#101 |
Re: Be Gentle. . . I'm an Amateur.
For my ebrake... I did use the S10 one, but I had to remake the arm itself for length and to look right. The computer I mounted above the heater on the passenger's side with the wiring going down the right side and out through the firewall there. Of course it helped going with a Painless Harness for the engine and chopped up the S10 harness for the chassis and ABS.
Cheers, Ted.
'51 Chevy Build - In the design stages Aut viam inveniam aut faciam - I will either find a way or make one. If you don't have time to do it right the first time, when will you... My new build - https://67-72chevytrucks.com/vboard/...70#post8958970 |
#102 | |
-MG P.S. I love the creativity in your build, lots of good ideas.
1951 Chevy 3100/S-10: http://67-72chevytrucks.com/vboard/s...d.php?t=406072 1957 Chevy 3200 1971 2WD Blazer - Sold Last edited by Groyd; 01-31-2011 at 09:29 PM. Reason: Missed quote |
#103 |
Certified Car Nut
The truck is really looking good man.
#104 |
6>8 Plugless........
![]() Join Date: Sep 2007
Very nice progress. Good descion to ditch the washer coupler.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#105 | |
I'm going to try and get the doors flush once it gets a little warmer here. I only hope it doesn't require what you've had to do to yours Kabwe. I lack the patience and skill.
1951 Chevy 3100/S-10: http://67-72chevytrucks.com/vboard/s...d.php?t=406072 1957 Chevy 3200 1971 2WD Blazer - Sold |
#106 |
hey i'm wanting to put the 5.3 in my truck also but i was wondering what your plans are as far as a fuel tank?
#107 | |
I'll have to double check all of that, but thats what I remember off the top of my head. My cousin is the brains helping me out, otherwise I wouldn't have a clue. Lots of info on here if you're doing an s-10 LSx swap. http://www.s10forum.com/forum/f213/l...mation-390967/
#108 |
yeah i am currently working on a 47 gmc and my brain has never been this worked before in my life. There is so much thinking that goes into these ground up restorations and then adding in electrical just takes it to a new level. im excited to put a 5.3 in it though
#109 |
I need some help on this one, I've considered about a thousand different paint and color options. I've been considering "Legend Lime Green" that was on the 05-06 F**d Mustangs and maybe some small gray or black pinstriping.
![]() But after I saw the "Mocha Steel Metallic" on the newer GM models I've kind of been jumping back and forth. I know I definitely want some pinstriping done afterwards and I'm not sure how great it would look with the brown. I know kustombrad http://67-72chevytrucks.com/vboard/s...d.php?t=320546 did some stripes with brown and it looked great. Any input appreciated. ![]() If it helps, I'm planning on these wheels. ![]()
#110 |
Hey Groyd, I like the Mocha Brown the best, but that is just my preferance. I love the wheels.
How's the wiring going?
My Build Thread 51 chevy http://67-72chevytrucks.com/vboard/s...d.php?t=437496 48,49,50 Chevy trucks. 41 Olds |
#111 | |
The wiring had been about halfway done for about a week and a half. We should hopefully finish it up this week. (Fingers crossed)
#112 |
ABS Delete
I got rid of all the ABS stuff and put a proportioning valve that mounts to the master cylinder/booster. I looked everywhere trying to find fittings on the s10forum for the proportioning valve. A guy at Autozone ended up letting me go to the back with my parts and just fit everything. Here is what I ended up with. I got the bracket and lines that attach the MC to the prop valve from waylayedinc.com, here is an image of the sizes and the mount.
![]() ![]() I don't know if anyone else is going this route, but if so these part numbers might save some time at Autozone. I used adapters for the fronts PAA-R350 (#561007) 3/8"-24 to 1/2"-20 PAA-R340 (#561006) 3/8"-24 to 7/16"-24 I then used inverted flares to attach the factory s10 lines to the adapters to the proportioning valve. BLU-4C (#845016) BLU-5C (#845017)? ![]() The lines need to be cleaned up and moved around a little, but you get the idea. This may be a bunch of wasted info, but it might help somebody save a little time. ![]()
#113 |
Man you saved my life, I have needed that diagram for 2 weeks. I switched all my '85 s10 brake lines over to newer bigger lines because my s10 was a rust machine and I wanted to be safe. I know I could have taken my brake lines to the AP store but now I don't have to. THANK YOU
#114 | |
#115 |
Looks great! Subscribed
#116 |
I moved my e-brake to the floor on the drivers side.
![]() PO had a bunch of lights in the dash. I cut them out for the A/C controls, and moved the wiper controls in the choke slot. I'll fill the wiper spot later this week. ![]() ![]() The wife said she wouldn't set foot in the truck if it didn't have A/C. I had to cut up the inner fender to mount my battery and cut out a space for my A/C compressor. ![]() Seems like I end up grinding off about three times the amount that I weld. I'm not getting the hang of this craft yet. The cheapo welder doesn't help either.
1951 Chevy 3100/S-10: http://67-72chevytrucks.com/vboard/s...d.php?t=406072 1957 Chevy 3200 1971 2WD Blazer - Sold Last edited by Groyd; 04-06-2011 at 11:01 PM. |
#117 |
I like that brake handle location that looks sharp, and I was wondering just this morning where I was gonna put the battery, your idea looks like a good one that I may have to do myself. Looks good.
1949 Chevy/ S-10 1966 Chevelle Malibu 2002 Chevy Z-71 |
#118 |
My wife said the same thing -
Still not a compressor in my truck LOL! I don't blame you though. Those OK summers get HOT. The layout looks nice and clean too. Don't sweat the grinding. It's all part of the learning process. You're doing great! |
#119 |
![]() Join Date: Apr 2008
Well if you are planning on the Coy's C-55 wheel then you better call and see if they have your size now. Those wheels have been discontinued and they only have limited sizes left. I wanted 17's but there was none left, so I got the 18's instead.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
#120 |
Truck is lookin' good dude! Keep at it...
It's all about the stance, baby! http://67-72chevytrucks.com/vboard/s...d.php?t=320546 |
#121 |
Glad to see one of us is making progress
#122 |
Ain't that the truth lol.
Keep up the good work.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
#123 | |
Thanks for the kind words everybody.
Just got the Vintage Air unit home. I'll try and get it at least mounted later this week. Expect some questions and updates.
#124 |
I forgot to mention that I went against using the s10 gas tank, because you had to change the entire sending unit and not just the fuel pump. I ended up using a camaro tank out of a 1994 I think. The fuel lines to the filter are ran, I didn't have enough to even come close to making it to the engine.
![]() It doesn't hang too low. ![]()
#125 |
Vintage Air unit mounted under the dash. I've yet to do any plumbing besides the four lines that go from the unit through the firewall.
