Old 01-06-2012, 01:24 PM   #101
KrazyRay
KrazyRay's Avatar
Re: 4x4 sway bar changeover
I have a pair from a 69. $55 shipped.
Thanks,
Ray
KrazyRay is offline   Reply With Quote
Old 01-23-2012, 07:47 PM   #102
67gmcstepside
Ray, i received the sway bar setup but the spring packs that came with it are 2 different sizes of which neither fits my existing setup. I have a 72 blazer 1/2 axle in front. Are these for the 3/4 ton setups only?
67gmcstepside is offline   Reply With Quote
Old 01-23-2012, 08:35 PM   #103
KrazyRay
KrazyRay's Avatar
They should all be the same. The plate on the passenger side is bigger to allow for the pumkin. Center to center of the holes should be 3 5/8" on three of them and 4 3/8" on one hole (the one up against the pumkin. Here's some pics of a 1/2 ton that I just pulled yesterday:
Old 01-23-2012, 08:44 PM   #104
67gmcstepside
Thanks Ray, once it stops rainning i will try another trial fit.
Old 03-05-2012, 04:49 PM   #105
2003 silverado
2003 silverado's Avatar
Ray iam in search of the brackets in post #94 As I have the plates mounted and the bar but my blazer never had the brackets. In a previouse post someone asked about a lift on there trk ,They sell disconnect links for the sway bar and it raises the sway bay two inches from the axel>Hope that helped him Let me know what you have ? Thanks Dave 19382
!972 K5 Blazer,Highlander,A/C a twin to the one I Had
1972 K/5 Blazer CST Highlander 15YR project
2003 Silverado Crew 2500HD (Daily driver)
1997 Ford focus (Beater)
2003 ford Taurus (student)
2014 Ford Fusion HYB (wife)
2003 Jetta ( Student)
2003 silverado is offline   Reply With Quote
Old 03-05-2012, 06:35 PM   #106
KrazyRay
KrazyRay's Avatar
Dave, Those are the tough pieces to get for the setup. You have to sacrafice a 4x4 square body frame to get them. Also, the front crossmember is a little different on a 72 so you might have to do some fab work to make it happen. I have a 77 crossmember with those brackets, but there is some welds that I had to cut that will need to be cleaned up...very useable. $65 shipped for the crossmember and brackets.
Thanks,
Ray
