, 03:45 PM | #108 |
some work done but a lot to go
05-05-2010, 04:25 PM | #109 |
05-05-2010, 07:27 PM | #110 |
got more done
more parts for Craigslist list Last edited by mr mike; 05-05-2010 at 09:43 PM. |
05-07-2010, 11:26 PM | #111 |
any help would be nice on this......
I got the engine running but the gear drive i put in and its the loud one, on the first start i was hearing just a small bit of wine but not much at all, would the gap from the cam button to the timing cover play any effective with the wine ????? |
05-08-2010, 11:15 PM | #112 |
All fixed sounds good now just had to take it for a small drive
05-09-2010, 08:43 PM | #113 |
Grandpa in the rustmobile...
nice how many lbs ya think you could haul with the TJ springs ima look into some at the local custom shop thanks!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
05-10-2010, 02:22 AM | #114 |
Well i would say at the max maybe 400 to 500 pounds
05-13-2010, 04:25 PM | #115 |
Got more work done and got the back down some more.
05-13-2010, 10:02 PM | #116 |
VA72C10
Looks good!
05-14-2010, 07:38 PM | #117 |
I was playing with the camera today for fun
05-14-2010, 10:59 PM | #118 |
looks good. What wheels are those? Id suggest adding a backing plate or boxing the frame around the notch.
05-14-2010, 11:10 PM | #119 |
The rims are 20x8 Chrome American Racing Vintage Iroc Replica
and you are right, I have to do something with the frame notch. I was thinking of boxing in or making a new rear frame. I will be z'ing the frame to when i put the air ride in when ever that is. |
05-15-2010, 10:56 AM | #120 |
Chevy Lover Till The End.
Man you have done an EXCELLENT job on your truck! I love everything about it. On your gear drive, I don't use them but I think they sound killer but I kinda like to hear my motor, you know with the gear drives it kinda drowns out your motor but hey, you are doing awesome!!
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
05-16-2010, 12:31 AM | #121 |
Thanks man, But i will say I am kinda bummed I am running out of stuff to do.
Ill have to think of some small stuff like shaving the tail light and drip rail and getting the rest of the stuff i need for the air ride. Ill think of something off the wall to do to it maybe like a 12v Cummins Diesel |
05-17-2010, 01:13 PM | #122 |
06-02-2010, 08:41 PM | #123 |
Me to, if you had a full drone truck i think it would be ezz other then boxing in the frame.
06-07-2010, 09:39 PM | #124 | |
06-07-2010, 10:35 PM | #125 |
Love your truck... And I LOVE that sticker.
