#101 |
![]() Join Date: Feb 2003
Re: My 65 Pickemup project
Ya good call, would sure be nice to run the stocker. I'm pretty sure the low hump will be fine.
Ok don't laugh, this is CIRCA 1990 and it was my high school truck. Small block with TH 350 (low hump). If a TH 350 will fit I'm sure a 700r will too. ![]() Changed the colour right after school. I know I know.LOL ![]() |
#102 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Nothing wrong with that....that was how it was back then. Besides you had a nice ride
#103 |
[quote=Delmo;4161152]Ya good call, would sure be nice to run the stocker. I'm pretty sure the low hump will be fine.
You'll have to convert to a high hump or fab a raised tunnel or it will hit the trans with the Porterbuilt X-member, sorry for the bad news.
2-20, 2-21 whatever it takes! |
#104 |
Well thanks for ruining it Hickup. Duuude that burb is perfect.
#105 |
60-66 Nut
So the Porterbuilt dropmember raises the engine and trans from the stock location?
#106 |
yes, it raises about 3" and moves it forward about 2" . If you look at the low hump floor it is already marked for the cutout and the high hump drops perfectly into place. When you get the high hump youll need both pieces, the big part simply unbolts but the small part is spot welded in.
#107 |
Jesse
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. Last edited by Liz; 08-28-2010 at 03:44 PM. Reason: wtb |
#108 |
Dude, beautiful work. I wish I could get my truck started
#109 |
Thanks LAZ, ya money is evil hey.
Well got a bit done this weekend, not as much as hoped but it's a start. Air lines ran, brakes done, wheel bearings in yada yada. ![]() ![]() ![]() ![]() ![]() |
#110 |
Man those tires are close to the bedsides! Also how close is that bumper to the ground? Great progress I love how you start with the back of the truck! Keep the pics coming!
Tony from Norcal |
#111 |
Ya there is about 1/2 inch per side to the wheels. Changes a bit when it goes up but I hope it will work out. the rear bumper is an inch off when it lays frame. The frame sort of balances on the center cross member bolts. I am going to swap those bolts for a counter sunk allen head bolt. That should get me another 1/4 inch lower. LOL
#112 |
Delmo,
SUPER JOB really like this project . STAY TUNED I am building almost the exact same build but it is a " Schlong Box" . Full Porterbuilt deal like yours. We are going with an ol skool shop truck theme to promote my powdercoating business. The truck was a dry west texas Craiglist find. NO RUST we will powdercoat the whole project flat clears etc. to keep the patina. Also some custom metal work by Roger Burman Lakeside Rods (61 IMPALA DASH) inner fenders etc. KEEP UP THE GREAT WORK what trans are you using? thanks, Greg www.extremepowdercoating.net |
#113 |
![]() Join Date: Aug 2010
The rims are great looking, love the outer ring chrome with the solid black.
#114 |
Man, I really Hate you for doing this to such a perfect truck. LOL j/k Dude that is one of the Best looking trucks I have seen in a long time. I love the patina finish on it. I have been looking for a very long time and yet to find me one in that good of shape. Even the seat is in tack..
#115 | |
#116 |
Trimmed up the tank today and stuffed it in. I have to pick up some bolt clip thingys tomorrow and bolt it down. Not a bad fit though, the tank is massive.
![]() ![]() Last edited by Delmo; 09-06-2010 at 09:31 PM. |
#117 |
What is that fuel tank out of?
#118 |
#119 |
Is there a reason you have it turned around vs. how it's "supposed" to be installed?
#120 |
Nothing is how it's "supposed to be" on this truck. Fits better.
#121 |
chevy only
![]() Join Date: Sep 2006
Delmo!! Killer work kat!, and you ol pro street truck is sic!!!
CHEVY ONLY... Nothin Else ! |
#122 |
Thanks Dino.
#123 |
Very nice Delmo! Do you plan on putting any kind of bed floor in? I see your bed is bolted directly to the bed cross sills did you body drop the truck or do you have a 3/4 inch spacer to make the bed sit even with the cab? Keep up the progress and pics!
Tony from Norcal Posted via Mobile Device |
#124 |
Good eye man, ya there is a spacer for the front of the bed. I was going to drop it the amount of the front rad support pad but got too lazy to cut the rear box mount. I still might do it if I don't like the height. Definatley puttin wood back in it, the 90 degree fitting for the rear bag sits up about 1/2 an inch from the kick so I guess that will be the lowest point for the bed wood. I have a cool idea for the wood, can't wait to do it.
#125 |
Your pro street GMC's are bad man!
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
