Old 11-09-2011, 05:02 PM   #101
kikkegek
kikkegek's Avatar
Re: Suburban K20 1986 Silverado
I installed a timing tab i can see from the front of the car to be able to check my timing.
installed a mr gasket 8" balancer timing tab....added some BLING to my ride. hahaha
also replaced my broken choke pulloff with a working one from a friend.
kikkegek is offline   Reply With Quote
Old 11-10-2011, 07:32 AM   #102
motornut
78K & 79C Jimmys
motornut's Avatar
gee gotta remember to buff that,ma bling is dirty
but looks like yours
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-10-2011, 11:11 AM   #103
kikkegek
kikkegek's Avatar
hahaha, I only have to make a new mark for timing..because this tab is in a new position...
did you do that yet?
Old 11-10-2011, 02:44 PM   #104
motornut
78K & 79C Jimmys
motornut's Avatar
nope I think i have the older block,diff from you....dip on drivers
dosn't the mark change,by the block style
but i havn't seen my timing light in a while,to see where it is since i've been twisting the dist
John
Old 12-02-2011, 02:19 PM   #105
kikkegek
kikkegek's Avatar
Today addded a mr gasket 929 kit to my ingition.
new weights, bushes and springs. used the softest springs, because I mainly drive on LPG and that can take faster advance and less advance.
dont really notice a difference. Will have to waite untill I get gas the next few couple of times.
Old 12-27-2011, 06:00 AM   #106
pat386
misshape grape
pat386's Avatar
Always love seeing people across the pond enjoy our steel! Nice ride!!
Don't you just love rumors? I always find out stuff about myself that I had no idea I even did..
pat386 is offline   Reply With Quote
Old 12-27-2011, 04:01 PM   #107
kikkegek
kikkegek's Avatar
thanks man! Appreciate it.
I am gettin close to finishing my HID Projector Retro.
The Morimoto Mini H1 projectors seem to fit my headlight bowls perfectly and I tested them 2nite in the backyard (yes, in the Netherlands, we have small backyards)...
Old 12-29-2011, 04:41 AM   #108
kikkegek
kikkegek's Avatar
installed them last night to see if they are also projecting straight mounted in the car and they seem fine.
check out the difference in output between top is halogen en bottom is projectors with 5000k bulbs
Old 12-29-2011, 10:32 AM   #109
motornut
78K & 79C Jimmys
motornut's Avatar
they look great
quite a difference
bigger then my back yard,sure can't get a truck back there lol
John
Old 01-03-2012, 05:08 PM   #110
kikkegek
kikkegek's Avatar
finished my Xenon projector Retrofit.
gotta glue the lenses back tomorrow and then throw them back in the car.
Old 01-18-2012, 02:41 PM   #111
kikkegek
kikkegek's Avatar
update. headlights mounted. here are some pics:
http://youtu.be/-nQZ7nf1kIQ
Old 01-18-2012, 02:50 PM   #112
68Timber
I know the pieces fit
68Timber's Avatar
Take that out, ASAP. Those plastic bushings wear out fast, then the weights start egging out on the posts. If anything, just use those weights with the stock springs and bushings.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-18-2012, 03:25 PM   #113
68Timber
68Timber's Avatar
The headlights turned out sweet.
John
74 Honda Z50 build
Old 01-18-2012, 04:23 PM   #114
kikkegek
kikkegek's Avatar
he Bruiser, thanks man!
are you saying that about the bushings from personal experience?
Old 01-18-2012, 04:27 PM   #115
68Timber
68Timber's Avatar
Yes, and by the time mine was worn out I had tossed the factory weights and springs. I bought new kits to keep it going but they never lasted long.
John
74 Honda Z50 build
Old 01-18-2012, 04:45 PM   #116
kikkegek
kikkegek's Avatar
thanks but the curve of the factory springs is way too slow. I need fast advance, because I drive LPG 99.9% of the time.
I'll check the bushings regurlarly, thanks for the warning.
Old 01-18-2012, 05:25 PM   #117
68Timber
68Timber's Avatar
You can use the lighter Mr. Gasket springs with the stock weights and bushings. Hold on to them if you still have them.
John
74 Honda Z50 build
Old 01-25-2012, 10:06 AM   #118
kikkegek
kikkegek's Avatar
I still got them. I never throw away stuff, because here in Europe things are a lot harder to get then over there with you guys. But I think the stock weights were worn out..
Old 02-03-2012, 11:56 AM   #119
kikkegek
kikkegek's Avatar
finally some snow over here!
and now the engine broke down.
it used over a quart of cooling liquid last week and the cooling system had pinut butter like residu in it.
monday the local shop is checking it out for us..
for now...enjoy..
Old 02-04-2012, 11:01 AM   #120
motornut
78K & 79C Jimmys
motornut's Avatar
hope things arn't too bad with the block
how did you find the lights driving?
are you going to make another set?
they sure look cool,clean install
John
Old 02-04-2012, 02:09 PM   #121
kikkegek
kikkegek's Avatar
hahaha, thanks, thats funny. Quad setup would be very cool yes...but expensive and time consuming..need t spent my money probably on th engine.
the shop is gonna look at it monday.keep you posted
Old 02-07-2012, 06:11 AM   #122
kikkegek
kikkegek's Avatar
shop called today.
they think the engine runs supersmooth....thats the good news, hahaha.
they will replace the headgasket and while they are at it, they will check if I need to replace the heads with refurbished ones (new seals, flattened, etc)...probably will...
and then everything is fine again....pretty happy about that.
Old 02-07-2012, 08:06 AM   #123
motornut
78K & 79C Jimmys
motornut's Avatar
great,thats good news
John
Old 02-09-2012, 04:59 PM   #124
kikkegek
kikkegek's Avatar
got the car back! And everything is fine again. We were lucky, because they discovered that one of the old heads had two cracks in it. On was not repairable. Theb didnt charge us extra.
glad we can cruise again!
Old 02-11-2012, 04:06 PM   #125
will scratch
will scratch's Avatar
Please tell more about the natural gas system for fuel is that you originally installed.
79 2wd Blazer/ flip kit, drop spindles, drop springs.
355 c.i. sbc, 350 tranny
will scratch is offline   Reply With Quote
